2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning Exhaust sitting too low for my liking. thoughts?
      04-11-2018, 07:04 PM   #1
Tano22
Tano22's Avatar
148
Drives: 2024 BMW M4 Competition XDrive
Dinan exhaust. My issue is only with the tips. Tips are fine protrusion length wise, but there's about a two finger gap between bottom of my diffuser and the top of the exhaust tip. Driving me nuts. Thinking maybe the hangers are too elastic, but they are fairly new (roughly 19k miles on them). Wondering if maybe they got stretched during install. Don't think cutting more pipe is the answer but I'm open to suggestions.
Here are some pics for reference.
      04-12-2018, 02:33 AM   #2
Bibopp
Drives: BMW M235i
The problem does not come from the muffler or from hangers. It comes from the assembly of all the line or pipes clamps. Go under the car, unscrew the clamp which link the midpipe and the muffler and turn a little the midpipe. When everything will find the proper place, the muffler will go up and your tips will be properly fitted with the diffuser openings.
Tano22147.50
      04-12-2018, 06:53 AM   #3
Tano22
Tano22's Avatar
148
I'll try that, thanks.
      04-12-2018, 11:23 AM   #4
mdputnam
mdputnam's Avatar
289
Dinan probably designed the exhaust that way to avoid this problem on the track.
      04-14-2018, 06:28 PM   #5
frenchfry675
Drives: M235i xdrive
I have the same issue with mine. I’ve tried everything to get them higher but couldn’t do it. Let me know if you ever figure out how.
      04-14-2018, 09:13 PM   #6
gk09
gk09's Avatar
Drives: 1m
Impossible to change. The DinN on my 1M is the same.
      04-16-2018, 03:48 PM   #7
KPT2
Drives: 2016 M235i
I moved the bottom mount (muffler) to the big irregular hole in the rubber mount. It raised the exhaust about one finger width.
      04-17-2018, 02:17 PM   #8
kevinh211
Drives: 2015 M235i
I have the same issue. I bought the car with the muffler on an always thought it was installed wrong.
A shorter polyurethane exhaust hanger looks like will help. Also maybe moving the hanger on the car back about an inch to help stop the tips from sticking so far out.
      04-17-2018, 03:32 PM   #9
frenchfry675
I was thinking the same thing about the hangers because they do look stretched once the muffler weight is on them. I hate how far my tips stick out. I wish I would’ve bought the stock diffuser muffler for my m performance diffuser so the tips were shorter. I also can’t get my tips even. It’s only off by a tiny bit but it bothers me.
      05-06-2018, 05:32 PM   #10
KPT2
Drives: 2016 M235i
I have shorter hangers coming from amazon, will update when I get them.
      05-12-2018, 09:31 PM   #11
frenchfry675
Did you put them on yet? Post some pics when you do.
      05-13-2018, 08:46 AM   #12
KPT2
Drives: 2016 M235i
Just did this morning. Gap is exactly one finger at the top now .
Here is what you need:
10 mm, 32mm between holes
Autobahn88 Universal Exhaust Muffler Hanger Bushing, 2 Holes, 10mm (0.4") Hole Siz...
https://www.amazon.com/dp/B01LOPWIM2..._vfe-Ab4EQBS18
      05-13-2018, 09:02 AM   #13
frenchfry675
https://www.amazon.com/dp/B01LOPWIM2/ref=cm_sw_r_sms_c_api_i_vfe-Ab4EQBS18
Awesome thanks. I just ordered a set.
      05-13-2018, 09:12 AM   #14
KPT2
Drives: 2016 M235i
Great. Happy to help. They don’t come in pairs though so make sure you order 2
      05-13-2018, 09:15 AM   #15
emtrey
emtrey's Avatar
92
Drives: 16 M235IX, 06 Carrera S, 335i
looks perfect, Just wondering if that limited gap will cause the infamous "melting" issues.
Hope not, because I prefer that look.
      05-13-2018, 09:23 AM   #16
KPT2
Drives: 2016 M235i
Originally Posted by emtrey View Post
looks perfect, Juts wondering if that limited gap will cause the infamous "melting" issues.
I hope not as well! I don’t track my car but I will be happy to be the guinea pig. I had it mocked up to this same gap by improperly using the stock hangers as I mentioned a few posts back and had no issues after a month.
      05-13-2018, 09:28 AM   #17
frenchfry675
Yeah I did. As I wrote "set" I wondered if you would think that. Haha appreciate it.
      06-12-2018, 10:39 PM   #18
KPT2
Drives: 2016 M235i
How did these work out for you Frenchfry?
      06-13-2018, 05:49 AM   #19
frenchfry675
They made the tips sit perfect but my muffler was hitting the heat shield above it. I think my bracket from my m diffuser needs to be bent to allow more clearance. I just gave up I'm going to take it to a shop to get it straightened out. Haha
      06-13-2018, 06:19 AM   #20
BEM-S4
BEM-S4's Avatar
Did you guys cut stock at the dimple? Wondering if leaving an extra 1/4" or so would pivot things up on order to have the tips sit higher.
I ask because when I did the MPE on the wagon a few weeks ago I noticed there was a fair bit of play to rotate the whole assembly to get the tips up in the air.
Also when the shop did my MPE on the 2 the tips were too high and it was because they left the stock pipe too long and trimmed a bit to get things to rotate down.
Tano22147.50
      06-26-2018, 10:14 PM   #21
KPT2
Drives: 2016 M235i
Month and a half of daily driving in 100+ temps and no melting for me so far
      06-30-2018, 10:01 AM   #22
emtrey
emtrey's Avatar
92
You might be correct. My indie mechanic said anything he looked at to raise the system looked like it would cause the muffler to hit the heat shield so he left it alone. He said the best way he saw was to take it to a muffler shop that had a jig to bend stainless steel and bend the hangers a little.
Bottom line, for me. I am done worrying about this. Its not the best design by Dinan IMHO but it sounds great and unlikely to be noticed by anyone other than BMW "addicts".
My "anal" son just looked at the car and said--those pipes are awesome and loved the sound of the system windows open or closed. Never said a word about the "gap"
