06-14-2022, 09:43 PM | #1 |
Rep 7
F22 Chassis HELP NEEDED
I have a 2016 BMW M235i and recently while driving I had a Chassis function restricted error pop up. Took off my wheel and checked the wires but everything looks fine. Wires are plugged in and none of the sensors or wires look to be broken. Any ideas?
482A26 Valve coil - front right - open circuit 482A24 Valve coil - front right - short circuit terminal 15 / terminal 30 |
06-15-2022, 12:34 PM | #2 |
3726
Rep 3,632
The valve control within the damper has probably failed. The dampers should still work, but will default to one setting and won't be able to be adjusted. Probably needs a resistance check with a multi-meter to confirm the issue is inside the damper and not a fractured wire connecting to it.
06-22-2022, 11:19 AM | #3 | |
Rep 7
06-22-2022, 12:33 PM | #4 |
3726
Rep 3,632
