05-03-2016, 08:00 PM | #1 |
Rep 1,931
Tire bake off
www.nybmwcca.org
05-03-2016, 08:41 PM | #2 | |
Rep 1,422
So I again ask the question to BP, what's a better, grippier tire than the PSS in 235/40-18 and 265/35-18? I've already been warned against the Toyo Proxes R888 for street use. Thinking of the RE-71Rs given cheaper relative cost and reviews. Anybody have experience with the RE-71Rs? |
05-03-2016, 08:58 PM | #3 | |
Rep 5,262
They are a bit loud for the street I had them for a few weeks while I was waiting my alignment appointment and they were noticeably louder like you hear like a buzzing sound |
05-03-2016, 09:09 PM | #4 | |
Rep 1,422
I miss the days of buying used track tires on the cheap and using them for 2 or 3 track days. Ran Hankooks and Hoosiers! So sticky. So not forgiving. |
05-03-2016, 09:38 PM | #5 |
Rep 5,262
05-03-2016, 09:44 PM | #6 |
Rep 1,422
But you'd recommend them? You've driven stock PSSs.... How do they compare?
05-03-2016, 09:54 PM | #7 | |
Rep 5,262
Also on the first track day with PSS and without LCA the shoulders got killed.... The RE-71R shoulders didn't break a sweat but I was already running the LCA... RE-71R sidewall seems much stiffer so it will let you run lower PSI without destroying the shoulders next time I'll probably run 34F 32R cold I estimate about 15 events as I have 3 on now and about 80% tread left For the street I would use PSS cause they are quieter.... for the track the RE-71R.... If I had to pick one for mix street-track is really tough... just buy a dedicated set PSS is a 300 rating tire and RE-71R 200 so they will wear faster |
05-04-2016, 08:20 AM | #8 |
Moderator
123
Rep 281
The PSS is without a doubt the best option for the street. Smooth, quiet, very good in the wet, sticky in the dry. With all that performance, it still wears better than most.
The RE-71R is really designed as a auto cross tire. This tire heats up very quickly and can throw down some very fast times. While it can be used for track days, it does not handle the higher temps as well as the R888 does. Like most "extreme performance" tires, if you continue the to push the RE-71R on the track it will over heat and the performance will start to drop off. Once the tire gets this hot, it will begin to wear very quickly. This would be a good tire for someone who just having fun and uses their car for auto-x, track, driving and street. While it can do everything well, it really is best for quick auto-x sprints. In my opinion R888 is a better match for someone who is looking for a dedicated track tire and still wants decent tread life. The R888 will handle the higher temps for a longer period of time. |
05-06-2016, 10:26 AM | #9 |
Rep 1,931
for track only its a really different story.
The pilot cups, the trofeo, hoosiers and bridgestones are all good. I liked the starspec for rain.
www.nybmwcca.org
05-06-2016, 12:53 PM | #10 | |
Rep 5,577
Do you think the front tires are just about identical or are their variations that are noticeable either driving, wear or noise ? |
05-06-2016, 01:47 PM | #11 | |
Rep 1,422
And would the RE71R outperform the PSS on the track? Road course, not autoX. Thanks! |
05-06-2016, 02:02 PM | #12 | |
Rep 845
Also, of course, Dunlop ZII Star Specs. Great tires, but a little loud, and quite unforgiving.
05-06-2016, 02:04 PM | #13 | |
Rep 1,422
Both > than PSS? |
05-06-2016, 02:05 PM | #14 |
Rep 845
For track use? Definitely.
For street use? No. Both are quite loud and don't have great wet traction.
05-09-2016, 08:32 AM | #15 | |
Moderator
123
Rep 281
The RE-71R is definitely stickier than the PSS. It would outperform the PSS is just about every handling situation. Although there are some disadvantages: wet traction, ride quality and tread life would all be lower than the PSS. The RE-71R is designed to be as close to a R-compound tire, while still being street legal. So you can drive these on the street, but be aware, it will wear quickly, it will ride stiffer, and it will not provide as good of wet traction. |
05-09-2016, 09:27 AM | #16 | |
Moderator
123
Rep 281
With this car or any BMW's, the BMW star rated tires are OE spec. We are told that BMW works with the tire manufacture to develop a tire that works best with that certain BMW model. Unfortunately, they do not tell us what they do to change the tire. If you are replacing less than 4 tires, I would recommend matching what is on the car. If you are replacing all 4, I see no real problem going to the non-star tires. |
05-09-2016, 09:30 AM | #17 | |
Rep 1,422
Thanks Keith, you definitely addressed one of my key concerns about the RE71R, the quick wear. I also saw you guys carry the Direzza Star Spec, and the reviews seemed better than the RE71R. What are your thoughts? |
05-09-2016, 09:32 AM | #18 | |
Moderator
123
Rep 281
If you are concerned with tread life, I would stick with the PSS tires. |
05-09-2016, 10:33 AM | #19 |
Rep 1,541
My last couple sets have been RS3 as my go to street/track tire, but I'll be trying the Kumho v720 next.
I think the Rs3 is a last gen tire now. |
05-09-2016, 02:40 PM | #21 |
Rep 1,422
Ok guys, Liquidpaper , bryan_f22 , pikcachu , keith@tirerack thanks for your help.
Based on your responses, I think I'm between the RE71R and the Direzza Star Specs. From the Tirerack customer reviews, the Star Specs seem to wear better and more evenly without giving up too much in performance versus the RE71Rs. In fact, sounds like the Direzzas are better under extreme heat? What do you guys think? I am aware these will be louder and I'm sacrificing wet traction. However, I'll be in DFW and seldomly driving in the rain. Grip is key. Need to get power to the ground. |
05-09-2016, 02:44 PM | #22 |
Rep 1,931
re71... lots of goodness in these tires if you don't mind the noise.
Starspecs are great too.
www.nybmwcca.org
