11-26-2022, 11:49 PM | #1 |
Rep 213
Cts turbo f-series bmw n55 boss turbo upgrade
I figured I'd make a post on this turbo, couldn't really find much information on this since everyone joined the b58 family and they're the hot commodity in the streets.
Just a little background on my M235i: Car is currently FBO of course, including a spool fx-150 HPFP and a spool stage 2 LPFP, with MHD custom map from True Power Software making low 400's on the dyno. Car has been running great, beating a lot of stock turbo n54's. But with all these n54's being upgraded turbos and b58's making over 500whp it was time to upgrade to keep it competitive. First impression on the turbo is the obvious A LOT bigger than stock, have some pictures for comparison. As I write this, the car is jacked up in the garage. I will be doing the install at home so I can provide all the details. Looking forward to seeing the car taking on some upgraded turbo n54's and some b58's. If the turbo is as advertised, it should easily make close to 600whp for now. If needed might upgrade HPFP to a stage 2 and upgrade injectors might possibly add port if needed to max out the turbo. Will keep you guys updated with progress. And a quick shoutout to Extreme Powerhouse for the turbo. Fast shipping, great products and great communication!
2012 DCT N55 135i
VRSF chargepipe, JB4, VRSF Downpipe, VRSF 7" Intercooler, Riss Racing Exhuast, Bms Intake, Fuel It Stage 2 Bucketless LPFP |
11-26-2022, 11:54 PM | #3 |
Rep 213
Some more pictures, wasn't letting me upload all at once
2012 DCT N55 135i
MLJR235116.50 |
11-27-2022, 09:49 AM | #4 |
Rep 191,485
Thank you for the shoutout and pictures.
Looking forward for your feedback after the turbo is installed
11-27-2022, 11:02 AM | #5 |
Rep 213
I should start data logging this week, and hopefully bring some pump gas numbers then some e50 numbers.
2012 DCT N55 135i
11-27-2022, 07:20 PM | #6 |
Rep 191,485
11-30-2022, 12:04 PM | #9 |
Rep 191,485
12-05-2022, 07:46 AM | #10 |
Rep 1,125
Drives: 2015 BMW 435i Xdrive MSport
Any updates?
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily) |
12-05-2022, 03:09 PM | #11 |
Follow my IG! @Es_wetto
Rep 26
Im not sure if hes having issues or not, but i had just finished mine not even an hour ago, it was a hell of a time trying to install, have a small coolant leak and have to adjust my wastegate but outside of that i think its hooked up right, im waiting on a new turbo inlet at the moment my pcv cracked when i pulled it out
12-05-2022, 03:15 PM | #12 | |
Rep 1,125
12-05-2022, 06:15 PM | #13 |
Rep 26
Boostedphil698452.50 |
12-05-2022, 06:16 PM | #14 |
Rep 1,125
Sick! Let me know how it goes.
12-05-2022, 07:15 PM | #15 |
Rep 213
Sorry guys I was out of town, I should be finishing up soon. Taking my time on installation to make sure things are good.
2012 DCT N55 135i
12-06-2022, 08:42 AM | #16 |
Rep 191,485
12-06-2022, 01:54 PM | #17 |
Rep 26
Make sure you snug up the lines very well! I accidentally didnt tighten one of the water lines enough and ive got a nice slow leak going on, fixing it this coming weekend, also would you by chance have ista+ so i can adjust my wastegate aswell?
12-12-2022, 09:05 AM | #19 | |
Rep 2,651
Make sure to do a 91/93/E30 dyno. Peeps that only run normal 91/93 want numbers from this kit, I'm especially curious about the 91 oct only.
Bootmod3, CTS Catless DP, B58TU HPFP, XHP, BM3 Flexfuel Kit
12-12-2022, 06:08 PM | #20 |
Rep 26
Just got my base map from doc vu, I will be getting tuned on 93, do any of you guys know a good way to check wastegate? My laptop isnt large enough to store ista+, i would love to make sure its correct and isnt going to limit me
12-13-2022, 10:59 AM | #21 | |
Rep 2,651
PWG is easier as there was this vacuum device you plugged it and there was a gauge you can check if it's within spec, and you adjust the nut from there.
