07-29-2020, 08:27 AM | #1 |
Rep 27
Anything wrong with these plans?
My M235i is currently stock but my future plans are below and I'm looking for any feedback on possible damage to the car, if something else will need to be upgraded because of the increase in power, if any of the parts are no good or not going to perform good considering the other additions. After doing a lot of research from this site and many others I do believe this setup should work fine Thanks for any input.
***I know Dinan is over priced but I like the products. VRSF - Catless Downpipe, Charge Pipe, and 5" HD intercooler Bootmod3 - Stage 2 Dinan - CAI, Res Delete, and axle back exhaust. |
07-29-2020, 11:05 AM | #2 |
Rep 870
All looks good
HOWEVER - I WOULD BUILD IN STAGES.
The Cattless DP and exhaust may be loud enough. . I am only Stage 1 93 and think the car runs great -- and Still don't have a DP or Exhaust (my next 2 mods). Although - I plan to start with the Exhaust and could end there if the tone is perfect and even then I would only go Catted DP. . . So - may I suggest progressing along with CP, IC , Exhaust & Tune (Stg 1) then see how the car is running. Ensure that your car can handle Stage 1. Then when all is verified as good --- progress to DP, RES Delete, & STG 2 as necessary. If all depends on your use for the car. |
07-29-2020, 12:07 PM | #3 | |
Rep 243
Another mod you may need to look at is a transmission flash? I'm manual but I think the autos benefit greatly from a flash to handle the added power, right? Anyway, good luck and enjoy your transformed car
'15 235i - Moddedededed
07-29-2020, 02:43 PM | #4 |
Rep 5,477
You get what you pay for with the VRSF parts. Remember that.
07-29-2020, 03:38 PM | #5 |
Rep 8,942
Vert or convertible? Either way I'd suggest ER CP. DP I don't know never investigated. FMIC if convertible have to go with Active Autowerke nothing else will fit. Tune that's a longer discussion, but I've heard good things about the new Dinan flash. CAI definitely Dinan, rest are a waste of money. If not Dinan just upgrade your filter to AFE Dry Pro S.
Resonator delete - Dinan will not fit on convertible. Either way I'd skip it. I would also skip Dinan exhaust for a variety of reasons. 1. the valve actuator is just zip tied to your bumper, that's lazy engineering. 2. you can never swap the tips, if they get messed up you're stuck with them. I'd go with either AWE or MPE, and lean heavily towards AWE. That said you can get MPE for less if you get a used one, AWE doesn't pop up for sale very often.
07-29-2020, 06:21 PM | #6 |
Rep 27
I dont believe the CP VRSF will really matter as long as it isn't the stock CP lol. But are you referring to the DP or intercooler with your passive aggressive suggestion of cheap parts lol or both? I'm down for any recommendations if you have any. I'm new to tuning so my ears are wide open. However, I am not a drag or track every weekend guy. This thing will be on the track maybe 3 times a year and maybe once for Drag just for Sh!ts and gigs. I am also a very firm believe in you get what you pay for but knowing that my car won't get pushed to hard that often made me comfortable with the VRSF stuff. Please let me know if I should be looking at other stuff.
And for whomever was asking its a coupe. I have a fear of convertibles being 6'8" lol. Thank you everyone for your inputs. |
07-31-2020, 02:29 AM | #8 | |
Rep 5,477
Don't waste your money on the Dinan resonator, especially if you're adding a cat back and catless DP. Dear God will it be loud and raspy. Also, the Dinan tips will rust in the KS salty winters. The Dinan catback also hangs funky. The Dina CAI is alright but it has an oiled filter. You could buy the MPPK/M2 lower airbox and an AFE dry panel air filter and get nearly the same sound for half the price. The best sounding and fitting catback is the M Performance exhaust and sounds epic with a quality catted DP. After nearly 25 years of modding cars, I'm a firm believer that if there is a factory performance part available, spend the money and get it. It will fit better and often perform better. If you want an IC, you really need to research and learn about them. It will be overwhelming as there is not perfect IC. Bigger is not better. They have their compromises. All of them. I'm stage 2 and live in KC. I don't track my car or do multiple back to back pulls so I see little need for an IC at this point. Stock does fine for my driving and I do get on it often. If I did an IC, I'd probably go with the cheapest CSF IC. |
P253.50 |
07-31-2020, 08:05 AM | #9 |
Rep 130
The FTP charge pipe looks solid. Good advice as always XutvJet.
I was considering the Turner Motorsport option, in part because I have all my work done at Turner Service. https://www.turnermotorsport.com/p-5...-complete-kit/ This kit has the cold and hot side pipe. Wonder if there is any advantage adding a hot side pipe? All I want is protection for a mild stage M2 0+ tune. It recommends a plug for manual transmissions... newer seen that either.
[FONT="Arial"] M235i 6 speed, MGM. Wavetrac LSD with altered final drive ratio, MPE, MPK Airbox, side skirts, diffuser, Dinan springs, LCAs.
07-31-2020, 07:49 PM | #10 | |
Rep 4,969
08-15-2020, 11:56 AM | #11 | |
Rep 109
Again, videos don’t quite do justice, but here are two sound clips of my set-up to give you an idea.
2024 BMW X3M Comp ~ Individual Gentian Blue
08-16-2020, 05:35 PM | #12 | |
Rep 409
08-19-2020, 10:26 PM | #13 | |
Rep 27
Conr4d33.50 |
08-28-2020, 12:36 AM | #14 | |
Rep 233
Have to say I agree with XutvJet about getting what you pay for. For bolt ons I bought Wagner, ER or Dinan. Not the cheapest but all installs were smooth (DIY) and haven't had any problems in years. Personally I haven't had experience with the other brands mentioned but didn't want to risk any headache.
16 M235 Cabrio - BM3, XHP, ER CP, Wagner DP & IC, MPE, Torqbyte CM5
18 340i F30 mostly stock |
08-28-2020, 08:45 AM | #15 |
Rep 4,969
OP, don’t get caught up with ‘named brand’ because that’s not going to determine what product functions better.
Intakes add zero power. I have a Dinan intake I’ll let go for cheap if you’re really interested, but they don’t add anything. A AFE dry drop in and a lower MMPK box are likely going to be as good. Careless + Resonator is a bit obnoxious. I have a cat less down pipe and a M performance exhaust. It drones and has a bit of raspy ness too it - but outside of cold start, it’s not too loud. I wouldn’t overthink this too much, it will always sounds like a vacuum cleaner. One word of advice: I wouldn’t buy a high end catted Downpipe unless they offer SOME guarantee like Fabspeed does. The worst choice you can make on an IC is buying one that is too small. No comment on what you SHOULD get, but I will say you want an IC that’s a 6” core or larger (especially for stage 2) |
TACP4.50 Pussiwillow529.00 |
