07-22-2023, 12:07 PM | #3015 | |
General
18718
Rep 19,444
This is another check in the plus column for ICE. Auto recyclers pay for junk cars to recycle parts and then the raw materials, which are easily separated metals and plastics, because the value of the recycled materials is more than the processing cost.
Murf the Surf20463.00 M5Rick66626.50 |
07-22-2023, 01:59 PM | #3016 |
Rep 991
07-22-2023, 04:40 PM | #3017 |
Rep 2,377
Drives: 2020 BMW M4 CS
2018: I couldn't find more recent numbers.
80 Percent of EVs are Leased, Not Bought EV values drop like a rock after three years. That makes them great buys on the used-car market, especially if the automaker warrants the battery at least five more years. For contrarians and possible risk-takers, there's a strong argument in favor of buying EVs used. At three years of age, some sell for as little as 25 percent of their initial price and there are fewer wear parts, other than the battery. Most combustion-engine cars retain 35-55 percent of their value at three years of life. I think this is a big issue. Once you start down the lease road it's hard to get back to purchasing a car as the down payment can be prohibitive. We all remember what it took to buy our first house. |
07-22-2023, 07:44 PM | #3018 |
General
18718
Rep 19,444
07-23-2023, 02:00 AM | #3020 |
General
66627
Rep 21,538
What may happen when EB's are charged in your home
https://www.google.co.uk/search?q=el...id:3EuO0ydJfgs |
07-23-2023, 02:09 AM | #3021 |
General
66627
Rep 21,538
Another case of an EV catching fire while charging outside destroying a truck and another EV beside it.
https://www.google.co.uk/search?q=el...id:nsBgDXHVorE |
07-23-2023, 03:04 AM | #3022 |
General
18718
Rep 19,444
Precisely. Your misunderstanding definitions of words leads to such errors. Things you think are wrong, aren't. You've talked yourself now in a full circle, you must be dizzy.
07-23-2023, 05:20 AM | #3023 |
Rep 5,413
I'm just back from a 800 mile round trip from Glasgow to the Pembrokeshire forests in wales part of the journey which involves 3.5 hrs of drive through the forests with very few/ no fast charger in sight. So to and fro of that leg of the journey is 7hrs!
I had to take the EV as my other car the ice is sold and I'm awaiting the delivery of the new ice car and the trip couldn't wait. Journey in the EV has easily added an extra 4 hours to the 14 hour drive time in charging or looking for a charger. A side order of plenty of fast food while waiting for the car to charge and charging anxiety etc. Cost of the trip is the same if not higher than using an equivalent ice car. |
07-23-2023, 06:27 AM | #3024 |
Rep 991
07-23-2023, 06:40 AM | #3026 |
Rep 2,377
Things that make you go Hmmmm...
Interim Guidance for Electric and Hybrid-Electric Vehicles Equipped With High-Voltage Batteries NOTE: If the fire involves a lithium-ion battery, it will require large, sustained volumes of water for extinguishment. Consider defensive tactics and allow fire to burn out. • If there is active fire, follow local standard operating procedures (SOPs) for vehicle fires. Wear appropriate Personal Protective Equipment (PPE) and Self Contained Breathing Apparatus (SCBA). • If occupants are still inside the vehicle or trapped, a fire extinguisher may be used to protect the occupants until a hose line is available or the occupants are removed. Consider establishing a water supply to support long-term operation. • Use a hose line to apply water to extinguish the fire while continuing to cool the HV battery and its casing. Never attempt to penetrate the HV battery or its casing to apply water. • Avoid contact with orange high-voltage cabling and areas identified as high-voltage risk by warning labels. • Be alert. There is a potential for delayed ignition or re-ignition of a lithium-ion battery fire even after it is believed to be extinguished. This may remain an issue until the lithium-ion battery is properly discharged. • As with any vehicle fire, the byproducts of combustion can be toxic and all individuals should be directed to move to a safe distance upwind and uphill from the vehicle fire and out of the way of oncoming traffic. https://www.nhtsa.gov/sites/nhtsa.go...iredept-v2.pdf |
07-23-2023, 06:49 AM | #3027 |
Rep 991
07-23-2023, 06:59 AM | #3028 | |
General
66627
Rep 21,538
KRS_SN14258.50 |
07-23-2023, 03:39 PM | #3029 | |
Rep 1,371
Drives: 981CS/428/is250/JLU Rubicon
I just did similar 900 mile round trip to Santa Cruz for my sons graduation in our Tesla...zero range anxiety as there are plenty of charging stations to choose from and only had to stop for twice charging which took about 22 minutes tops...just enough time to grab a Starbucks or McDonalds breakfast ...spent a total of $56 in charging for almost 900 mile round trip and the added time was minimal when you time it with eating or stretching the legs. The horrors of road trips in an EV are extremely exagerated, at least in the US |
07-23-2023, 03:55 PM | #3030 |
Rep 2,766
The never ending discussion on fires is a strange one to me. Yet to see any statistics or data that shows I have a reason to fear any vehicle fire. I've also never known someone that a vehicle fire caused an injury or death.
Here's some data - There were 39,508 fatal motor vehicle crashes in the United States in 2021 in which 42,939 deaths occurred. https://www.iihs.org/topics/fatality...state-by-state
2006 Z4M Coupe - ZHP knob, stubby antenna, clutch delay delete
07-23-2023, 05:00 PM | #3031 | |
Rep 5,413
A trip from Glasgow to London and back would be easy as a 800 mile trip as there are plenty of chargers enroute some 350kw ie better than Tesla BUT when you go off the beaten road for nearly 7 hours Teslas or EV's as I alluded to earlier and am posting now are useless.. I'll attach the trip details from the tesla website nil are fast chargers for the 7hour leg and the IX stats just for comparison. |
M5Rick66626.50 |
07-23-2023, 05:27 PM | #3032 |
Rep 4,493
I’m spending the week in Vail and my Tesla is plugged in at home and sitting in my garage. What are the odds my house burns down?
07-23-2023, 05:37 PM | #3033 |
Rep 5,413
Hope I'm not spamming you lot but my 11 year old daughter asked. Can we drive to the arctic to see the polar bears dad..I couldn't resist saying..no .. not in this car ... there are no ev chargers down there kid...
I took the 12 and 11 year old kids on the road trip. Its safe to say they'd chuck an egg at the greta gang as they know the reality of road travel. |
M5Rick66626.50 |
07-23-2023, 05:52 PM | #3034 | |
Rep 3,292
AlpineBoost3930.50 |
07-23-2023, 06:49 PM | #3035 | |
Rep 1,371
Murf the Surf20463.00 |
07-23-2023, 06:56 PM | #3036 | |
Rep 1,371
Our home charger charges at 43 mile an hour, so full charge takes about 5 hours I always set mine to charge at 1am and its always ready by 5am. We also have 250kw Tesla super chargers stations that take about 15 minutes to go from 6% to 80% and they are everywhere when you are away from home Toyota, who is late to the game, just announced some crazy tech that claims 900 mile range and 15 minute charge times....that would be a complete game changer |
