2Addicts | BMW 2-Series forum Technical Topics Cosmetic and Lighting Modifications Inner Headlight
      05-13-2014, 02:48 PM   #1
Broose
Inner Headlight
On the HID/LED headlights the inboard inside light (inside the ring) isn't used. Anyone figured a use for that spot?
Name:  headlight  2014-BMW-M235i-headlight.jpg
      12-23-2014, 10:31 AM   #2
arts711
arts711's Avatar
27
Drives: m235i
*bump*
Does anyone have any idea on this? I'm curious as well as i noticed the other day behind a friend's car's reflection that switching to high beams to not turn the other interior unit on, only the outer unit.
      12-23-2014, 11:01 AM   #3
DanG
DanG's Avatar
Drives: 2018 M2 AW DCT
2018 BMW M2  [7.68]
The inner unit is only used as a day time running light. High and low beam both come from the outer unit. BMWs have been that way for several years.
      12-23-2014, 12:34 PM   #4
ciwhamc
Drives: M235i Alpine White
2014 BMW M235i  [0.00]
No daytime running lights are the Angel eyes
      12-23-2014, 12:45 PM   #5
WingZeroX5
WingZeroX5's Avatar
Drives: F80 / F30
they should turn on depending on which direction you are signaling, to illuminate the intended turning direction
      12-23-2014, 09:49 PM   #6
arts711
arts711's Avatar
27
Drives: m235i
i may be missing this, is there anyone can get a picture of this in action?
      12-27-2014, 03:24 AM   #7
G4Z808
G4Z808's Avatar
30
Drives: not yet
the inner two projectors defiantly dont turn on for anything on my car. Im wondering is there anything at all behind those lens ? is it actually a projector or just a dummy lens
      12-27-2014, 04:35 AM   #8
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
It could be like on the e82's.... The inner headlight lamp will light up when the headlight switch is in AUTO position and...
* you turn the steering wheel(in that direction of that light)...
* you put the car in reverse BOTH inner lamps will light up
* DRL (IF you have setup the system in the BC)
for more helpful videos check out BMW NA's site of videos...
http://www.bmwusa.com/Standard/Conte...modelcode=1022
      12-27-2014, 04:51 AM   #9
G4Z808
G4Z808's Avatar
30
Drives: not yet
Nope only the outer projectors move when turning \
Does not turn on in reverse
The DRL is the corona rings
But this is just for a NA Spec car, wonder if its different for different markets
      12-27-2014, 05:02 AM   #10
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
Your headlight switch is in AUTO right> ? It makes a difference.
      12-27-2014, 05:33 AM   #11
G4Z808
G4Z808's Avatar
30
Drives: not yet
Correct, in AUTO
      12-31-2014, 08:49 PM   #12
Supernaut
Little Deuce Coupe
Supernaut's Avatar
Drives: SO M2C
I'm in the process of ordering, so while reviewing the brochure I ran across this description of what they should do.
      01-01-2015, 03:14 AM   #13
G4Z808
G4Z808's Avatar
30
Drives: not yet
headlights already do this without utilizing the inner lens, when turning the wheel the outer lens swivel in the direction of your turn. the inner lens still serve no purpose
      01-01-2015, 12:16 PM   #14
pikcachu
pikcachu's Avatar
1403
Drives: M235i (F22 Red angel)
ah.... now it get what cornering wizard is...
looks like it comes disabled on the 2...
Cornering wizard FEM_BODY 3110 ASP_ABA_AKTIVIERUNG aktiv Activate cornering assistant
might do some coding and give it a try see if the light comes on with the blinker
      01-01-2015, 01:55 PM   #15
Artemis
Moderator
Artemis's Avatar
29464
Drives: BMW M2 Competition
For the record: the difference between Adaptive Headlights and Cornering Lights:
"Adaptive Headlights
The Adaptive Headlights cast their beam in the direction of the curve and ensure better visibility and more safety during night drives on winding roads.
Sensors measure speed, steering angle and yaw (degree of rotation around the vertical axis). Based on this information, small electric motors turn the headlights left or right so the beam falls on the road ahead, guiding you into the bend.
Headlight beam throw control (a model-specific function) means the front headlights are raised at high speeds and lowered at slower speeds, which results in a wider beam for inner-city driving.
The adaptive headlight range control (a model-specific function) takes into consideration the vertical curve of the road. The headlight beam throw control is lowered when driving over a knoll and raised when the vehicle is in a dip.
The result: every single curve is illuminated and the oncoming traffic isn’t dazzled unnecessarily. Driving at night is even safer, particularly when visibility is poor.
Adaptive Headlights are only active when the vehicle is pulling away. They stay switched off when the BMW is in reverse and when the steering wheel is turned to the left while the vehicle is stationary (e.g. when pulling out of a parallel parking space to avoid dazzling oncoming traffic).
Adaptive Headlights are complemented by cornering lights. These are automatically activated at speeds of up to 70 km/h and improve visibility in the immediate vicinity of the vehicle, which is useful when driving along hairpin bends, turning or parking."
(http://www.bmw.com/com/en/insights/t...eadlights.html)
"Cornering lights
Cornering lights provide additional illumination of the area to the side of the vehicle, making night-time parking and turning safer.
Cornering lights compliment the functionality of Adaptive Headlights. While Adaptive Headlights provide superior illumination of curves when driving at normal speeds, cornering lights give you better lighting when carrying out low-speed manoeuvres: parking, turning into a driveway, u-turns and taking extremely winding roads, for example.
To provide this additional light, the fog lamps are fitted with integrated swivelling reflectors; alternatively, the headlights are equipped with an additional lamp. When the indicator is activated at speeds below 40 km/h, these lights illuminate an area to the side of the vehicle, up to 80° of the direction of travel.
After the corner is taken, the cornering lights dim and extinguish automatically. Cornering lights also facilitate safe reversing: when reverse gear is selected, both the left and right lights illuminate the area around the vehicle."
(http://www.bmw.com/com/en/insights/t...ng_lights.html)
///M is art Artemis
      01-01-2015, 02:12 PM   #16
Artemis
Moderator
Artemis's Avatar
29464
The lens inside the inner corona of the M235i picture shown by OP (first post) seems to be different.
Here's the headlight cluster of my 1M (featuring Adaptive Headlights and cornering lights).
///M is art Artemis
      01-01-2015, 06:42 PM   #17
G4Z808
G4Z808's Avatar
30
Drives: not yet
already tried coding that on, didn't change anything. probably due to the m235i not having foglights . the inner lens don't look like those on the 1M, seems they really are just dummy lens. i still wonder if there is any projector bowl behind them that will accept a bulb
      01-01-2015, 07:59 PM   #18
pikcachu
pikcachu's Avatar
1403
ah ok....
      01-02-2015, 10:46 PM   #19
arts711
arts711's Avatar
27
Drives: m235i
i tried as well, didn't work with the cornering wizard active and lights on auto. Odd though because if you pop the hood, there are two heat sinks....
      01-02-2015, 11:07 PM   #20
G4Z808
G4Z808's Avatar
30
Drives: not yet
I think the heat sinks might be for the LED's in the corona rings, just guessing though. Havent seen a HID light that needs external heatsinks
      01-03-2015, 05:38 AM   #21
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
Yes, those heat sinks are for the LED AE's. IF you lookk in RealOEM.com it clearly shows that.
http://www.realoem.com/bmw/showparts...=63&fg=05&hl=4
      01-03-2015, 05:51 AM   #22
G4Z808
G4Z808's Avatar
30
Drives: not yet
Thanks for the link. looks like the inner lens is really just a dummy. oh well
