2Addicts | BMW 2-Series forum Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics The "Official" F22 OBD2 wireless adapter / Android+Torque / iPhone+DashCommand thread
      05-04-2017, 07:06 AM   #199
orangeglim
Drives: 2019 M2C
2019 M2C  [0.00]
I picked up the pieces to do this in my M235i a couple days ago. I ended up going with this equipment:
ScanTool 427201 OBDLink LX Bluetooth - $50
https://www.amazon.com/ScanTool-4272.../dp/B00H9S71LW
I have an iPhone, so using my phone with it was a no-go. Also, my iPhone is a 5S with a 4 inch screen so I wanted something larger. I picked up this phone from Amazon:
BLU R1 HD - $60
https://www.amazon.com/BLU-R1-HD-Exc...dp/B01H2E0J5M/
I got the version with the Amazon special offers, so it shows ads on the lock screen. This isn't my primary device so I don't care about that. This is a surprisingly nice device for $60. I don't have a SIM installed in it because I don't need have a need for that. The phone is installed in this holder:
Belkin Car Cup Holder Mount for Smartphones - $30
https://www.amazon.com/Belkin-Car-Ho.../dp/B00NL7GTXG
For the app I'm using Torque Pro from Google Play:
Torque Pro - $5
https://play.google.com/store/apps/d...l.torque&hl=en
I've automated things a bit using Macrodroid:
Macrodroid - Free - $3 for no ads
https://play.google.com/store/apps/d...crodroid&hl=en
My automation works like this:
1. I wake up and unlock the phone. Macrodroid turns on bluetooth, waits 1 second, launches Torque.
2. If I lock the screen Macrodroid asks Torque the quit and turns off bluetooth.
3. If I happen to forget to lock the screen manually when I'm done, when the car turns off the lighter, which my phone detects as power being disconnected, Macrodroid asks Torque to quit, turns off bluetooth, and locks the screen.
4. If the Light Sensor increases to 25lx, wait three seconds, if still 25lx, turn the screen brightness all the way up. This makes it easier to see in sun light. Auto brightness on the phone itself doesn't bring it all the way to 100%.
5. If the Light Sensor decreases to 10lx, wait three seconds, if still 10lx, turn the screen brightness to 10%. This makes it less bright at night.
This way Torque is only running when I unlock the phone. If I don't want to see it, I lock the screen and Torque disconnects from the car and bluetooth turns off. I don't have to worry about it being connected when I don't want it. So far everything works pretty well but I'm only a few days in.
      05-04-2017, 09:55 AM   #200
BentZero
BentZero's Avatar
Thanks for the Macrodroid tip!
Build thread
      05-04-2017, 06:00 PM   #201
orangeglim
Drives: 2019 M2C
2019 M2C  [0.00]
No problem. I edited my previous post with two new actions I added to adjust the screen brightness. I'll need some time to fine tune these actions a little more, but so far, so good.
      05-29-2017, 01:28 PM   #202
lennyf
lennyf's Avatar
162
Drives: 2017 BMW M240i
Anyone here familiar with the Kiwi3 OBD2 module??
So for iphone users whats the app of preference?
Torque Pro or Dash Command
      09-05-2017, 11:28 AM   #203
cbeg50
Scangauge 2 parameters to display EOT
Originally Posted by Zooks527 View Post
Or just put a ScanGauge under the headlight control.
Does it have a real 70s J.C.Whitney feel? Sure. However, no one but the driver can see it, the left 2 columns are visible to the driver all the time, it's not there in the middle of your dash acting as a magnet for some kid to break your window, and your wife won't spend any time chewing your ass for blocking her vent in the summertime.
You're also not broadcasting an unprotected Bluetooth link into your ECU whenever your car is running.
Hi Zooks527,
Could u do me a favor and provide the scangauge parameters to display engine oil temperature EOT? I'm unable to get this to display on 2015 M235i. Thanks
      12-03-2017, 01:38 PM   #204
aerodavew
Drives: 2014 M235i
Has anyone tried the Bluedriver?
      12-26-2017, 01:32 PM   #205
stlb5
stlb5's Avatar
227
Drives: '19 M2C MT, '15 X5 Msport
What is the difference between the different vgates? Icar2, Icar3, Icar pro?
      01-04-2018, 07:26 PM   #206
stlb5
stlb5's Avatar
227
Torque question. Has anyone figured out if the ability to show oil temperature is model/build year specific? I have a 05/14 build and it's not showing up for me. I've tried a Vgate and another WIFI device. I also have a P3 Gauge and oil temp shows up on it.
      01-04-2018, 08:21 PM   #207
SteveInfante
NewFinishColumbia/detailer
SteveInfante's Avatar
Drives: 2015 F31 xDrive
I don't think it's year/model specific. My car is a 05/14 build and it works. I can't remember how to get it to work but I did find the info in here. I haven't used it for a while so maybe read the whole thread. It's a setting when you select a custom set of gauges if I remember correctly.
I have oil temp, coolant temp, boost pressure, oil pressure, and speedo set to my custom gauges.
78' Honda CB400A project
      01-06-2018, 10:04 PM   #208
stlb5
stlb5's Avatar
227
I went back through the thread and post 134 has instructions for adding oil temp to dashcommand, but not Torque. Any chance you can remember how to do it in Torque?
      01-18-2018, 03:13 PM   #209
stlb5
stlb5's Avatar
227
I'm still looking for help. I cannot get oil temp to show up. Has anyone gotten it to work after in not initially showing up?
      04-01-2018, 07:00 PM   #210
BMDUBGIRL
Drives: 2016 M235i
After reading through this thread, I used the Vgate iCar Pro OBD II wi-fi ($30 on Amazon) and Bimmer Code (coding app $26.99) on my iPhone X.
It was a breeze, the Vgate worked perfectly, and it took under an hour. My coding changes so far:
1) Remove Disclaimers
2) Add digital speedometer to instrument cluster. For those who lost their time in the display, the time will re-set when the car connects to Connected Drive.
3) Added M animation on display screen at start-up.
4) Removed M235i logo in instrument cluster. I really like the cleaner look of the cluster without it.
5) Added M Performance logo at start up in instrument cluster.
6) Mirror fold on lock.
Thanks to all who posted tips on how to do this. The best $56.99 I've spent on my car so far!
      06-08-2018, 12:10 AM   #211
bit8m
Drives: 2016 M235i
Is anyone aware of custom OBD2 PIDs for BMWs in general of F22 specifically that can be added to Torque Settings -> Manage extra PIDs/Sensors?
      06-11-2018, 12:01 AM   #212
TwistedX
Really Twisted
Drives: 2015 M235i F23 8AT
Has anyone figured out if these cheaper wifi/Bluetooth obd adapters will work with Carly coding and the torque app for android?
2021 Jeep Gladiator Rubicon
2015 BMW M235i F23 - Sold
      08-15-2018, 08:39 PM   #213
ZeeJM
Drives: 2018 M240i xDrive
I bought the "Panlong Bluetooth OBD2 OBDII Car Diagnostic Scanner Check Engine Light for Android - Compatible with Torque Pro" on Amazon and have used it successfully with Torque Pro and Bimmercode.
      09-14-2019, 01:05 PM   #214
MAILIYAT
Drives: MUSTANG
Originally Posted by fkacct View Post
This is absolutely awesome. Never thought something like this exists for so cheap! Is it possible to pair the iSaddle Bluetooth and your phone to car Bluetooth connection at the same time?
OBD2 (On-Board Diagnostics, Version 2) is a hardware Dafont Showbox Adam4adam diagnostic & sensor protocol for communicating your car’s sensor & error data to an external scanner or monitor. In the early days, scanners were expensive pieces of standalone equipment costing many hundreds (thousdands?) of dollars.
      05-16-2020, 04:19 PM   #215
rsessin31@me.com
Drives: 2014 BMW M235i
Originally Posted by wjones14 View Post
  1. Press the Gauges button
  2. Tap near the top of the screen and Press the Edit option when it appears
  3. Press the Add Gauge option at the bottom
  4. On the Edit Quick Gauge screen, press the Needle PID option under PID
  5. Under Name press the SAE.RPM value
  6. You should see a list of PID categories. Choose Temperature
  7. The Engine Oil Temperature PID is SAE.EOT. Choose that.
That's the hard part. The name of the gauge will be Quick Gauge, so change it to Oil Temp. Then set your low and high ranges. I went with 0-300. That's the basics.
Dash Command doesn't really prompt you in an intuitive way to add the PID, and even after that, it has no idea of the range, so it's like 0-3000 or something.
Hope that helps!
I have a 2014 m235i and i have tried both Dashcommand and Torque pro, neither are displaying the oil temp! It's extremely frustrating and i cannot figure out why! Any advice??
      08-06-2021, 12:12 PM   #216
Kinesthesia
Kinesthesia's Avatar
Drives: 2014 M235i
I bought this to plug into my m235, it works great with Torque Pro on Android.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
