12-21-2017, 07:52 AM | #1 |
Rep 410
Questions on flexfuel for m235
Just want to know if anybody has ever used it for their m235i and how it was. All I know about flex fuel is that you can switch back and forth from 93oct and others to e85.
12-21-2017, 08:09 AM | #2 |
Rep 146
Flex Fual
I would not dare put this in my BMW, from what I have seen first-hand from my neighbor who used it in his 2017 F250 and according to him, his truck has never been the same. He provided this link for me to read so I am sharing… the “disadvantages part” I think would throw up a red flag on a decision to use this as an alternative fuel.
https://www.carsdirect.com/green-car...-disadvantages
2018 ///M240i Convertible [Loaded - Garage Queen]
2018 Ford F150 XLT FX-4 [Daily Driver] BMW CCA #535395 SCCA #619713 |
12-21-2017, 08:53 AM | #3 |
Rep 400
As far as I know, Flexfuel vehicles must use different seal material because the ethanol can eat regular seal material. (don't know exactly what the regular material is)
I would never put E85 to any car that's not Flexfuel specific vehicle. |
12-21-2017, 09:59 AM | #5 | ||
Rep 1,541
You can mix normal pump gas with e85 to dilute the e85. Will work fine. Almost all gas in the US has some ethanol in it (~e10). I run e33-e35 usually. Keeps the engine clean and lots more power if you tune for it. Luckily I have a gas station that has 91oct, e85, and 101oct about 15min from my house.
12-21-2017, 01:52 PM | #6 |
Rep 1,219
Drives: 2015 M235ix
I have never found 101 octane fuel available in the NY metropolitan area, though admittedly I have not looked very hard.
And the thought if trying to accurately mix three fuels from three pumps while filling the tiny tank in a 2 series is beyond my tiny brain's comprehension. So I will stick with the 93 that God/Exxon gave us. I would use 91, as recommended, but again it is as rare as hen's teeth around these parts. |
12-21-2017, 02:02 PM | #7 | |
Rep 1,541
FYI: e85 is equivalent to 105oct Either way I use an app on my phone to do the mixture. Takes 15 seconds and is the difference of ~50hp.
12-21-2017, 02:02 PM | #8 | |
Rep 1,931
Most folks run 2 gallons of E85 with a full tank of 93, anymore and your fuel pump will throw a CEL. Then you need to upgrade the LPFP. Than if you run too much E, they car will run like shit and stall.
www.nybmwcca.org
12-22-2017, 08:18 AM | #9 |
Rep 1,219
Drives: 2015 M235ix
Where on the RPM curve do these increases in HP emerge? If at the very high end, then they are not very useful except on the track.
And paying close to $20. per gallon is pretty steep, especially when I have to run round Robin Hood's barn to find "any race supply shop" or "any race track." Have a great Christmas and drive carefully. Keep those RPMs down! |
12-23-2017, 11:03 AM | #11 |
Rep 146
Jokes
Thank you for your journalistic opinion... but you know what they say about "opinions" right?
I found the content quite accurate, and lots of other sources out there with similar of not exact information. If you want to put that ethanol slop in your BMW then that is your choice. That fact that all gas now has some level of ethanol is irrelevant. When there is a legitimate reason to use flexfuel in my M240i, I may consider, for now its 93 with a tad of that added corn stuff.
12-23-2017, 01:05 PM | #12 | |
Rep 2,067
I only fuel with ethanol free high octane gasoline (e.g. Shell V-Power) in Canada. Better mpg and better for your car. I know that stateside you may not have that option --- sad...
2019 X2
12-24-2017, 10:04 AM | #13 | |
Rep 146
https://www.pure-gas.org/ One of the core reason to avoid E85 for boats is mentioned here, it deals with storage periods when a boat is not in use. https://www.westmarine.com/WestAdvis...nol-Fuel-Myths I would think that this scenario may also apply for those who store there fun summer car away for the winter...
12-24-2017, 02:24 PM | #14 | |
Rep 2,067
2019 X2
whoismorggan554.00 |
12-29-2017, 03:23 PM | #15 | |
Rep 1,541
Disadvantages: Sole use.The use of ethanol can be considered a disadvantage as well because any crops that are made available for fuel production cannot be used for any other use. This could lead to higher prices for products like animal feed that could otherwise be derived from them. Corn, in particular, is a labor intensive crop to cultivate and is prone to drought, bad weather conditions and disease. A ridiculous argument. The same could be said of fossil fuels or any other resource in existence. Engine damage.Ethanol can also unfortunately cause corrosion and damage to the engine, mainly because it absorbs dirt easily. The "absorbs dirt easily" is irrelevant to our cars or any other modern fuel system. If you have dirt in your fuel system you have larger issues to deal with. Also to state it causes corrosion and damage to the engine is false. Written by a person that doesn't even know what an engine is apparently. In fact ethanol "cleans" the combustion chamber (tops of pistons, valves, fuel injectors, etc). Also, if you would have quoted my whole comment you will would seen that I'm only talking about a low concentration. Which makes most of that article irrelevant. Expense. Ethanol is also not as economical as gasoline, in that it does not provide the same level of fuel efficiency. Suppliers of ethanol may not be as numerous as those who supply gasoline, so flex fuel stations may be fewer and farther between than is presently the case with gasoline stations. In fact, there are currently only a few stations nationwide that supply ethanol. The value of ethanol will vary depending on normal fossil fuel prices. Here in California the gas prices for 91oct over $3.50 a gallon. E85 is ~$2.50 a gallon here. So even though ethanol gets less MPG it can still cost you less. Again, in my context of mixing the fuel the MPG aspect is a non-issue. There are many e85 to fossil fuel cost calculators online that will show you if it's a money saver for you based on e85 and fossil fuel prices. It also states there are only a few stations nationwide that supply ethanol. What is a few? Great article. Little actual research or thought was put into the article. The issue is not as simple as it is made out to seem.
B58togo808.50 |
12-29-2017, 03:30 PM | #16 | |
Rep 1,541
If you're not someone that is looking to do that (as most naysayers here probably) it won't be worth it.
12-29-2017, 03:35 PM | #17 | |
Rep 1,541
You would not get much of a boost on stock ecu; if any.
Maynard3848.00 |
12-29-2017, 03:47 PM | #18 | |
Rep 1,541
Well he is opening up Alaskan oil again
12-29-2017, 06:49 PM | #19 |
Rep 146
We can go back and forth with this topic for days, I can find info that trumps your logic and I am sure you can find the same in reverse... it's like politics, Republicans and Democrats yapping to each other, both right and both wrong depending on who's point of view your focusing on at the moment.
Bottom line, enjoy using e85 For me, there is nothing anyone can say to me that will convince me to put e85 in my BMW. As for my boat, "the twins" are always fed an ethanol free formula.
2018 Ford F150 XLT FX-4 [Daily Driver] BMW CCA #535395 SCCA #619713 Last edited by VIN240i13; 12-30-2017 at 07:55 AM.. |
12-30-2017, 12:47 AM | #20 |
Rep 525
I'm not sure what there is to debate...
Much of what Anthony said is correct. Any caution about the use of E85 mainly applies to older engines and their hoses. The newer cars, especially at lower concentrations of ethanol (i.e., E30 mix) can handle the additional alcohol content without any detrimental effects as long as the engine is tuned for the difference in how the fuel combusts. |
Anthony235715.00 |
12-30-2017, 07:53 AM | #21 |
Rep 146
Correct there is no more debate..
Not going to waste any more time providing info on the negatives of using e85, it's all out there.. Google it. For those that use it, enjoy.... I won't.. end of story...
12-30-2017, 07:59 AM | #22 |
Rep 780
Um I use 5 gals of it evrey tank with my 98oct. It’s what evreyone running a jb4 or similar tune is running. Go to N45 board amd look
