2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum Edmunds tests the 228i
      05-12-2014, 08:42 AM   #1
basiluf
Drives: 2019 S450 2018 S90
BIMMERPOST
     Featured on BIMMERPOST.com
http://www.edmunds.com/bmw/2-series/...oad-test1.html
Not bad test numbers from conservative Edmunds.
Thanks to a nearly perfect 50/50 weight distribution and excellent outward visibility, the 228i playfully bounds from corner to corner with solid athleticism and instills very high levels of driver confidence. Steering is quick with appropriate effort, though feedback at the limit could be better. Considering the 228i's 3,344-pound curb weight, the 2.0-liter four-cylinder twin-turbo engine provides more than enough power to entertain even jaded pilots.
2014 BMW 228i
At our test track the 240 horsepower and 255 pound-feet of torque propelled the rear-wheel-drive 228i to 60 mph in a very quick 5.1 seconds. The eight-speed automatic capitalizes on all available power with well-spaced gears and quick, smooth shifts. Gearchanges can be commanded by the driver through wheel-mounted paddles, which work as well as an automated dual-clutch transmission. Even better, the traditional automatic doesn't exhibit the low-speed lurches from which many automated manual transmissions suffer.
The $650 M Sport brakes repeatedly brought the 228i to a stop from 60 mph in a very short 111 feet, all while remaining very composed and controllable.
Why Should You Consider This Car?
The execution of the 2014 BMW 228i is simply impressive. The 228i makes few compromises and you can tailor one to your taste — whether it favors luxury or performance. As potent a performer as the 228i is, it weakens the case for upgrading to the M235i.
Why Should You Think Twice About This Car?
Rear-seat space is the main drawback to the BMW 228i. It holds two adults and their luggage comfortably, but not much else. In its defense, competitors suffer the same fate to varying degrees. We also couldn't replicate the EPA's fuel economy ratings, but as manufacturers are so fond of saying, "Your mileage may vary."
'14 M235i(current)ED
'11 E93 M3(past)ED
'08 E90 328i(past)Local
      05-12-2014, 09:09 AM   #2
Uridian
Uridian's Avatar
42
Drives: E36 M3, 228i M Sport
5.1 seconds 0-60, huh? Didn't the other test show 4.9? Both significantly better than the advertised 5.4.
      05-12-2014, 09:13 AM   #3
bimmerfile
bimmerfile's Avatar
621
Drives: 2019 BMW X2 F39
The 228i is scoring about the same 0 - 60 times as the outgoing 135i.
In the past week I've read test times of 4.9 sec and 5.1 seconds with the auto tranny.
Dunno how they did that with 50 less HP and 42 less ft lb torque than the 135i, but they did it.
Those clever Germans.
2019 X2
      05-12-2014, 09:16 AM   #4
Uridian
Uridian's Avatar
42
It's all about that launch control and close gearing of the 8AT. If I can break 6 seconds in my 6MT I'm satisfied.
      05-12-2014, 09:18 AM   #5
scrape1
Drives: '14 228i M Sport, '04 X3 3.0i
I wish somebody reputable would test the 6MT 228i. To me it doesn't feel as quick as the auto.
      05-12-2014, 09:22 AM   #6
ska///235i
***** noob
ska///235i's Avatar
2006 325xi  [0.00]
2014 BMW 228i
Not bad
2006 325xi (Sold)
2014 M235I (Current)
2015 428xi Gran Coupe (STB)
      05-12-2014, 09:52 AM   #7
basiluf
I don't think it is. The 435i 6MT was tested by C&D @ 5.2 seconds to 60 mph, and that's compared to 4.9 seconds for the 228i AT.
'11 E93 M3(past)ED
      05-12-2014, 10:06 AM   #8
chris719
Drives: '08 M Roadster
0-60 is not that meaningful, there will be a huge difference in power in reality when you aren't doing a launch and stopping at 60.
      05-12-2014, 10:23 AM   #9
phoenixbmwlife
phoenixbmwlife's Avatar
Drives: M235i & G30 540i
2014 BMW/M235i  [0.00]
Wow and they are not even using 1 ft rollout as I thought they were. I know many car magazines do that but i just read they dont. For those of you interested in what roll out is there is an article about it on edmunds.com about how they test cars.
http://www.edmunds.com/car-reviews/f...nd-trucks.html
Follow me on Insta
https://www.instagram.com/bmwm_life_/
https://www.instagram.com/autogiftua/
https://www.instagram.com/phoenixbmwlife/
      05-12-2014, 10:37 AM   #10
basiluf
Yup, edmunds times are consistently slower than other car review sites since they don't use the rollout. That's why these results are quite impressive!
'11 E93 M3(past)ED
      05-13-2014, 01:47 AM   #11
FoxCrane
FoxCrane's Avatar
Drives: Blue
Thanks for all the context above, guys!
      05-13-2014, 07:13 AM   #12
Pyrat 2
Pyrat 2's Avatar
Drives: Rapidly from A to B
'Twin turbo' and an 'auto manual' transmission??? I know it doesn't have a twin turbo and thought the trans was not a dct?
'07 Z4MR '22 GT4 '18 GT3 '16 GT4, '16 M2, '14 X1, '13 135is, '06 330i, '03 323 Ci, '01 330i, '99 M3 (RIP), '96 318is, some non-BMWs
      05-13-2014, 07:23 AM   #13
snaimpally
Drives: 2011 335i MT
2011 BMW 335i  [0.00]
I test drove the new AT 228i at the dealership (before I had purchased my 335i) and it was a blast. The compact size of the car, the gearing, and the suspension make it a lot of fun to drive. The M235i hadn't arrived yet so I hadn't driven it but I thought the 228i would be sufficient. Plus, with a turbo engine, its easy enough to change a few components, add a new tune, and get a lot more power.
PTF Map, Pure Turbo Stage 1, GFB DV+, Mfactory LSD, AA FMIC, B12 Pro Kit, M3 FCA, AR DP and
Dynavin N6, Mosconi AS100.4, AS100.4, AS200.2, Micro Precision tweeters & woofers, Esotar2 1200
      05-13-2014, 07:55 AM   #14
Bahn360Photo
Fitness Gene
Bahn360Photo's Avatar
Drives: 2018 M4
2006 bmw m5  [10.00]
2016 bmw z4 35is  [8.33]
2000 bmw m5  [10.00]
2018 BMW M4  [10.00]
1987 BMW 325 Conver ...  [10.00]
wonder how close m2 will be to M235 in price/performance
Effective 11 Min Home Workouts?????
No equipment?????
20 years of experience
Spartan Race winner
PROtrainer!
Click the link??
https://www.youtube.com/c/FitnessGene
      05-13-2014, 08:28 AM   #15
i001947
i001947's Avatar
26
Drives: '13 E92 M3
+1
      05-13-2014, 08:34 AM   #16
Falafel Combo
Drives: X5 xDrive50i
MT will never be as quick as the new ZF 8 speed auto. My 8AT f30 was significantly faster than my current 6MT f30. My MT almost feels like a de-tuned version of the auto.
      05-13-2014, 08:37 AM   #17
Fraggy
Fraggy's Avatar
Drives: 2016 M3
I drove a 228 and it was awesome. The next day I bought a 428, only because I need a tad more room inside. If I could have been happy with the smaller size, the 228 was more than enough for me.
2016 Alpine White M3 (gone)
2019 Alfa Romeo Guilia (Totaled)
2020 Car-less 😁 (no more)
2020 M340
      05-13-2014, 08:48 AM   #18
bradleyland
TIM YOYO
Drives: 2013 M3
EDIT: I'm not sure where you read 'auto manual', but as other posters have pointed out, I don't see it.
The 228i has the ZF sourced 8-speed automatic with a torque converter (same as every other non-DCT equipped BMW). Edmunds, just like the rest of the automotive press, are too lazy and bored with their jobs to get the details right.
His: 2019 R1250GS - Black
Hers: 2013 X3 28i - N20 Mineral Silver / Sand Beige / Premium, Tech
Past: 2013 ///M3 - Interlagos Blue Black M-DCT
Past: 2010 135i - TiAg Coral Red 6MT ///M-Sport
      05-13-2014, 08:57 AM   #19
scrape1
Yes, that is my impression as well, after comparing the 228i auto I test drove with my 288i 6MT. Although I think mostly it's because the auto is quicker off the line. If I do an aggressive clutch engagement around 3500 RPM as opposed to a more typical 1500 rpm, she pulls pretty hard. I think the MT can come close to matching the 8 speed 0-60, but you have to give it a pretty hard launch. For obvious reasons, I don't like doing that to my own car.
      05-13-2014, 08:57 AM   #20
overcoil
Drives: M235i 6spd
The Edmunds article does say it has a traditional auto - am I missing the mistake in the article ?
      05-13-2014, 09:27 AM   #21
chiefneil
Drives: 2014 335i M-Sport
Directly from the article:
"Gearchanges can be commanded by the driver through wheel-mounted paddles, which work as well as an automated dual-clutch transmission. Even better, the traditional automatic doesn't exhibit the low-speed lurches from which many automated manual transmissions suffer."
They did goof and call it a twin-turbo though.
      05-13-2014, 10:43 AM   #22
unintelligible
Computer Janitor
unintelligible's Avatar
Drives: '12 F30 328i
Yeah agreed and I think this is the same for the F30. I have a 6MT 328i and had a 8AT loaner a couple weeks ago and the auto felt like it had another 50 hp on my car. These motors really, really love the auto.
2012 328i Sport Line 6MT (Turned In)
2015 Ford Mustang GT Premium (Current)
