2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning Mini Cat
      03-20-2018, 10:22 AM   #1
Rony316
Drives: M235i XDrive Convertible
Mini Cat
Hello,
Has anyone successfully used the mini cat from Big Daddies Garage. Do we need the angled one or is the straight one fine for our vehicles?
2016 F23 AW M235xi
      04-04-2018, 09:13 AM   #2
Er1c
Drives: 2020 330i xdrive
interested to know if anyone has gone this route also. i want to do a down pipe upgrade but i have yearly emissions inspections in MA.
      04-04-2018, 09:23 AM   #3
Rony316
I will be installing mine this weekend. Hopefully I bought the one that fits. Also in MA. Will update when I pass inspection at end of month
2016 F23 AW M235xi
      04-04-2018, 09:23 PM   #4
Er1c
cool, which Down pipe do you have? Did you go with the angled spacer and mini cat or just the mini cat?
      04-04-2018, 09:31 PM   #5
Rony316
I already have VRSF and went with the straight mini cat. Fingers crossed.
2016 F23 AW M235xi
      04-05-2018, 02:16 PM   #6
jmwilson125
Drives: 2016 M235i
I tried the er high flow do and got a cel, then I tried a normal spacer and still had a cel, then I tried a 90 degree spacer still a cel, then I tried splicing this little cel delete module to my 02 sensor wires and still got a cel. I have since given up and do the worry about it.
I have heard of the mini cat working for some guys though. I think there may be a couple from guys who had success. By the time I discovered these were an option I had already given up.
Best of luck, let us know how it works out.
      04-05-2018, 02:19 PM   #7
Rony316
The goal here is not to completely eliminate check engine light, as I have a JB4 for that. The goal is to drive conservatively enough with the mini cat in to clear emissions just for inspection. Would be cool though if it works all the time.
Will let everyone know hopefully after this weekend
2016 F23 AW M235xi
      04-06-2018, 11:03 AM   #8
Sail Boat
FWIW, I failed MA emissions back in college (2012) when I had a Forester with a Cobb catted downpipe. At the time, this was a very high quality piece.
With the exception of 25+ yr/o cars (obviously), practically everyone I know here in VA change their tunes and downpipes to stock prior to emissions testing - some have become pretty smart about it and have VBands installed on the DP inlet and outlet to make the switch simpler. The one or two that don't claim to "know a guy".
I guess just buy what you think is best but keep your OE parts to switch in and out. Otherwise, you can make pretty great power on the stock DP... I say save the $600+.
      04-06-2018, 07:29 PM   #9
frenchfry675
Drives: M235i xdrive
They are vbands but it sucks switching them back and forth. I switched back a couple months ago and messed with the vband at the turbofor 2 hours trying to get it on. It was a royal pain. I miss the good old days of the angled extensions.
      04-11-2018, 05:19 PM   #10
Er1c
Any luck?
      04-21-2018, 08:03 PM   #11
Rony316
Just installed it today, cleared the code, and drove around a bit. Nowhere close to having driven enough to take an O2 reading. Pretty sure I didn't get one of the vbands on right as it's vibrating now. Gonna adjust in the morning and will update everyone if CEL comes on or not.
Update: 300 miles later. No check engine light.
2016 F23 AW M235xi
      05-06-2018, 03:25 PM   #12
Er1c
Thanks for the update man! That’s great news for us folks with yearly emissions that want to go catless. I plan to follow your route with the vrsf catless and the big daddies mini cat.
      05-06-2018, 03:27 PM   #13
Rony316
Different topic entirely, but going back, I would've rather gotten a DP with the OEM bracket instead of the free floating VRSF. Put too much stress on mid pipe which caused vibrations and rattles.
2016 F23 AW M235xi
jmkr29.50
      05-06-2018, 09:03 PM   #14
Er1c
Good to know! Will look into alternatives.
      05-29-2018, 05:11 PM   #15
Bmw.Fan
Drives: m235i
Minicat still good? Was going to order one soon.
Thanks!
      05-29-2018, 05:14 PM   #16
Rony316
Still good. No codes after the initial delayed O2 response. All sensors still read ready. No tune to cancel CEL either
2016 F23 AW M235xi
Bmw.Fan38.50
      05-29-2018, 05:15 PM   #17
Bmw.Fan
Drives: m235i
Awesome, order placed. Was also worried it wouldn't fit but you are the living proof I needed to pull the trigger.
Just for clarification, you got the regular straight one right (the only one they sell for 50 bucks)?
      06-14-2018, 11:48 AM   #18
MadOzodi
Drives: '14 EBII M235i
Not sure if you've purchased one, but the Mini Cat CEL Fix only comes as a straight version. The Angled CEL Fix and Straight CEL Fix don't have the integrated catalyst honeycomb.
      06-18-2018, 11:45 AM   #19
MadOzodi
Installed Big Daddy Mini Cat yesterday and now I've got the P0139 code.
Rony316, ballpark how many miles before your "initial delayed O2 response" went away?
      06-18-2018, 12:49 PM   #20
Rony316
After I cleared it the first time, it never came back
2016 F23 AW M235xi
      06-22-2018, 01:32 PM   #21
MadOzodi
Cleared codes, disconnected battery for a few minutes, P0139 came back after 48 hours or so.
The Big Daddy Mini Cat really stretches the post cat O2 sensor wires when used with the Wagner catted DP.
Stock DP going back on this weekend for emmissions. *SIGH*
      06-22-2018, 01:41 PM   #22
Rony316
How are you not passing emissions with catted dp? Also, you should still pass with delayed response code
2016 F23 AW M235xi
