02-03-2022, 12:33 PM | #1 |
Rep 110
8.8 screen upgrade
I tried to upgrade my 6.5 screen from my 2017 230i entry level to the 8.8 inch screen but I got the “No signal” message.
Looking around I found that my screen 9387547 is too new for my car. Can someone confirm is the screen 9292248 would work? Code was done for the new screen but had to change it back since it didn’t work out |
02-03-2022, 03:30 PM | #2 |
Rep 1,828
I've tried it with a screen from an auto wrecker, without doing enough research. Non-nav cars are stuck with 6.5" factory screen unless you upgrade the whole system or go aftermarket. I have HU_ENTRY, it sounds like you do too.
02-04-2022, 07:24 AM | #4 |
Rep 1,828
Found this: https://www.bimmerfest.com/threads/n...-guide.914613/
Looks doable if you're determined enough. |
02-04-2022, 03:50 PM | #5 | |
Rep 110
02-12-2022, 02:16 PM | #6 |
Rep 1
In doing a bit of research I saw that the 6.5 inch screen is labeled "L7 CID Entry 6.5". With that logic, could the 8.8 inch L7 CID screen be a plug and play?
03-13-2022, 01:52 PM | #8 |
Rep 198
here this should cover almost any question you have
https://www.2addicts.com/forums/show....php?t=1253651 quoted from a post on page 5 I think I can confirm the LCI F30 screen 9387453 works on a 2017 M240i! Great update from the base 6.5'' screen Last edited by pmcmtnbkr; 03-13-2022 at 01:59 PM.. |
04-09-2022, 04:11 AM | #9 |
Rep 5
Screen swap
I'm looking to upgrade my screen and The 3 series screen seems to be much cheaper than the 2 series one - does anyone know how much worse the fitment is of this on a F22?
04-18-2022, 08:13 PM | #10 | |
Rep 198
https://www.2addicts.com/forums/show....php?t=1253651 |
