The "Official" F22 OBD2 wireless adapter / Android+Torque / iPhone+DashCommand thread |
07-30-2015, 02:33 AM | #133 |
Rep 980
wjones14, could you do me a huge favor and explain to me how you got an oil temp guage to show up in DashCommand? I do not see one in the default guage set and I cannot figure out how to get one. Huge thanks in anticipation.
(Of course, I may well be one of those people whose ECU just doesn't output oil temps to DashCommand. I have a 2015 228i N26).
2015 BMW 228i M Sport w/Track Handling Package DAP | Lighting | Premium | Tech DINANTRONICS Performance Tuner Stage 1 | DINAN Shockware | DINAN Free Flow Exhaust | DINAN Performance Spring Set + Ride Quality and Handling Kit |
08-01-2015, 06:04 PM | #134 | |
Rep 968
That's the hard part. The name of the gauge will be Quick Gauge, so change it to Oil Temp. Then set your low and high ranges. I went with 0-300. That's the basics. Dash Command doesn't really prompt you in an intuitive way to add the PID, and even after that, it has no idea of the range, so it's like 0-3000 or something. Hope that helps!
In between cars. 2025 G87 ordered!
Vehicles: 2011 Kawasaki Z1000 (1/4 mile 10.3 seconds @ 129 mph - stock) Previous: 2021 Alpine White M2C 6MT; 2018 Camaro 2SS 1LE 6MT; 2015 BMW M235i 6MT; 2015 Mini Cooper F56 6MT; 2005 Mustang GT 5MT |
08-02-2015, 01:47 PM | #135 |
Rep 968
Updated screenshot of Dash Command on an iPod Touch 5th gen. I edited the gauges to both look the same. This is after running the car around town for about 15 minutes on a beautiful 81 degree day. The coolant temperature cycles from 225 to about 165 and then gradually back up again - I guess the thermostat opens when it's about 225? And the oil temperature seems to stay more consistent.
08-05-2015, 08:22 PM | #136 |
Rep 29
I've tried both OBD Fusion and Dash Command and neither of them support the oil temp PID for my car. Build date 03/2014. I'm out of ideas apart from a P3 gauge or new steering wheel. Sad really.
08-11-2015, 09:38 PM | #137 | |
Rep 1
08-22-2015, 08:13 PM | #139 |
Little Deuce Coupe
394
Rep 635
Drives: SO M2C
Is Smartview somehow allowing you to mirror to the screen or is that a mirroring unit?
ex: 2004 Thermonuclear Yellow RX-8|6MT
ex: 2015 Estoril Blue M235i |6MT|slicktop|MP exhaust - PCD 2020 Sunset Orange M2C|6MT|Black 788s |
10-25-2015, 02:20 AM | #141 | |
Rep 75
Drives: 2015 228i MSport,THP, PP
Ordered from amazon.ca
VIDoug Vancouver Island
2015 228i MSport, THP, PP, MG |
10-28-2015, 11:56 AM | #142 |
Rep 265
I got the iKEGOL iCar WiFi version and am using it with an Ipod touch 5 with Dash Command in my M235i. I made a couple of quick gauges. It works!
01-29-2016, 07:40 PM | #144 |
Rep 886
He was selling that setup here: http://www.2addicts.com/forums/showthread.php?t=1174531
02-11-2016, 07:35 AM | #146 |
Rep 1,752
Man, not sure how I missed this thread, but this is pretty sweet. I'm trying to decide between the iSaddle and BAFX bluetooth adapters. Can someone explain what the differences are? Thanks.
02-15-2016, 12:26 PM | #148 | |
Rep 300
[IMG]https://www.dropbox.com/s/kjdcrxecex...%2021%20AM.png[/IMG] (note that I selected Celcius as the data, but scaled the gauge as if it was Fahrenheit, which is why it only reads 90) Last edited by simoneves; 02-16-2016 at 01:44 AM.. |
02-27-2016, 12:03 PM | #149 |
Rep 781
How do you setup 30 - 50 mph acceleration in Torque Pro (or any other ODBD2 app) ?
In this way your acceleration can be compared to results found in magazines like autoexpress.co.uk (they always test 30 - 50 mph in 3rd and 4th gears). |
03-13-2016, 03:42 PM | #150 |
Rep 1,752
Another vote for Bluetooth iSaddle. I have a 2016 M235i. I'm using Torque on my wife's old Samsung Galaxy S4. I'm able to get oil temps in both the engine parameters list as well as the engine oil temp gauge. I liked that I could get a digital speed gauge too, but I've since coded my car and now get digital speed in BC. Overall I'm pretty happy with it. I leave it plugged in at all times and haven't had any battery issues. If I decide to keep this permanently I'll need to run a USB cable through the air vent for charging. For now I just detach the phone from the magnetic mount and charge it that way. I may replace the phone with a black one though to go with the interior a bit more.
03-13-2016, 04:58 PM | #151 |
Rep 886
Or just put a ScanGauge under the headlight control.
Does it have a real 70s J.C.Whitney feel? Sure. However, no one but the driver can see it, the left 2 columns are visible to the driver all the time, it's not there in the middle of your dash acting as a magnet for some kid to break your window, and your wife won't spend any time chewing your ass for blocking her vent in the summertime. You're also not broadcasting an unprotected Bluetooth link into your ECU whenever your car is running.
Prior 40 years: 67 BelAir wagon / 68 LeMans Tempest / 70 Mustang Mach 1 / 72 El Dorado / 78 Corvette / 81 Subaru GL wagon 4WD / 83 s10 Blazer 4x4 / 85 Bronco 4x4 / 96 Bronco 4x4 / 04 Passat 4mo / 09 BMW 335xi Last edited by Zooks527; 03-13-2016 at 05:06 PM.. |
03-13-2016, 06:46 PM | #152 | |
Rep 1,752
03-13-2016, 07:04 PM | #153 | |
Rep 886
I've had BT OBD adapters for my cars for years. Very useful for logging and debugging. Nothing I'd ever leave plugged in all the time.
03-13-2016, 07:53 PM | #154 | ||
Rep 300
