2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning OMG VRSF ChargePipe
      03-07-2020, 10:14 AM   #1
123Britt
Drives: 15 M235i AT
OMG VRSF ChargePipe
Installed
      03-07-2020, 02:19 PM   #2
khj24
khj24's Avatar
221
Drives: 2015 m235i
It's fine, it'll just be that green o ring that compresses. If you put a bit of oil on there it'll side on nicely with some force. Definitely a reassuring seal, I wouldn't mess with it.
      03-07-2020, 04:22 PM   #3
123Britt
Drives: 15 M235i AT
Actually Mine would NOT
Yes the Green - O-Ring.
      03-07-2020, 06:02 PM   #4
khj24
khj24's Avatar
221
Drives: 2015 m235i
Mine wasn't chamfered at all, I guess yours was tapped a little too small like you said then. Hope the tmap sits deep enough with your setup!
      03-08-2020, 10:11 PM   #5
drodrig2
Drives: m235i
The VRSF charge pipe I just got yesterday has the same problem as yours. What Champherd / CounterSink bit size did you use?
      03-09-2020, 03:50 PM   #6
123Britt
Drives: 15 M235i AT
3/4 Countersink
Nice
      03-09-2020, 09:27 PM   #7
Dynamic_m235
Drives: 2016 m235i xDrive
Originally Posted by 123Britt View Post
Installed the VRSP 5 HD Intercooler and Charge Pipe less the TMAP Sensor on the charge pipe because I noticed a blemish on the seal -- so I ordered a new seal.
No problem right? All the work of installation was really done - just the simple TMAP sensor install.
Well - once I got the new seal , I attempted to install the Cleaned Sensor and with new seal. OMG -- it does not fit!!!
After reviewing the OEM Chargepipe I noticed a significant chamfer on the opening of the port. While the VRSF ChargePipe MAP Sensor opening is only deburred but NO CHAMPHER. (see photos)
I have now taken the entire IC and ChargePipe back off the car and I guess I will go to Home Depot to buy a champher bit .
So -- Lesson Learned: Check that your VRSF ChargePipe will accept the TMAP Sensor. The way that it is (without a champher) -- you will either break the TMAP or trash the seal on installation. I have pushed like hell to get mine installed. Once I champher the opening - I am sure it will compress the seal and be a tight fit.
How frustrating!!!!!!!
I had a vrsf chargepipe and it rubbed on my steering rack till it poked a hole through. Their chargepipe isn't made right to fit directly, most people have problems like me
      03-24-2020, 09:22 AM   #8
Tiago@VRSF
Tiago@VRSF's Avatar
Drives: F90 M5
This issue only affected a small portion of XI charge pipes and has been rectified via a redesign. Please contact support@vr-speed.com for a replacement
      03-24-2020, 10:58 AM   #9
I had to give it a bit of oil and push/twist it in firmly, it almost seemed like it wanted to cut the o-ring without any "lube" but went in at the end, been on for 3 years no issues whatsoever...
