01-25-2015, 11:02 PM | #1 |
Rep 627
JB4 Map 1 vs Map 5
Hello,
Is there any particular reason why a majority of JB4 users prefer running map 1 instead of map 5? I thought map 5 learns based on temperatures, IAT, mods, etc. Am I missing something? |
01-25-2015, 11:28 PM | #3 |
Rep 627
Hmm forgive me if I sound ignorant, but wouldn't it be better to let the tune learn the car over a period of time to produce the best gains? Map 1 is a fixed tune but as well all know, every car is a little different.
01-26-2015, 12:40 AM | #4 |
Rep 5,262
what i heard is that it's not that it "learns" over a period of time but it changes constantly... and apparently it changes so much that at one moment you have X horsepower and 3 mins later you have X-50
So i think that's what people complain about it... rather have a constant known power than the power going up and down |
01-26-2015, 02:18 AM | #5 |
Rep 4,599
Map 1 needs no extra mods.
Map 5 can be used on a stock car but not sure you'd see much benefit over map 1. However, if you add bolt ons to allow JB4 to target higher boost ie DP, map 5 comes into its own.........you wont run map 1 again !!
Current '22 X3M LCI.. |
01-26-2015, 09:30 AM | #6 |
SoFlo_BD
359
Rep 1,748
What he said^
I usually only run map 5 if I have e85 in the tank so it can adjust for octane and raise boost. DP I still prefer map 2 for more consistency. At the end of the day you just need to experiment with the maps that support your mods and determine which you like better. It all comes down to personal preferance. |
01-26-2015, 12:00 PM | #7 |
Rep 194,538
map 1 is same boost targets no matter which mods you have
map 5 auto tunes and changes boost target depending on your mods, fuel and IAT. You need to test drive both and decide which one you like better. I like map 5 because it has smoother power delivery but then again i am FBO with e50
01-26-2015, 02:29 PM | #9 |
Rep 4,599
M8 -if you think map 1 is good, wait until you try maps 2, 5, 6 or 7 with suitable BO's and fuel grade. Its LoL fast !!!
01-28-2015, 04:19 PM | #10 |
Rep 257
02-06-2015, 05:10 AM | #12 | |
Rep 197
02-06-2015, 09:56 AM | #13 | |
Rep 194,538
Map 1: Peak boost 12.5psi, suggest for most racing applications. Map 2: Peak boost 14.0psi, suggested for those using exhaust mods and 93 RM2 octane or higher fuels Map 3: Progressive methanol mapping Map 4: Stock performance, JB4 on Map 5: Autotuning, enabled in 8.8 and later firmware Map 6: User definable map. Suggested for troubleshooting by professionals only. Map 7: Race gas map. Peak boost 18.5psi. Requires straight unleaded race gas.
02-06-2015, 10:01 AM | #14 |
What goes here?
456
Rep 1,356
Drives: 2019 G30 M550i
Garage List 2019 BMW M550i [0.00]
2021 BMW M3 Competi ... [0.00] 2019 BMW M5 Competi ... [0.00] 2016 BMW M3 [0.00] 2014 BMW M235i [0.00] |
Map 2 peak is 14.5, not 14.0.
2019 G30 M550i
GBNF: 2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i |
02-08-2015, 08:43 PM | #15 |
WRX Betrayer
68
Rep 141
So, I've got an xdrive m235i m performance exhaust and jb4 stage 2 on map 5...would you guys recommend map 1 for the time being and then going to map 5 when I install my downpipe? Can someone spell out the maps and uses by the extent of modifications you have? Have yet to go to map 1 since I started on map 5 as that was recommended by the motorsports garage I go to. Anyone seen better delivery from map 1 on a completely stock car compared to map 5 that can attest to it?
02-08-2015, 10:00 PM | #16 |
Rep 627
I personally like map 5 a lot better than map 1. I have intake, jb4, and downpipe.
I feel like the power is a lot smoother than map 1 or 2, but again it's my opinion. Like what others have stated - you just have to find what you prefer. |
02-09-2015, 03:00 AM | #17 | |
Rep 4,599
Agree with your observation that map 5 [autotuning feature] does feel smoother than the maps with fixed parameters.
02-09-2015, 06:11 AM | #18 | |
Rep 197
02-09-2015, 08:49 AM | #19 |
Rep 965
02-09-2015, 11:17 AM | #20 | ||
Rep 194,538
That being said the JB is adjustable, you can increase it to 4 if you would like more power.
12-09-2015, 02:56 PM | #21 |
Rep 174
sorry to revive an old thread but if my car was stock other then the JB4, would i be correct in thinking that i should be on map 5 if i put e85 mixture in with my 93. and is there a ratio i should be putting in. also i have Sunoco 100 available is that better or worse?
12-11-2015, 11:01 AM | #22 | |
3455
Rep 79,211
E85 Use Models equipped with the pneumatic wastegate & flex fuel connector may experiment with up to 40% E85 mixtures. Some cars tolerate E85 and some do not. Cars that do not tolerate the mix will "buck" or "miss" at full throttle. In some cases map 7 can be used on the E85 mix and in other cases map 2 is the highest that can be used. It's best to start slowly and work your way up in terms of aggressiveness when experimenting with E85 mixtures. |
