06-29-2014, 02:17 PM | #23 | |
Rep 31
07-01-2014, 05:25 PM | #24 |
Rep 42
So i got my tuner today, unfortunately my dumb a** cant get the thing installed. I got the first 2 patches connected but i cannot get the MAF senson (purple patch) to disconnect for the life of me. Any suggestions? Also is the blue sensor the one that does not need to be connected?
07-01-2014, 05:33 PM | #25 |
General
13512
Rep 19,011
My apology for being nosy. But I got bored at work.
@G228msport, I heard that Shelly BMW pretty cool about mods car. I always bring my F10 528i and F15 35i to New Century BMW. Both car running JB4 and to answer @nalinax question, I do have catless downpipe on my F10 and the JB4 clear the CEL. I was running Stage 1 on my F10 until I had a downpipe which throws CEL. When I was running Stage 1, I always uninstall it whenever I bring the car to the dealer since it was very easy. But since the Stage 2 is connected to the DME, it is a bit hard to take it off. Fortunately with the Stage 2, you can switch the map to map 0 and it becomes undetected. As for the recorded MAX boost. How often do you drive your car with Max boost under normal condition? Unless if you redline the engine all the time, then yes, you will record the Max boost +3psi gain from the tune. But, as G228msport mentioned, they will not look into your engine log for your AC problem, because it is not relevant. Piggyback is actually the safest and most reliable tune, because you are still relying on the stock ECU for the failsafe. Unlike the flashed tune, a mistake on the tune, it will fry the whole car and will most likely voiding the warranty (unless if you go with DINAN, which is overrated). Also, with piggyback, once you are done with it, you can always resell it or use it on another car with the same motor. For the installation, on the N20 tunes, that are 4 pairs of connector and 4 cables. On the Stage 1, you only use the brown cable connector pair, the rainbow color connector pair, and the purple cable connector pair. The blue cable connector pair is only used if you have the pneumatic boost solenoid. While on the Stage 2, you don't use the purple cable connector pair and same scenario on the blue cable connector pair. Then you have to connect the red wire to the positive and black to the ground. The rest of the 2 wires (green and brown) need to be connected to the CAN system. I hope I can help fellow members to answer some of the questions.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEAL!! | Akrapovic 10% Off SALE until Oct 15th 2024 MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
07-01-2014, 05:40 PM | #26 | |
Rep 42
07-01-2014, 05:53 PM | #27 | |
General
13512
Rep 19,011
I sell BMS products and install quite a few, so just sharing the experience.
07-01-2014, 06:32 PM | #28 | |
Rep 42
07-01-2014, 06:34 PM | #29 |
General
13512
Rep 19,011
No worries, glad to help.
Now go out and enjoy the car.
07-05-2014, 11:28 AM | #32 |
General
13512
Rep 19,011
It is "stand alone", but of course you can gain more with other mods, such as; catless downpipe, exhaust system, bigger intercooler, air intake (even though a lot of people saying that it didn't gives you any gain, but I believe gives you better air flow, better response), etc.
