2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning Turbo inlet pipe upgrade
      06-08-2016, 10:16 AM   #1
Bee Pee
Bee Pee's Avatar
United Kingdom
1779
Drives: AW M2 DCT
Reading thru BryanF22 thread about CP's, post # 15 got my attention:-
http://www.2addicts.com/forums/showp...2&postcount=15
The stock inlet pipe - item 1 in the picture above - is common, to both PWG and EWG cars and it tapers to the stock PWG compressor wheel size. Great for PWG cars and despite EWG turbos having a larger compressor wheel, it appears BMW reused the same inlet pipe from old turbo.
To conclude then, for EWG cars, the connection at compressor housing is smaller than the compressor wheel. I had hoped the equivalent M2 part would be an OEM upgrade ie less / no tapering suited to larger inlet of the EWG turbo. Alas, M2 shares the same part.
I have read Pure hi flow inlet pipe is a canny upgrade as it opens up the diameter of the inlet pipe allows the EWG turbo to breathe more easily ie lower PWM values to achieve the same boost levels.
Any tips/go-bys on DIY install of Pure hi flow inlet pipe most welcome.
Thanks in advance,
BP
Current '22 X3M LCI..
      06-08-2016, 10:36 AM   #2
Luminous
Luminous's Avatar
743
Drives: 2019 M5 Competition
I'm not sure how useful the larger inlet pipe will be on a stock turbo. If you upgrade to a larger turbo I would highly recommend it to take full advantage of the turbo.
Edit: also I would recommend purchasing the preassembled unit from pure, otherwise you'll need to cut and glue your stock inlet.
2019 SG M5C
2015 SO M3 6MT
2015 BSM M235xi
      06-08-2016, 10:40 AM   #3
Mywifes335
Mywifes335's Avatar
Drives: 2014 FBO M235i
Hey man, I heeded your advice. I got that AND the dv+. The waiting time for delivery of the PS2 is palpable to say the least.
Originally Posted by Axius View Post
Why the sad face, I fucking love sausage.
      06-08-2016, 10:45 AM   #4
Luminous
Luminous's Avatar
743
Good call. The stock DV would definitely leak or tear eventually and it's much easier to upgrade while you're doing the turbo.
How long is the current wait from pure?
2019 SG M5C
2015 SO M3 6MT
2015 BSM M235xi
      06-08-2016, 11:03 AM   #5
Bee Pee
Bee Pee's Avatar
United Kingdom
1779
Drives: AW M2 DCT
Luminous,
Yes I plan to go for option 2.
I've read folks have seen drops in PWM whilst maintaining same boost levels on EWG cars with stock turbo.
There's definitely merit in opening up the inlet side even for stock EWG users.
Any standalone retrofit install threads on here or PDF of the PURE install instructions to have a look at ?
Cheers,
BP
      06-08-2016, 11:06 AM   #6
Mywifes335
Mywifes335's Avatar
Thanks! Delivery before 26th... So just over 2 weeks...
      06-08-2016, 12:16 PM   #7
Drpoomanchu
Drpoomanchu's Avatar
Drives: AW M235i Man FBO
Luminous,
Cheers,
BP
I am interested in this as well...
      06-09-2016, 12:52 AM   #8
FrankiE90
FrankiE90's Avatar
Drives: Krooked Sk8board
Not easiest install. If building n55 w turbo and fuel upgrade maybe look into. But the cost per HP may not make sense compared to say N54. Inlet install would be a conversation to say u did it to a n55. Rather save and spend money on nicer suspension for example.
FrankiE90 AKA:.[The TANK] *CLICK THE SIG
E90s (been gone but not forgotten) • KW clubsports • • • • • • • • • • 18" BBS GT4 // Build E30 (pending) + E46 M3 Wagon ESTORIL Blue
      06-09-2016, 01:18 AM   #9
Bee Pee
Bee Pee's Avatar
United Kingdom
1779
Drives: AW M2 DCT
My cars chassis (suspension and brakes) already sorted.
Oem inlet on EWG is actually tapered so the bore of the pipe (at the coupling to turbo inlet) is smaller and so creates a restriction as far as flow into the compressor side of the turbo. Fitting the pipe with large bore will remove this restriction allowing better flow, less load on the turbo and improved throttle response.
      06-12-2016, 02:10 PM   #10
bryan_G01
bryan_G01's Avatar
1165
Drives: like i stole it...
I upgraded all the piping because i didn't want to have the other hoses bust under pressure like the CP did.
The piping from ER for the FMIC is much bigger than stock. maybe 1/4 to 1/2 inch larger so more air does flow.
i think its a great upgrade for any car, more air, better cooling.
Great product by ER.
www.nybmwcca.org
Current Cars:
Jpup26.00
      06-12-2016, 04:30 PM   #11
Drpoomanchu
just curious how much time did you have in the install of the pre-intercooler piping. how difficult was the install ? debating on just ordering all the piping and installing with the FMIC.
      06-12-2016, 06:01 PM   #12
JQuach07
Drives: m235i Alpine White
Very easy to install from the bottom with charge pipe. Turbo piping is pretty freaking hard. If you do turbo piping might as well do DV+ same location
      06-12-2016, 08:15 PM   #13
bryan_G01
bryan_G01's Avatar
1165
drop front bumper and intercooler as well as intake.
Everything is right there. I had a shop do it with a lift, took 3 hours.
www.nybmwcca.org
Current Cars:
      06-14-2016, 11:09 AM   #14
quenotte
France
60
Drives: F87N M2 Competition
Installation of Pure high flow inlet pipe should not be difficult.
I've installed Turbo to FMIC and FMIC to TB charge pipes (ER ones), GFB DV+, Wagner Evo2 Comp FMIC and to my mind, pure inlet installation should be a piece of cake compared to DV+ installation...
I'm also interested in installing this Pure Inlet pipe.
But I'm waiting for Victor to manufacture SS spacers for F8x TS install... One thing at a time
      06-14-2016, 11:53 AM   #15
Bee Pee
Bee Pee's Avatar
United Kingdom
1779
Drives: AW M2 DCT
Quenotte,
I hope so but cant find any DIY install instructions/how to anywhere.....
BP
      06-14-2016, 12:05 PM   #16
quenotte
France
60
I will check with ISTA but to my mind there is only one bolt that maintain it.
Darkiedm4 installed it on his car so he may confirm
      06-14-2016, 01:10 PM   #17
PeterPure
PeterPure's Avatar
Belgium
677
Drives: BMW F80 M3
2017 BMW F80 M3  [0.00]
Inlet pipe is easy. Remove intake pipe that goes to airbox. Remove 1 vacuum? Line that connects to lower inlet part. There is indeed 1 bolt that needs removing on the inlet/compressor housing. Then pull lower inlet out of compressor housing. To install new pure inlet you dont reuse the bolt. The inlet pipe has 2 or 3 o rings that keeps it in place. All can be done from top of the car.
      06-14-2016, 02:10 PM   #18
quenotte
France
60
Darkiedm4, are you sure that you don't bolt it with pure inlet?
Bolt fixation is still there
      06-15-2016, 08:39 AM   #19
quenotte
France
60
I've ordered Pure high flow inlet from Mike@N54Tuning.com
Hope to receive it soon
      06-15-2016, 10:16 AM   #20
Bee Pee
Bee Pee's Avatar
United Kingdom
1779
Drives: AW M2 DCT
Post from another forum - seems like its definitely worth doing for EWG cars to take out the restriction at the compressor wheel side of the turbo....
Pre inlet:
Post inlet:
PWN/duty cycle can be seen to be lower post Pure inlet fitting. The difference roughly equates to 1psi of boost from what I have seen but I'll look to get a log showing this once I have boost dialled in a bit better .
      06-15-2016, 04:25 PM   #21
Daleb
Drives: M2
As darkiedm4 says its as simple as that, once you are doing it and see it in front of you it makes sense.
There are 2 bolts in total, one that joins the oem inlet to the turbo compressor housing and another that connects further up to the head (its pictured in the above pure inlet photo). You only reuse the one in the photo. The bolt connecting it to the compressor housing needs to be accessed and removed from below.
The above logs that bee pee posted are mine and that is my initial findings. I have a stage 2 LPFP and TBI so I'll look to push the stock EWG turbo to see what it can do....the inlet will certainly help me!
      06-16-2016, 09:03 AM   #22
PeterPure
PeterPure's Avatar
Belgium
677
Drives: BMW F80 M3
I meant the bolt to compressor housing. The above one you reuse indeed.
