2Addicts | BMW 2-Series forum Classifieds Commercial Classifieds Suspension / Brakes / Chassis / Spacers SUPREME POWER l KW Suspension Products
      08-13-2018, 04:11 PM   #1
matt@supremepower
matt@supremepower's Avatar
Drives: BMW
KW Suspension
KW V3
Race technology for the road, with adjustable compression and rebound dampening. State of the art motorsport technology enables better performance on the streets. The independently adjustable compression and rebound dampening allows for cutom driving setups.
The exclusive KW patented system has dual level valves that allow for adjustment of the rebound dampening for your road comfort and the compression dampening that controls the driving dynamics.
Lowering:
Front Lowering: 0.8" to 1.8"
Rear Lowering: 1.0" to 2.0"
Compression- and rebound adjustment
As far it is vehicle-specifically possible, the rebound damping is adjusted by a spindle at the end of the piston rod. Mainly, the traction phase (rebound) controls car body vibrations and also influences handling and comfort in the low-speed damping range. By using the traction phase adjustment, the vehicle can be adapted to the requirements of the driver. Moreover the driving behavior can be regulated from comfortably rolling to sporty and tense with improved road holding characteristics.
The compression phase adjustment is carried out at the lower end of the shock absorber via our patented multi-purpose valve. The large number of pre-set parameters of this valve allows for a wide range of adjustment for individual use. The unique low-speed compression adjustment significantly distinguishes this technology from any other. In this compression range, the driving behavior of the vehicle is drastically influenced. An increase of the damping power supports the vehicle already during compression and therefore avoids rolling and pitching. The directional stability is significantly improved.
Damping technology with individually adjustable rebound- and compression technology
inox-line* stainless steel technology
Individually height adjustable
Adjustment parameters approved by the German Technical Control Board (TÜV)
High-quality components for long durability
Infinitely variable rebound damping adjustment
14-way adjustable compression damping
Unique, individually working damping force adjustment
Comprehensive documentation for easy use
KW Clubsport
KW Clubsport coilovers was developed for customers, who demand a better handling car when participating in track day events, but also require a setup that could be used every day. The Clubsport was specifically designed for the Nordschleife using track day tires. By using the optional adjustable top mounts, the suspension geometry can be adjusted to the requirements of tires and the intended use. The mentioned adjustment options combined with the independently adjustable rebound and compression damping technology allow a suspension setup according to the vehicle load, tire characteristics and different track conditions. KW Clubsport meets every demand regarding a coilover for the usage on the road and the race track.
KW Clubsport suspension kits are independently adjustable in compression and rebound forces and include high performance racing springs. Racing top mounts are optionally available for further performance. KW Clubsport guarantees excellent handling, best performance, highest agility and fantastic lap times.
Height adjustable coilovers
Performance setup for the racetrack
Dampers in compression & rebound forces independently adjustable
Use of high performance linear race springs/li>
In stainless steel technology inox-line
Additional available with racing top mounts
KW Sleeve Kit
KW Sleeve Kit Can cause issues when trying to lower vehicle all the way (~1.5)
The perfect solution for the individual looking to lower their vehicle to the height they desire without going to a full blown coilover setup.
Kit Includes:
4 Lowering Springs
F/R Spring Perch Adjustment Tools
Height Adjustable Spring Perches
Strengthened bump Stops
KW Shock Sleeves
Ordering:
Mounting & Balancing:
Expect perfection: All orders include complimentary mounting and balancing on our Corghi Artigulo 50 Touchless Mounter and Hunter Engineering 9700 Road Force Balancer
Shipping:
Perfect tire and wheel packages delivered consistently. All wheel and tire packages are boxed and handled with care. No stapping. No cardboard on faces. Extra Heavy Duty Boxes surround your purchase and ensure delivery to your door in perfect condition. No cutting corners here.
Phone:
You may call us at 714-632-1951 to place your order over the phone.
Payment:
Credit/Debit Cards: Visa, Mastercard, Discover, Amercan Express. (avail online & over phone)
Other Payments:
Money Order/Cashier’s Check & Bank Wire Transfer are also available. Please contact us to pay with either of these methods.
Shipping:
All orders will be shipping via Fedex. If you are interested in shipping to Hawaii, Alaska, Puerto Rico and Canada, please call us. You will be charged additional shipping fees. International shipping is available at reasonable prices, please contact us for shipping quotes.
Hours of Operations:
Monday - Friday from 9AM to 6PM PST
Saturday by Appointment
Sundays we are closed
Retail Showroom and Installation Center:
Come check out our 10000 square foot facility in Fullerton, CA. We install everything we sell.
Contact Info:
Phone: 714-632-1951
Email: Matt@supremepower.com
Website: http://www.supremepower.com
If you have any questions, please feel free to PM, email or call us anytime and we will do our best to get you the info you are needing!
      09-18-2018, 12:56 PM   #2
matt@supremepower
Drives: BMW
      09-28-2018, 07:02 PM   #3
matt@supremepower
Drives: BMW
