03-22-2019, 08:48 AM | #201 |
Rep 151
05-05-2019, 04:21 PM | #202 |
Rep 503
Yesterday I had these put on:
BEYERN RITZ Gloss Gunmetal with Brushed Face (18" x 8.5", +35 Offset, 5x120.65 Bolt Pattern, 72.6mm Hub) PILOT SPORT PS2 Tires (93617) by Michelin®. 225/40ZR18 BEYERN RITZ Gloss Gunmetal with Brushed Face (18" x 9.5", +45 Offset, 5x120.65 Bolt Pattern, 72.6mm Hub) PILOT SPORT PS2 Tires (45327) by Michelin®. 255/35ZR18 |
05-10-2019, 03:31 PM | #203 |
Rep 25
Just got these fitted today.
19" OZ Leggera HLT in gloss black. 225 front, 255 rear. Nothing too ballsy. Just a nice clean fit. I'd like to put springs on my car next but the front splitter is already really low. Last edited by unrealeck; 05-10-2019 at 03:39 PM.. |
Anubis8049.00 |
05-11-2019, 04:06 AM | #204 | |
Rep 61
05-11-2019, 10:26 AM | #205 |
Rep 25
06-11-2019, 10:35 AM | #206 |
Rep 124
Hope Instagram pictures are allowed as it just makes it that much easier to post a photo!
This is on Dinan Springs and Bump stops with the front fenders rolled as well. |
06-25-2019, 03:54 PM | #207 | |
Rep 4
Did you get the springs? I like these wheels A LOT! |
07-27-2019, 08:09 AM | #210 |
Rep 8,942
Not my F23 but wanted to recommend Vorsteiner. These are 105s on my F31 but they also make 108s in a 2-series fitment. Not crazy $ either think around $1500 for a set in standard finish $2000 in custom for the 108s.
08-16-2019, 01:39 PM | #213 | |
Rep 76
08-21-2019, 10:02 PM | #214 |
Rep 10
whats the width and offset? are you on stock suspension?
2016 M235i Esoteril Blue xDrive
08-28-2019, 08:49 AM | #215 | ||
///AMG Killa
17
Rep 44
Front: 19x8 et45 235 Rear: 19x9 et48 255 And yes stock suspension, for now
2015 BMW M235i 6MT
09-14-2019, 05:16 PM | #216 |
Rep 167
10-27-2019, 09:56 AM | #217 |
Rep 2,870
OZ Allegerita 18x8et40 and 18x8.5et40
Bridgestone Potenza s007A in 225/40 and 245/35r18 The BBK really added weight, coming up from the base 228 mini-brakes. These take off 4 or 4.5# per wheel, compared to factory 18's with Conti ExtremeContacts. Despite being a 'softer' rated tire, the Potenzas have held up much better to track use than the Conti's did - I think it is a stiffer carcass, so it doesn't eat the outside edge nearly as badly. Basically the same tread pattern as the Conti/MPSS, so it does about as well in heavy rain too. |
10-27-2019, 06:59 PM | #218 |
Rep 925
Apex EC-7
19x8.5et35 19x9.5et43 Falken FK510 225/35/19 255/30/19 M Performance Springs (10mm) No camber adjustments, no spacers, no rubbing whatsoever, very slight rear poke!
2016 M235i | BSM | 6SPD | BMS JB4 | Dinan Intake | Wagner Evo 2 Comp IC | VRSF DP | ER CP | Dinan Exhaust | M Performance LSD | M Performance Springs
Gone: 2016 F30 340i, 2015 Corvette Z06, 2011 E92 335i, 2007 E92 335i, 2008 Corvette Z51, 1999 E46 323i, 2001 Boxster, 1999 Carrera 2, 1997 Corvette, 2001 Camaro SS |
MarkDemma519.00 |
10-28-2019, 11:10 AM | #219 |
Rep 503
11-13-2019, 06:52 AM | #220 | |
Sleepy
Rep 53
