03-11-2015, 10:27 AM | #199 | ||
IG @bmwF9xG80
3859
Rep 7,614
If you go on RaceGas you can prob go up to F,0,1,2,3,4 range (But I recommend going up 1 setting at a time) I know pdawg went up to 5 I've only reached 4, haven't tried 5 yet but i will end of month at the Dyno
60-130 6.5s X4M
60-130 5.04s G80 M3 Stock Turbo 60-130 4.82s | 9.4@148mph 1/4 Hybrids IG: @bmwF9XG80 |
03-11-2015, 11:55 AM | #201 | |
IG @bmwF9xG80
3859
Rep 7,614
I visited for a few days early Feb and I saw 93, 91, and don't recall if it was 89 or 87. I wouldn't recommend beyond F on 91 octane, RC-Germany has 98 RON which is 93 Octane USA.
60-130 6.5s X4M
03-11-2015, 12:05 PM | #203 | |
IG @bmwF9xG80
3859
Rep 7,614
At the pump you're filling says 93 or 91 ?
60-130 6.5s X4M
03-11-2015, 12:13 PM | #205 |
IG @bmwF9xG80
3859
Rep 7,614
There's 93 then I filled up at ARCO and 76Gas in Santa Monica
60-130 6.5s X4M
03-12-2015, 05:18 AM | #207 |
Rep 197
Question from the naive: if the maximum safe increase in boost with premium gas and no other mods is in the range of 3-4 psi (BMS Stage 1, JB4 map1, AFE Scorcher, etc.) why would you get more power out of the RC ? Isn’t it the same maximum safe boost under full throttle?
03-12-2015, 07:51 AM | #208 |
Rep 39
Forgive me if this has already been discussed. What does the "plug" do (that comes with RC) Does it simply put you back to stock without removing the wiring harness? I installed the RC last weekend and I honestly don't notice a seat of the pants difference. I've been making runs with it plugged into the module and then unplugging from the module and putting the "plug" in to compare. I have no way of quantifying the power change other than seat of the pants which is a poor scientific experiment but I was hoping that would be all that would be necessary!! Human nature is such that we believe what we want to believe especially when we have spent money on it!! I do think it has affected my mpg's positively although I won't know for sure until I fill up this weekend and check the mileage. I never trust the mpg's that a car's computer tells me. I always check it the old fashioned way with a calculator (miles traveled divided by gallons used).
I've also been interested in the discussion about how to plug in the harness. There are absolutely no instructions with this purchase which is ridiculous!! I've read that it doesn't matter.....that the module will "figure it out" regardless of how you hook it up. That may be but I contacted the vendor I purchased this from and he had no clue so he contacted the manufacturer and 5 days later came back with the verdict that the harness with the yellow wire should be plugged in on the right and the harness with the white wire should be plugged in on the left. For what it is worth I have now had it plugged in both ways and my car seems to perform similarly. In fact it doesn't seem to matter what I do......it seems all the same. When I give it throttle from a dead stop in sport+ it will not break the tires loose but when the rpm's get up to 5k or so the tires will break loose a little in 1st and again in 2nd. Thoughts??? |
03-12-2015, 08:08 AM | #209 | |
Rep 39
03-12-2015, 08:58 AM | #211 | |||
IG @bmwF9xG80
3859
Rep 7,614
I'm testing my RC above F to see its tolerance with my engine without any mods. And I've seen 21-22 boost (for me 17 is stock I believe) Quote:
The stock setting is a optimal balance for MPG improvement and minor performance improvement, as you increase each setting will get performance higher. If you've driven 20-30 miles and don't feel anything its because each engine will react a little different to it. Increase 1 setting up to C drive 20-30 miles (normal at first, then full throttles to see how it feels for you). Test 1 increase and let us know. My friend with 550 is happy on B, mine came on C but I have tested it for the past 4 months in each setting to notice the big difference (2 ticks above stock due to my weaker engine). My other pal noticed big change 1 tick above on his F15 50i. I know Alex is still on stock B (but has perf mods), Chaddy is on F, and Delnari is prob heading to C by now.
60-130 6.5s X4M
03-12-2015, 09:47 AM | #212 |
Rep 197
03-12-2015, 10:51 AM | #213 |
Rep 1,040
If you are not hearing or feeling a different in acceleration your unit is not working. Again this is the best Stage 1 piggyback I have installed to date. The difference with the RC Ultimate is tuning the faster processor can give compared to similar MAP sensor only units. They claim boost is not as high as competitors. They can manipulate signal adjustments faster with the more powerful computer. I'm a believer!
03-12-2015, 11:08 AM | #214 | |
Rep 809
And that the unit does not come with detailed installation instructions, no big deal, at the beginning I was confused too, but then (with a little help from pals on this forum) I understood where those cables go and that manufacturers claim that either one goes to either sensor connector, it worked for me without a problem. I suggest you claim your warranty with your vendor. Last edited by AlexGT; 03-12-2015 at 04:04 PM.. |
03-12-2015, 02:32 PM | #215 |
Rep 197
03-12-2015, 06:53 PM | #217 |
Rep 1,040
Someone had posted a European article comparing the top piggyback units on the market for the M235i in Europe. If you search you find the article showing the top performing units. The RC Ultimate finished in the top section explaining how it delivered more performance with less boost than some of it's competitors. Making power is more than just making more boost.
03-12-2015, 11:11 PM | #218 |
Rep 678
Great feedback, Alex, chaddy and Delnari. I might give this a spin after my 10k maintenance in a couple months.
Chaddy, I understand your the only one running it with a cat-less DP and not throwing any codes. What is the list price on the RaceChip?
2022 M4 Comp X 2021 M440ix - Sold 2015 M235 - Sold |
03-13-2015, 12:36 AM | #219 |
Rep 536
Mate Im running a catted DP 200 cel !! The ER provided zero gains over the high flow catted option and of course the car is happier.
My advise on exhaust is catted 200 cel DP "stock mid pipe" and a high flow axle back section and muffler. Chaddy, I understand your the only one running it with a cat-less DP and not throwing any codes. What is the list price on the RaceChip?[/QUOTE] |
03-13-2015, 12:46 AM | #220 |
Rep 536
There are several factors to making power, boost is only one aspect.... important of course but other things like airflow, IAT temps,timing , engine load and AFR's play an equally important role to making good power. Although I dont believe the RC alters AFR it does a very good job on other areas to provides clean solid power BUMP with equally as good delivery.
