2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum Rumor: BMW M2 and 2-series Designed to Fit F30/F32 M3 Parts
      08-02-2011, 08:27 PM   #45
kardboard
kardboard's Avatar
Drives: 2006 M3, 2010 135i, 2004 WRX
2010 135i  [3.00]
2004 WRX  [4.00]
Originally Posted by e46e92love View Post
Riddle me this, if we went back in time and told former heads of ///M division and its senior engineers that future ///Ms would share engines almost exactly the same as the productions series (current 1M) and many parts from other ///Ms (current 1M & ///M3 as well as future) what do you think their reaction would be?
Make the M2 special in its own way, just as the ///M5 and ///M3 are both special in their own ways.
Cheers,
e46e92
2006 M3: Individual Blue Onyx on Black. MT
      08-03-2011, 09:47 AM   #46
Lynn_228i
AW BMW 228i with Black Dakota Leather Seats
Lynn_228i's Avatar
Drives: BMW 228i
I hope they still keep the 1-series in the USA the way it is
I am hoping they still keep the 1-series in the USA with the way it is equipped and maybe just add a back-up camera since I do not want a bigger or more roomy car being that I am petite and I do not need more power than the 128i coupe which is perfect for me.
      08-03-2011, 10:07 AM   #47
Muffnbluff
Redline Addict
Muffnbluff's Avatar
14
Drives: '14 BMW 335 xdrive
Originally Posted by kardboard View Post
Twin turbo'ing will solve both your power issues and lag issues. I expect a 4 cylinder twin turbo set up with M3 suspension, dct, brakes, and similar CFRP panels such as the hood, roof, and trim.
Seems like future Ms will be about choosing a motor first then a style as they will all be fairly similiar (1M/M3) (X5M/X6M) (M5/M6)
I can only imagine how small the turbos would be on a twin turbo I4 setup. The turbos wouldn't do anything past 5,000 RPM.
      08-03-2011, 10:22 AM   #48
hector
Drives: 2007 e92 335i, 2008 128i cpe.
Originally Posted by mkoesel View Post
...I also can't see the US getting ...or whatever other FWD models they come up with either...
are you including in that prediction the Z2 roadster and/or coupe that are also expected to be fwd?
      08-03-2011, 10:37 AM   #49
mkoesel
Moderator
Drives: 2015 SO/CSAT F80 M3
No, I really just meant the 1 series itself with that comment. A small roadster has a better chance of making it to the US than a small hatchback. However, I would not necessarily say that it will come here for sure either.
A gen-u-ine BMW eff-eight-zero with them tandem clutches in the transmission and that dad gum sun roof on the top-a da cawr.
      08-03-2011, 05:30 PM   #50
Kayani_1
Kayani_1's Avatar
Drives: BMW E92/E60
Bring it on baby
nickname"BAD 3",MHD E85 tune,RennArt catback non-resonated exhaust,VRSF Downpipes, VRSF 7"FMIC,VRSF stock side inlets,SSQV BOV,ECS CP,M-performance alcantara steering,retrofit M3 paddle shifters,Alpina B3 tranny flash,AFE power seal CAI,LED angels,ST Coilovers,M3 upper/lower control arms,E93 M3 Front Swaybar ,235/35/19x9 ,275/30/19x9.5. M sport bumpers, CF diffuser. When in doubt..flat out.
      09-23-2011, 11:20 PM   #51
RPM90
Drives: 340i M-sport AT
Originally Posted by SCOTT26 View Post
If you are meaning commonality then you are on the right track as the F20 and F30 share the same modular matrix , so this will feature within the 2er and 4er Coupes too.
As of the next generation M1 or M2? It will stick to it's basic formula but will have scope for further enhancement. But , especially for weight purposes the car will resort to a four cylinder Turbo. The power output will stick closely to around todays car 340HP allowing the M3 to have a considerable gap with around over 100HP with it's all new six cylinder engine.
If that's true then it seems the new 2 series coupe won't have any added power than the current models.
The current 135i has 300/300. I would expect that a NEW replacement for this car would have at least a bit more power, say 320/320.
If that happens, then an M2 with only 340/340 isn't so special.
The new 2.0T engine has more power and better MPG than the current NA 3.0 engine. That's a solid replacement.
What's the replacement or refinement for the N55?
It should be a bit more power and a bit better MPG.
Then, what goes into an M2?
I say, a higher boosted N55 with the M handling and styling bits.
I just can't see an M2 with a 2.0T for that kind of money.
Not saying it won't happen, just saying, I don't like the idea.
Or, maybe BMW will do what Audi did with the A4.
They cut out the V6 altogether.
You have 2 choices. A4 2.0T or the S4. They loaded up the S4 with options and the price is right for those who want more performance.
Maybe the next 2 coupe will only be offered with a 2.0T, and if you want higher performance you'll have to go with the M2 with an N55.
Could be good, but the price needs to be in check
      09-24-2011, 05:52 AM   #52
GeeRam
GeeRam's Avatar
United Kingdom
118
Drives: X5 40d SE
It will be special if they can make it 300+kg lighter
It's power to weight ratio that's important, not just the headline power output.
2017 X5 4.0dSE ~ Atlas Cedar:Ind.Amaro Brown Merino&Piano Blk, Sport Auto, DHP, Comfort seats, Cold weather pack, HK audio, Electric towbar, Sun protection glass
SOLD - 2011 135i M-Sport Coupe DCT ~ The only Bluewater:Coral Red E82 135i in the UK.
The Weekend Toy1932 Ford 3 window Coupe, all steel, with a 383 SBC, a Tremec and a Quickchange
      09-24-2011, 06:02 PM   #53
RPM90
Yes, I'm very aware that power to weight is more important than raw numbers.
But until we see officially that the new 2 coupe will be lighter, we can't call it yet.
Also, 140lbs less is ok but it ain't that great.
The current 1 is too heavy as is given it's smaller size.
Current 1 series is about that much lighter than the 3 series. They use the same engine and the 1 is not that much faster, and the 3 with sport handles better and has a better ride, even though it's heavier.
A 150lb weight decrease with about a 25/25 power bump will make for a much more compelling 'next gen' 1/2 series.
      09-25-2011, 06:43 AM   #54
GeeRam
GeeRam's Avatar
United Kingdom
118
Drives: X5 40d SE
140lbs....... ??
      10-08-2011, 04:27 PM   #55
Iron Man
Iron Man's Avatar
Drives: '13 128i Alpinweiß/Korallenrot
140lbs....... ??
Yeah, I think he converted that backwards. 300kg = 660LB or so. I seriously doubt they could drop that much weight, without dramatically boosting the cost (more Al and CF to get that kind of weight loss).
      10-12-2011, 08:31 PM   #56
RPM90
I was basing it on a similar weight reduction of the E87 vs F20.
I figured roughly a 140lb weight reduction for the new 2 series replacing the current 1 series coupe.
A 660lb reduction is never going to happen. That's an extreme weight loss, more in line with a high priced lighter weight materials.
      11-01-2012, 04:55 PM   #57
f30jprad
f30jprad's Avatar
Drives: 2017 330i
Sign me up! The 2-series looks promising.
Tags
2-series, bmw 2 series, bmw 2 series coupe, bmw 2-series forum, bmw m2, bmw m2 coupe, bmw m2 forum, bmw m2 forums, m2 coupe, m2 forum, m2 forums
Search this Thread:
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
