04-21-2024, 01:02 PM | #1 |
Rep 1
Hi all,
New to the forum and looking for a little bit of advice. I have had an engine management light on and off now for about 3 months. Upon starting up this week it came up with drivechain fault all in red on the dashboard. Engine starts and runs fine on tick over but as soon as you rev it runs rough and splutters. Had it plugged into ISTA on a friends laptop as I don’t have the software and the following codes come up: - 282E00 - Oxygen sensor after catalytic converter, heating, activation: Short circuit to B+ 283300 - Oxygen sensor before catalytic converter, heating, activation: open circuit 282D00 - Oxygen sensor before catalytic converter, heating, activation: Short circuit to B+ 283400 - Oxygen sensor after catalytic converter, heating, activation: Open circuitOxygen sensor after catalytic converter, heating, activation: Open circuit 270100 - Hot film air mass meter, signal: Too low Rang my local dealer and the soonest they can see the car is 3 weeks time so going to try and tackle it myself if it’s a sensor. Looked on the OBD Scanner and seems: O2 Lambda sensor bank 1 sensor 1 -0.99V O2 Lambda sensor bank 1 sensor 2 - 1V O2 Lambda Sensor bank 2 sensor 1 - 0V O2 Lambda Sensor bank 2 sensor 2 - 0V Noticed on the sensors that the MAF air flow rate was - 0g/sec Any ideas what I should look at first could it be a faulty MAF sensor? Not into massively into mechanics but want to try and give this one a shot! Thanks |
04-24-2024, 09:01 AM | #2 | |
Rep 6
If I was in your shoes I would take it to a local shop Last edited by Adam Lanister; 04-24-2024 at 06:10 PM.. |
