2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum 2 Series Active Tourer Discussions Mirco filter replacement
      07-02-2016, 10:40 PM   #1
fionbank
Drives: 218i
How long does it change? 1 year?
      07-06-2016, 01:50 PM   #2
Pparana
Drives: 2015 m235i
I did mine last week at 12k, was pretty nasty. Geuss depends on how, where you drive
      08-06-2016, 04:40 AM   #3
fionbank
Drives: 218i
Great, u did it! Is it easy to replace? I am still looking for where is it locate.!
      11-24-2016, 12:16 PM   #4
stevekwok
Drives: 220i active tourer
It's in the middle between the legs of the driver and passenger.
      12-15-2016, 05:02 AM   #5
fionbank
Drives: 218i
Thanks Steve, i will try to find it out in this Christmas hoilday!
      12-20-2016, 12:20 PM   #6
Pparana
Drives: 2015 m235i
That should cover it. Pretty much the same.
      09-12-2017, 01:32 PM   #7
DocH_NWP
Drives: 2GT (F46) 218d Lux Auto
Recomended to be done with any oil change.
On my GT (MY16 - UK RHD) it was as follows:
Remove panel on left of driver's footwell (T20 TORX - single).
The panel comes away with the footwell light attached.
Reaching towards the far end of the footwell on the left wall, you feel/see a small flap. Push that back and the microfilter cover opens up. You can see the top filter and a little of the lower filter (unlike the 320 above, there are TWO filters sitting one above the other). Using longnose pliers, get the first one out, then manoeuvre the lower one up and out. It's a bit fiddly and you may find it better to lie across the front seats with your head in the footwell.
Replacement is the reverse, making sure you take note of the airflow arrows on the ones you have taken out. Put the first one in, then push it down so there is room for the second one to go in on top.
I got mine for £11 a pair (active charcoal ones from Bilstein) from Mister Auto.
http://www.mister-auto.co.uk/en/poll...ADB112512.html
Took 10-15 minutes in total.
