09-27-2018, 06:28 PM | #1 |
Rep 28
Instrument Cluster Cover Removal
Brand new member here. Looks like a great forum. Hope you can help me out with a question.
I have a 2016 M235i 6 speed manual that I recently purchased and for some reason the clear polycarbonate cover over the instrument cluster has a crack in it. My question is can this cover be easily removed and replaced with one from a donor car or do I need to replace the entire cluster? I've swapped this out before on other brands of cars, but I am new to BMW. If anyone has actually done this, any tips or recommendations would be greatly appreciated. Thanks in advance |
09-28-2018, 02:58 PM | #2 |
Rep 3,256
Not sure how useful this will be, but this is how you remove the entire cluster. I'm not sure if the plastic in front is a clip in. Perhaps once you remove it you might be able to see better.
https://f87.bimmerpost.com/forums/sh...79&postcount=9 |
10-04-2018, 07:52 PM | #4 |
Rep 28
I thought I'd provide a quick follow-up to my original question in case anyone else has the same question. Just completed the lens replacement tonight in less than 15 minutes.
The cover is in fact very easy to replace. Six clips and four t-9 torx screws and it comes right apart. Removal of the cluster from the car is as easy as it gets. Two T-20 torx screws at the top, pivot forward, remove 2 electrical connectors from the back, and it pulls right out. Putting it back in is equally as easy. I did disconnect the battery just to be safe, remembering not to close the trunk while the battery was disconnected since the power latch won't release the trunk lid if there is no power. |
PANDA F2216.50 designatedposter175.00 |
10-04-2018, 10:23 PM | #5 | |
Rep 643
M235i rwd 6mt
10-05-2018, 12:22 AM | #6 |
Rep 26
10-05-2018, 06:22 PM | #7 |
Rep 28
Yes. There are four T-9 Torx screws that must be removed from the back of the cluster and there are six clips that must be released. Two of the clips are on the bottom, two are on the top and there is one on each side.
10-05-2018, 06:51 PM | #9 |
Rep 28
I couldn't find anyone who would sell me just the lens, and the lens only is not available from the dealer. I found an entire cluster from a wrecked 2014 M235I reasonably priced on ebay. I made a best price offer and the seller accepted for just over $100. I then swapped the lens from the ebay cluster onto my original cluster so no programming or initialization was necessary.
04-04-2020, 09:56 AM | #11 |
Rep 52
I have a lense with a water stain, presumably from an overzealous windex sprayer while doing an interior detail before I bought the car. It sounds like it's possible to just replace the lense and I would buy a used cluster just for the lense on eBay, but wondering what models would have the same lense as my F30 2016 340i. I figure I can go with the cheapest that has the right lense and not worry about the rest of the details...Thanks for any help!!
04-04-2020, 10:24 AM | #12 |
Rep 643
No need to replace.. Just remove lens and clean it. Polish if necessary with common paint correction products from the auto store. I'd also get tack cloth to ensure no dust particles are there when you reinstall
M235i rwd 6mt
04-04-2020, 11:56 AM | #13 | |
Rep 571
nahtanoj116.50 |
04-04-2020, 02:10 PM | #14 | ||
Rep 52
El Conquistador339.00 |
09-29-2022, 05:59 PM | #15 |
Rep 1
Where are the 4 Torx Screws?
I know this an old thread, but I'm trying to replace the gauge lens but it's stuck in the bottom left corner and I don't see any torx screws as mentioned by others.
