03-11-2020, 01:30 AM | #89 |
Rep 5
But with this, I didn't feel any improvements.....
03-14-2020, 03:17 AM | #90 |
Rep 2
No coding necessary on 1 or 2 series H&K.
The 1 and 2 Series H&K is only analog and 3 series upwards is digital over most. Therefore the match 7 amp is working plug and play on 1 and 2 series H&K. Last edited by Gaumund; 03-21-2020 at 05:32 AM.. |
05-29-2020, 12:48 PM | #92 |
Rep 1,274
I bought the USB input card for the Audiotec-Fischer MATCH 7UP BMW amp! Btw, I bought the amp and USB card from Crutchfield. I had to run a 10 foot (later replaced with a 15 foot) long USB cable from the console to the amp. The hard part was getting the cable run under the carpet that's between the back of the console and the rear seat! PITA! Then I had to code the amp to accept the USB input as the primary input and buy a lightning to USB A connector adapter. The sound is fantastic.
11-28-2020, 06:18 PM | #93 |
Rep 16
Hey guys, just got the 7DSP for my 2020 X3 and was hoping I could bounce a few things off you.
1 - Can the plastic adapter for the power actually revive a 6 or 8 gauge power/ground? Cause it sure doesn't look like it. 2 - I have the 7dsp and an external sub amp (50 amp / 650w). Can I run a 100a fused 4 awg line to a block 4-5' away that splits it into two 8 awg lines for the positive? The 8 awg runs will be under 2' after they're split. Do I need a fused split or just a common 4 awg in / dual 8 awg out? 3 - can the ground from both subs be a 2' run of 8 awg run or does is have to be 4 awg because the positive is a 4 awg until it's spilt? The ground is a bare metal bolt almost directly beside the amps and would be simple to bolt both 8 awg ground leads to. Thanks for your help!!! |
11-28-2020, 10:09 PM | #94 | |
Rep 2,181
Does your 2020 X3 have iDrive 7?
11-29-2020, 08:25 AM | #95 |
Rep 16
01-23-2021, 12:58 PM | #96 |
Rep 50
Hello, I am considering getting one of these devices. I would want to have 3 different sound setups (one aligned for driver, another for front passenger, and one when car is full of people). Can anyone confirm that this device affords this capability?
01-23-2021, 01:14 PM | #97 | |
Rep 9
radio317.50 |
09-09-2021, 10:02 PM | #98 | |
Rep 52
Drives: 2009 335i
Where did you find the .apfx files? Looking to see if someone has an optimized one for stock speakers?
09-10-2021, 08:14 AM | #99 |
Rep 1,274
I replied to MarkUSVT via PM. Basically, my advice is to:
- load the AF tuning software on a laptop - buy a long USB cable to connect the tuning port to the laptop - set up the computer in the passenger seat - start playing music that you like to listen to - start tuning. Oh, and watch the tuning video on the AF website. |
