07-13-2015, 06:37 PM | #815 | |
Rep 5,262
With 2TB you get for sure: - Paddle Shifters - Sport+ mode (you can mimic this in the regular auto by selecting sport mode and manually selecting DTC to on) - No automatic upshift in manual mode when DSC is off, DTC on, or sport+ selected - Automatic kickdown is deactivated when DSC is off, DTC is on, or sport+ is selected but it's already the default for the M235 unless you selected otherwise |
07-13-2015, 06:40 PM | #816 | |
Rep 5,262
07-13-2015, 06:58 PM | #817 | |
Rep 557
07-14-2015, 08:08 PM | #819 |
Rep 887
Drives: Enzo F23 228i
I'm just about done, but when you first start the car, I still have a seatbelt warning in the cluster...did I miss this setting?
07-14-2015, 08:22 PM | #820 |
Rep 5,262
07-14-2015, 09:15 PM | #821 |
Rep 887
SeatBeltReminder_SBR_Fahrer nicht_aktiv
SeatBeltReminder_SBR_Beifahrer nicht_aktiv Gurtzustandsanzeige_Fahrer_GWF_GZA_FA nicht_aktiv Gurtzustandsanzeige_Beifahrer_GWF_GZA_BF nicht_aktiv SBR_PreWarning_Fahrer nicht_aktiv GWF_SBR_WARNDAUER wert_01 I still have the warning symbol to the left of the cluster and also the text on the right. I also just checked the video in motion and that doesn't work either so I'm double checking things right now. |
07-14-2015, 09:27 PM | #822 | |
Rep 5,262
Gurtzustandsanzeige_Fahrer_GWF_GZA_FA should do it... can you read the values after coding? |
07-14-2015, 09:38 PM | #823 |
Rep 887
07-14-2015, 11:01 PM | #824 |
Rep 887
So I reset everything and started back with removing the seat belt warnings and the DVD in motion. I still have the Dashboard Icon on the left and the initial warning banner on the right when the car first starts. Maybe everyone does and I'm asking too much, I don't get warnings if the belt comes off (icon still comes on) so in a way that's a win.
Additionally, I was rocking out to some Bad Company (HD Radio) and switched in a dvd (Fleetwood Mac Live) and all of a sudden my sound went to crap...sounded like a $10 sony radio. Switched back to Bad Company and they sounded like crap. No matter what I did to the tone I couldn't get the system to sound good again. Blew everything away one more time with no luck on the sound. Unless my ears got plugged from the weather, it sounds like I've lost all my mid-bass and power. Will see what happens in the morning. I didn't play with the settings, but I did find a place where there are 6 or 7 different "tunings" for the radio. I've gotten everything to work at one time or another, just not together yet...and forget folding mirrors on a cab... |
07-14-2015, 11:04 PM | #825 | |
Rep 5,262
07-15-2015, 09:16 AM | #826 |
Rep 887
Nope, the icons are still on the cluster, but the stereo sounds normal again. I'll take a picture at lunch of what I'm seeing.
07-15-2015, 10:40 AM | #827 |
Rep 244
I have the same problem. The icon is still on on the cluster. But I do not care too much about it anymore. BTW, my car build date is 5/11/15.
07-15-2015, 10:45 AM | #828 |
Rep 5,262
07-15-2015, 02:24 PM | #829 |
Rep 887
Yep, I've moved on. One thing I did find was a key that has several different versions of acoustical settings, or what I believe to be acoustical settings...going to change that and see what it does.
07-15-2015, 09:05 PM | #830 |
Rep 887
Re-coded everything tonight...and I can confirm that the TPMS now shows tire pressure and temp with the following settings:
HU_NBT2 3001 RDC_SAFETY aktiv HU_NBT2 3001 RDC_DRUCK_TEMP druck_and_temperatur I also set the parallel phones up, but it makes no sense as it will still only connect to one at a time. Not sure what the point is with this mod. Still trying to figure out how to set the European flashers... |
07-15-2015, 09:13 PM | #831 | |
Rep 5,262
By adding the ability to simultaneously connect two mobile devices to the vehicle, customers can receive calls on both their private and work phone. They can select one of the mobile phones to stream music over Bluetooth, or they can even pair a third device for playing music." what flashers ? |
07-15-2015, 09:30 PM | #832 | |
Rep 887
As for the flashers, when you activate your emergency flashers, in the US the just go blink...blink...blink, while the European flashers go blink.blink...blink.blink. Kinda like that...it's different. |
07-15-2015, 09:37 PM | #833 | |
Rep 5,262
ah.. you mean Emergency brake light mode Yes FEM_BODY 3060 ESS_AKTIVIERBARER_AUSGANG in US it actually uses the fog lights on the back to make the brake light area bigger.... EU they flash this is how the EU mode looks like, i have it coded, it works |
07-15-2015, 09:44 PM | #834 | |
Rep 887
07-15-2015, 10:04 PM | #835 | |
Rep 5,262
didn't know that was possible... i think its only possible on the e90 chassis like this? Last edited by pikcachu; 07-15-2015 at 10:12 PM.. |
07-15-2015, 10:21 PM | #836 |
Rep 887
