07-08-2019, 05:55 PM | #1 |
Rep 1,652
M235i steering and responsiveness
Hey folks! I've had several BMW's over the years but nothing this small. Is it just me or is this car very sensitive while steering? It's so responsive it's almost a little scary and I can see getting out of control quite easily. I'd say Go-Cart comes to mind but you get my drift.
Is it the extreme oversteer I'm feeling where it doesn't take much to change lanes and get around? My e92 is almost 3 inches longers so it's the shorter wheel base, I get it. But for the first timers driving this car has anyone every experienced the same feeling. It feels very very light and easy to maneuver ...too good in fact where it gets pretty scary and I feel like I'm going to end up facing the other way. Experience and thoughts please! |
07-08-2019, 06:40 PM | #2 |
Rep 7,093
Drives: 2018 M2 AW DCT
I wonder what tires you have on your M235i. Mine was excellent and very well planted. I ran Michelin PSS and then switched to Michelin A/S 3+.
07-09-2019, 04:25 AM | #4 |
msej449
518
Rep 721
Do you have the 2VL Variable Sports Steering? On my UK build this was a standard feature. My previous BMWs didn't have it and it took a bit of getting used to on my part, as opposed to my wife, who took to it straight away and much prefers the steering on our M235i to the 'standard' steering on our previous 3 Series. I had to sort of 're-map' my own physical steering adjustments, especially at speed. Like you, I felt that if I lost concentration, then at speed I'd be in danger of over-turning the wheel.
RMNB369.50 |
07-09-2019, 04:45 AM | #5 |
Rep 1,652
Thanks for the quick responses! I currently have the Pirelli P7's grand touring all season rft which are awful. So the Mich P4's are going on in a few days as TireRack hooked me up once again. I'm certain this will be a big improvement.
Not sure about the variable steering. How can I find that out? Build sheet from dealer perhaps? Nonetheless, there will continued progression on the suspension but not sure what will make the biggest improvement. Someone said M3/M4 control arms. Thoughts on this? Eibach springs would help? I can say the Koni FSD's I have on my E92 plus AG M359's (9"x10"), 235fr & 275r certainly makes that car feel planted. No fear at all in hard corners! PSS of course. If anyone else has any thoughts chime in. |
07-09-2019, 07:54 AM | #6 | |
Rep 3,611
After tires, two things will most improve your driving enjoyment: a limited slip differential, and coilovers w/camber plates and enough negative camber to meet your needs. Your choice as to which to go with first (I'd start with the LSD).
07-09-2019, 11:23 AM | #8 | |
Rep 5,479
The M235 has a short wheelbase, a pretty quick steering rack (quite a bit quicker than the E92's), and a smaller steering wheel. The M235 steering, even in the Sport setting, is a bit lighter than the heavier E92 steering. The quicker and lighter steering and smaller wheel in the M235 is screwing with your muscle memory. You'll get used to it. Also, the crappy, stiff sidewall, and narrow (for a 225 width tire) P7s further compound the nervousness of the chassis and steering and can make wheelspin an annoyance. The new tires will make a huge difference in stability and grip. Hopefully you're getting wider tires. If you really want to improve the chassis dynamics, an LSD is the way to go. Don't waste your time with suspension improvements until you do the LSD.
RMNB369.50 |
07-09-2019, 06:29 PM | #9 | |
Rep 1,652
07-09-2019, 06:34 PM | #10 | |
Rep 1,652
Also, you mentioned LSD. GIve me the TOP 3 LSD's out there that most folks go for. I've heard of Quaife… what's the big deal about this one? Feed me people! I need to spend some more money so my wife "officially" kicks me out! |
07-09-2019, 06:48 PM | #11 | ||
Rep 3,611
My focus performance-wise is the track, and the car steers just fine for me there. Because it "steers like a BMW" (my characterization), I doubt that's because of VSS but don't really know. Quote:
Dan has whatever you need in the way of an LSD, whether it's off-the-shelf or they have to build it for you (the latter is unlikely unless you're planning on wheel-to-wheel racing). He'll ask you how you plan to use the car, on the street and otherwise, and then he'll recommend an appropriate diff. FWIW, Dan won't try to sell you the most expensive diff he can, so you don't need to worry about that. I've done business with DiffsOnline since 2009, and everything has always been straightforward with no bs. That's where I got my Wavetrac. No affiliation - just a satisfied customer.
TC Kline Coilovers; H&R Front Bar; Wavetrac; Al Subframe Bushings; 18X9/9½ ARC-8s; 255/35-18 PS4S (4); Dinan Elite V2 & CAI; MPerf Orange BBK; Schroth Quick Fit Pro; Full PPF Last edited by dradernh; 07-11-2019 at 09:32 AM.. |
RMNB369.50 |
07-11-2019, 12:11 AM | #12 | |
Rep 395
PSS --> A/S 3+ for a year and tons of rwd grip Last edited by rainfall; 07-11-2019 at 03:07 AM.. |
DanG11348.50 |
07-11-2019, 03:04 AM | #13 |
msej449
518
Rep 721
Over here in the UK the Pirelli P7 is simply not used for M-Lites by BMW either as OEM or in BMW retro-fit wheel+tire sets. Go to the Pirelli UK website and put in an M235i and the P7 isn't shown at all, only the PZero. BMW do use the PZero as OEM and on their own wheel/tyre sets (but then, only for summers). I can't fathom why they use the sedan/comfort-oriented P7 tire on a performance car like the M-Lite, especially given the trouble it so obviously causes. Ditto all-seasons: sorry, but again, I wouldn't put all-seasons on a performance car like the M235i either, and nor does BMW UK (where all-seasons are popular given the often wide range of weather conditions thru a UK driving year). So, basically, change your P7s for something more suitable as recommended here and on the Tires Thread.
I retro-fitted a BMW LSD 2 years after getting the car and wish I'd done so sooner. It really should have come with it as original equipment. 230 or so BHP and RWD really demands an LSD. Don't necessarily expect a dramatic difference initially - but over time you come to appreciate the way it stabilises the handling e.g. oversteer is very progressive and predictable and you get a lot less intervention of the electronic traction control. It's very rare now for my eLSD to intervene unless I've badly misjudged my power input (which happens, of course, from time to time :-) ) So I'd agree, retro-fit an LSD first, get used to it, and then decide if you need to do anything more. Finally, from time to time you'll see me posting video from a skidpan training course I did at my local track (Goodwood UK) in an M140i which only cost £99 for a hour on-track instruction. I'd recommend finding something similar, as it lets you try SPORT and DSC=OFF in a safe environment using someone else's car and makes your driving much more confident when you're back in your own car on public roads. It also programmes that muscle memory to unconsciously react properly when - inevitably - you get it wrong on the road.
2023 Peugeot e-208 GT (electric) Last edited by msej449; 07-11-2019 at 03:22 AM.. |
RMNB369.50 |
07-11-2019, 05:21 AM | #14 | |
Rep 1,652
