2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum BMW M Performance LSD for M235i, 335i, 435i Arrives. Pricing and technical FAQ inside
      02-22-2016, 03:44 PM   #89
BarryJI
BarryJI's Avatar
Drives: 2015 BMW 228i M Sport
Not doing it at that price but just out of curiosity: why is this for the M235 only and not the 228?
2015 BMW 228i M Sport w/Track Handling Package
DAP | Lighting | Premium | Tech
DINANTRONICS Performance Tuner Stage 1 | DINAN Shockware | DINAN Free Flow Exhaust | DINAN Performance Spring Set + Ride Quality and Handling Kit
      02-22-2016, 04:21 PM   #90
simoneves
Drives: '16 228i DSB/THP/6MT
I think I remember reading in a different thread that the LSD is only available in one ratio, and the 228 diff is a different ratio, so would change the gearing. But maybe I made that up.
      03-21-2016, 03:54 PM   #91
sgmpw
sgmpw's Avatar
Drives: M240i
2016+ include LSD?
I'm about to order either the '16 M235i or a '17 M240i (all M2's sold out) but the LSD was a key consideration.
My 'guy' sent the attached as evidence that the LSD is now included (hence no longer on the available options list).
Any comments or disputes or validation?
Thx.
      03-21-2016, 05:22 PM   #92
AlpsRider
AlpsRider's Avatar
2865
Drives: M2 Competition, LBB, 6MT
Thx.
I think this is what is meant:
"Electronic limited slip differential system uses Anti-lock brake sensors and hardware to electronically monitor wheel speed. If one of the wheels on an axle is rotating faster, computer briefly applies brakes to it, slowing the spinning wheel down and causing the wheel on the opposite end of an open differential to start spinning and gain traction. This is an opposite to the anti-lock brake application, when a locked wheel is electronically released."
      03-21-2016, 06:10 PM   #93
OpenAir
OpenAir's Avatar
Drives: Enzo F23 228i
2015 BMW 228i  [0.00]
Originally Posted by F30.M View Post
Is this xDrive compatible?
I asked my CA today, who is really into this stuff, and he said no to xDrive. He did say that it will work in the 228 as it has the same ratio as the 235.
      03-21-2016, 07:36 PM   #94
sgmpw
sgmpw's Avatar
Drives: M240i
Based on this definition I think you are referring to a different type - 'brake actuated LSD' vs what the attachment lists as electro-mechanical.
      03-21-2016, 07:55 PM   #95
multarnc
SMSgt
multarnc's Avatar
Drives: 2016 M235i
2016 BMW M235i  [0.00]
When I ordered my 2016 M235, I was told that it has an open differential. the LSD was on the options list.
2016 BMW M235i
Mods: Dinan Stage 3, Dinan Intercooler, Dinan Intake, M Performance Exhaust w/CF Tips, M Front Splitter, M Rear Diffusor, M CF Spoiler
      03-21-2016, 08:00 PM   #96
Zooks527
The xDrive uses a different rear differential than the RWD, with a welded ring gear instead of bolted. You can go with an LSD from Quaife or Wavetrac. Cost to put one into an xDrive ends up being about the same as the BMW LSD in the RWD. On the flip side, a Wavetrac LSD in the RWD is about a third of the price of the BMW one.
      03-21-2016, 08:15 PM   #97
multarnc
SMSgt
multarnc's Avatar
Drives: 2016 M235i
I can get the BMW LSD for about 2k + install. Worth it to not have any warranty issues.
2016 BMW M235i
      03-21-2016, 10:37 PM   #98
Sindarin
Drives: BMW
No. The M235i rear differential has a 3.08 ratio while the 228i has a 3.91 ratio.
      03-22-2016, 12:17 AM   #99
EternalVendetta
Drives: '16 M235i 6MT / '19 Model 3 SR
I was considering the OEM LSD at $2K + labor costs, but getting an LSD for 33% of that cost is mighty tempting. Any details?
2016 M235i | Estoril Blue | Coral Red | 6MT
Tech | Cold Weather | Driver Assistance | HK
M Perf. Gear Shift Knob, Parking Brake, Pedals, Carbon Interior
M Perf. Black Grilles | CF Mirror Caps, Rear Spoiler, Rear Diffuser | Lightweight Front Lip Spoiler | M Perf. Exhaust
      03-22-2016, 11:44 AM   #100
AlpsRider
AlpsRider's Avatar
2865
I don't believe that the $3,000. M performance LSD is included in the current M235. If your "guy" is telling you that, I'd investigate further.
      03-24-2016, 04:22 PM   #101
mdputnam
mdputnam's Avatar
289
Thx.
I don't believe the Electro-mechanical limited slip differential is the M Performance Limited Slip Differential for the M235i for the following three reasons:
First line of evidence, Google "BMW electro mechanical LSD" and you'll find references by BMW that use this terminology to describe their standard open differential that use the brakes for the LS function.
Second line of evidence, the document you link to (Reference PQ05105060) was released on 01-05-16. The port install M Performance Limited Slip Differential option was discontinued at midnight on Sunday 2-28-2016. Yes, I was up at midnight on a Sunday playing with the "Build Your Own" function when to my surprise it disappeared after reloading the web page at 12:30.
Third line of evidence, when I ordered my car on Monday 2-29-2016 the SA was unable to enter the order code for the port install M Performance Limited Slip Differential. After checking with the dealership's manager and the dealership manager talking to the regional manager; the word was the Port Install M Performance Limited Slip Differential Option was discontinued. And, that the M Performance Limited Slip Differential is now only offered as a dealer installed option.
And my fourth line of evidence, (yes I know I said only three) but... my brand new M Performance Limited Slip Differential arrived Wednesday and is sitting on my workbench in the garage, waiting for the arrival of the car next month. There is nary an "electro" connection on the thing.
      03-24-2016, 05:51 PM   #102
Liquidpaper
Liquidpaper's Avatar
Drives: '15 M235i
2015 BMW M235i  [0.00]
This is accurate. When I ordered my car in the summer of 2014, I did a ton of research on whether the car actually had a real, mechanical LSD or not. I found out that it has brake actuated, electronic limited slip functionality.
I ended up getting a custom rear end (different ratios, LS functionality) built, and when it was put in, there was no electronic hookup for the differential -- it is a purely mechanical unit, unlike the M2/3/4/5, etc, which have a LSD that is controlled by, among other things, the ECU.
      03-24-2016, 06:28 PM   #103
sgmpw
sgmpw's Avatar
Drives: M240i
uh....that's pretty compelling evidence
I kind of thought it was too good to be true. I'm on the list to order an M240i but told my contact this would be a key question I need answered. Seems I already have it. Thx. Sigh.
      03-24-2016, 08:03 PM   #104
drexplode
drexplode's Avatar
1785
Drives: G26 i4x
Anyone know if the LSD via PIA is available for M235i? I was told by two dealers "not in the system".
      03-25-2016, 04:32 AM   #105
Zooks527
If you feel that paying $1400 more than a $600 part in order to warranty it is financially advantageous, go for it. I will note that you're far more likely to have warranty issues from the Dinan piggyback than a different rear differential.
      03-25-2016, 04:43 AM   #106
Zooks527
I had some email discussions with the folks at Wavetrac a month or so ago. They offer a drop-in pumpkin for the MT RWD 228i for $700 and for the RWD M235i for $600 (see http://www.wavetrac.net/application.htm). Both of these apparently have bolted ring gears.
For the xDrive M235, they have one that's appropriate (list $1300), but as the xDrive models use a welded ring gear, the existing unit needs to be sent to them for removal of the OEM gear and welding it onto a mount for their unit (with an additional $600 shop charge). That moved my doing the LSD from the "this summer while I'm out of town on vacation" list onto the "maybe" list, mostly due to the turnaround time sending the differential to them.
There's a bunch of BMW folks using Wavetrac LSDs. CalWaterBoy in the E90 forum over at the other guys has had one in his 335i convertible for at least 4 or 5 years with no problems and swears by it.
      03-25-2016, 08:22 AM   #107
doccyber
doccyber's Avatar
Drives: %D0%97%D0%B0%D1%81%D1%82%D0%B0
Does LSD offer any advantage for every day road use?
      03-25-2016, 08:52 AM   #108
Zooks527
Certainly useful in wet, snowy, or icy conditions. Keeps the back end planted, will prevent traction control from kicking in if you're doing something like coming out of a parking lot and doing a 90 degree left turn across traffic and so on.
Normal driving on dry roads? Not much advantage, if any.
WillOs7.00
      06-28-2016, 01:00 AM   #109
devil84
United Kingdom
116
Drives: G30
i am picking one of these up. Just making sure I have everything i need. Basically just the LSD unit given to me. Anything else that should come with it?
Anything else I should look out for? anyone have a PDF version of the installation instructions?
      07-24-2016, 11:32 AM   #110
stylinexpat
stylinexpat's Avatar
415
Drives:
Originally Posted by Bear From Jax View Post
3k for 30% lock? No thanks. I'd wait until Wavetrack or someone else comes out with a better one for the same price.
$2-3K is about right but I know someone who makes a much better LSD if you need one.
