01-29-2017, 11:20 AM | #3 |
3441
Rep 79,211
Pretty simple : http://burgertuning.com/instructions...es_jb_plus.pdf
01-29-2017, 01:02 PM | #4 |
Rep 49
01-29-2017, 02:55 PM | #5 |
Rep 1,931
just turn the car off, pop hood. put ur keys away from the car, put it on. done.
Even if you fuck it up, you just to restart the car and its fine. Dont unplug power. its not needed.
www.nybmwcca.org
superherorockstar63.00 |
01-29-2017, 03:00 PM | #6 |
Rep 221
make sure you separate the earth and power wires completely. mine some how fused together so ensure there is no way they can touch other wise there will be tears.
01-30-2017, 08:51 AM | #7 |
Rep 126
Too be honest I didn't even wait for the ecu to go to sleep. I just popped the hood when I got home and installed it, then did a few test runs . And my car is running great it's definitely a noticeable improvement. I almost forgot. I'd probably recommend an AFE PRO DRY FILTER if you don't have an cold air intake it really really helps with throttle response. I got mine fro Xtreme Powerhouse for 69 bucks
Tyresian69.00 |
01-30-2017, 06:51 PM | #8 | |
Rep 190,807
01-30-2017, 07:47 PM | #9 |
Rep 74
Question for those who installed the JB+ and had to bring the car in for warranty service.
Did you leave it in,or took it out?I mean you can hardly see it in the engine bay,right.My first warranty visit is coming up this wednesday.Just wondering what you guys did. |
01-30-2017, 07:48 PM | #10 | |
Rep 190,807
01-31-2017, 05:07 PM | #11 | |
Ne Plus Ultra
88
Rep 264
Drives: Portimao Blue 2022 M240iXdrive
AFE Pro Dry Filter
Thanks! |
01-31-2017, 05:15 PM | #12 |
Rep 190,807
It will work on both cars
Redbeemer88.00 |
02-01-2017, 01:52 PM | #13 | |
3441
Rep 79,211
Rommel428.00 |
02-01-2017, 02:12 PM | #14 |
Rep 93
Installed a couple weeks ago
I installed the JB+ a couple weeks ago and am super happy with it. The only thing I've noticed ever since i installed it is that sometimes when I step on it in third for the first time it seems like the turbo doesn't spool up. Anyone else experience anything similar to this?
Thanks to Mike at Xtreme Powerhouse for the speedy delivery of the JB+. |
02-01-2017, 02:15 PM | #15 | |
Rep 190,807
What do you mean by does not spool up? Turbo lag?
02-01-2017, 07:42 PM | #16 |
Rep 78
I installed my JB4 couple of months ago, it was EZ. I didn't disconnect the power but I was very careful around the positive terminal. I ran map 1 for several weeks and then switched to map 5. I'm very happy with it.
Last edited by syclonedriver; 02-02-2017 at 08:25 PM.. Reason: corrected map 4 to 5 |
02-01-2017, 08:37 PM | #17 | |
Rep 49
Maps
Can you explain the different maps to me? That would be wonderful Thanks! |
02-01-2017, 09:48 PM | #19 |
Rep 93
I wouldn't say turbo lag. It's almost like the turbo doesn't even spool. I don't feel that kick in the back like I did in first and second. I'll rev it out until about 5k rpm and then shift to 4th and I'll feel that turbo kick again.Normally I can clearly hear the turbo pressure release with my intake, when I let off the throttle, however when this happens I don't hear any of that hiss. It doesn't happen everytime, it's seems to happen when I'm accelerating hard for the first time on a drive.
02-02-2017, 02:12 PM | #20 | ||
Rep 190,807
Map 1: Additive target, around 4psi over stock. Map 2: Additive target, around 6psi over stock. Suggested for those with 93 octane and bolt on modifications. Also good for small E85 mixtures. Map 3: Progressive methanol mapping, absolute target of 11-20psi based on meth flow, meth additive setting, and average ignition values. Map 4: Stock performance with JB4 active for logging only. Map 5: Autotuning map, absolute target of 11-17psi based on octane and conditions. Map 6: User definable absolute target map. Suggested for troubleshooting by professionals only. Map 7: Race gas map. Absolute target of 18.5psi. Requires straight unleaded race gas.
