05-04-2014, 05:25 PM | #1 |
Rep 269
Spacer fitment
I have a spare set of Macht Schnell 10mm spacers I just tried to put on my 228i rear, but to my chagrin, they don't fit! The hub ring sticks out too far so the spacer won't sit flush against the face of the rotor. Some cross referencing shows that the 228i rear hub is the same as the F30 328i hub, which they claim to fit. I'm curious if the F30 guys have had any trouble getting these spacers to fit properly. Anyone else tried to fit spacers yet?
***this is a cross post from the brakes section, so please feel free to delete that one, since I can't*** And, since posting in the wrong section, I found this on the F30 forums: "10mm will work in the front, but not the rears. The rear hub lip is longer than the fronts so minimum rear is 13mm." So that answers that. |
06-29-2014, 10:15 AM | #5 |
Rep 2,363
Wanted to give some feedback. Actually having spacers installed at the moment 12.5 front and 15 rear and we hit this same issue with the rear. What we did was remove the dust cap before putting the spacer on, and then put a dot of super glue on the side of the dust cap and put it directly on the spacer itself and we were able to get it on.
Follow my builds:
06-29-2014, 01:34 PM | #7 |
Rep 269
15mm should be fine for the rear. I'd also be very hesitant to break the dust cap seal like that. Sticking it on the spacer isn't a seal. Specially so since you're re-sealing with a dab of superglue instead of proper sealant. Also, did you buy a new dust cap or try to reuse the old one? In my experience, there's no way I'd try to reuse one since I have to mangle the lip so much trying to remove it.
Sounds sketchy to me. |
