12-01-2016, 06:25 AM | #1 |
Rep 1,151
Clunk noise when reversing full lock in cold.
Anyone else had this:
when its cold and i first get in car it makes a clunk clunk noise from front when i reverse out of car spot on full lock right hand down. once car warmed up its gone when u do same manoeuvre, not sure if common or to check. its odd sound wheel could be slipping but u feel a physical clunk feels mechanical. |
12-01-2016, 08:12 AM | #2 |
Rep 5,578
Myself and others have experienced the same thing. Last few winters there were some post about this.
Probably caused by 'stiction'. Do you have summer tire's on the wheels. I just switched to Michelin a/s from PSS's and haven't had the clunk this season, but maybe just not cold enough yet. |
12-01-2016, 10:34 AM | #3 |
Rep 66
Definitely experienced this as well....only with summer tires (pss). Havent experienced with my winter setup. Only when full lock in reverse backing out and only when cold. It does sound like a mechanical clunk...like a knuckle popping out and back in sorta thing.
12-01-2016, 11:50 AM | #4 |
Rep 1,151
hi all ..yes exactly what you guys describe... my old e92 used to do similar but this is much worse. Its just starting to get lot colder in the uk. i am running Mich pilot super sports..u think thats what it is a slip...its all i could think off as when warmed up and driven 10 min up road didnt do it.
12-09-2016, 03:07 AM | #9 |
Rep 4,522
Lee,
Its normal and a feature of the cars "Ackerman" geometry. http://www.babybmw.net/viewtopic.php...erman#p1195880 Daniel, Brake clunk - again typical with these caliper / pads - pads can move radially slightly - nothing to be concerned about. BP
Current '22 X3M LCI.. |
Taunto281.50 |
01-27-2017, 06:01 AM | #11 | |
Rep 1,151
01-27-2017, 06:25 AM | #12 | |
Rep 4,522
If it's bugging you, then yes go to the dealer to take a technician out for a test drive to replicate the problems and see what he says. BP
01-30-2017, 04:37 AM | #13 |
Rep 1,151
will only do from cold so if i go to dealer sound gone. ive replaced all tyres now with new super sports, not noticed as bad..but not been as cold.
01-30-2017, 09:06 AM | #14 |
Rep 4,522
"Akermann" geometry related clunks/noise will be exaggerated by cold tyre sidewalls. Less evident when tyres are warm.
Taunto281.50 |
02-07-2017, 09:31 PM | #15 |
Rep 27
Took mine to the dealer, as I've owned BMWs since 1991, and the only time you should get clunks in the suspension is when something isn't right. Turns out strut bearings at top were faulty -- as were the second set that they replaced them with (they noticed immediately and ordered another set). There is a difference between clunks and scrubbing of tires.
02-08-2017, 03:58 AM | #16 | |
Rep 1,151
02-15-2017, 03:08 AM | #17 |
Rep 1,151
Well Went In They Replaed A Few Bits Under Warranty Including Squeaking Seat Base New Rear Door Boot Lock And Suspension Mounts Or Something
05-22-2022, 07:51 PM | #18 |
Rep 16
05-26-2022, 04:51 PM | #19 | |
Supreme Allied Commander
3875
Rep 54,430
Drives: F80 M3
It's a good idea to remove and clean the contact surfaces of the pad to caliper/caliper holder once year or two. This is a great product we use at our shop since 2005. We have yet to find anything else that works better. It's also under Molykote, but the MB version is much less expensive. https://www.amazon.com/Genuine-Merce...&creative=9325 |
