2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions coding DSC to make your F-series fun...
      02-28-2016, 08:48 PM   #1
rwalker
Drives: the wheels off
I've spent the afternoon trying to adapt information in this superb blog entry to the F-series.
My car is a 2/2014 build M235i 6MT with a Quaife LSD.
What I've got so far. These are all DSC => 3000 nodes.
Engine Power Reduction to Prevent Brake Disc Overheating (FLR)
Brake Fading Compensation (HPS)
C_Funktion_Fadingkompensation_aktiv_I
activ => nicht_activ
Hydraulic Brake Assist (HBA)
Brake Standby (EVB)
C_Funktion_Bremsbereitschaft_aktiv_I
Maximum Brake Support (HVV)
Dynamic Performance Control (FDB)
C_Funktion_FDB_GMV_aktiv_I, already nicht_active (likely owing to the fact that I'm RWD?)
Electronic Differential (AX_Ref_Diff_Lock)
C_Funktion_Differenzialsperre_aktiv_l
I'd appreciate help filling in the blanks (where applicable) and correcting errors. Thanks for reading!
      02-28-2016, 09:00 PM   #2
rwalker
By the way, in the process of the above, I noticed my car is coded for the 370/30mm rotors in front even though the car wears 340/30mm from BMW.
      02-29-2016, 01:41 PM   #3
Pparana
Drives: 2015 m235i
interesting, I have not noticed a drop off in lap time as in that article. Let me know how your car does or feels, might give some of these a go.
      02-29-2016, 01:47 PM   #4
rwalker
Were you able to map all of the F25 actions to your F22? Can you fill in the blanks or point us to a thread where they're already filled in?
The one I'm really on about is e-diff, which I perceive to be braking/pulling power in tight corners and middling throttle inputs. That is, I've noticed that when unwinding the wheel under constant throttle there's a noticeable kick when the wheel gets straight. This is more of a street-driving issue, but I should be able to tell if there's any difference on track as well.
      02-29-2016, 01:57 PM   #5
Liquidpaper
Liquidpaper's Avatar
Drives: '15 M235i
2015 BMW M235i  [0.00]
This is awesome. I need to code these in. Was it hard?
      02-29-2016, 02:12 PM   #6
rwalker
the terminology is tedious, and the tools are brittle, but otherwise it was a doddle
      02-29-2016, 02:39 PM   #7
Liquidpaper
Drives: '15 M235i
Okay, well I know my way around a computer reasonably well, so I'll take a crack at it. Besides, I know pikcachu has a great cheat sheet on this.
      02-29-2016, 04:08 PM   #8
Poboy
Drives: 2016 M235i
I notice this exact sensation on a daily basis, can you comment on whether the coding fixed this or not?
Thanks,
      02-29-2016, 04:29 PM   #9
Pparana
Drives: 2015 m235i
I suppose I wrote that ambiguously, I have not done any of that coding yet. I will try for this weekend, I am at sebring a week later for 2 days open track and can see if any of it effects the feel.
      02-29-2016, 04:30 PM   #10
Pparana
Drives: 2015 m235i
The coding is pretty easy, just watch the tutorials.
      02-29-2016, 04:57 PM   #11
rwalker
it's hard to be sure I'm witnessing the absence of this issue, because I haven't been rigorous about recreating it, but I will certainly report on my findings...
so far, I only have a short commute under my belt with this coding in place
      02-29-2016, 05:40 PM   #12
pikcachu
pikcachu's Avatar
1403
Drives: M235i (F22 Red angel)
e-diff doesn't pull power off... just apply brakes to the spinning wheel ala LSD
Also be careful with the stuff you change on the DSC as it's not like you are just turning off a warning message for navigation...
      02-29-2016, 05:41 PM   #13
pikcachu
pikcachu's Avatar
1403
where do you see rotor size ?
      02-29-2016, 05:43 PM   #14
pikcachu
pikcachu's Avatar
1403
thresholds for the brake disk overheating might be different in our cars so you might never hit it...
      02-29-2016, 05:46 PM   #15
rwalker
it's called "front brake rotor config" or some such... I don't have it here in front of me, sorry.
      02-29-2016, 05:48 PM   #16
rwalker
pikcachu, does your cheatsheet cover FLR for the F-series?
      02-29-2016, 05:52 PM   #17
pikcachu
pikcachu's Avatar
1403
No, never dug too much into the DSC ecu
      02-29-2016, 05:53 PM   #18
pikcachu
pikcachu's Avatar
1403
ok... i'll do a search... is this on the DSC cafd ?
      02-29-2016, 05:54 PM   #19
rwalker
yep, towards the top of the 3000 section
      02-29-2016, 06:00 PM   #20
pikcachu
pikcachu's Avatar
1403
ok... looked quickly but couldn't find it.
When you can get to the exact variable name post it so I can take a look.
Thanks
      02-29-2016, 06:29 PM   #21
rwalker
will do
      02-29-2016, 07:11 PM   #22
Pparana
Drives: 2015 m235i
Pika has me thinking twice about these, while the brake one does not bother me, I never felt any issues with the e LSD and my LSD. I'm thinking they may have more issues with X1 which is awd and a cuv. I've had the car in some pretty ridiculous slip angles. I may want the e LSD on road for some unforeseen emergency.
Edit,
E LSD is only on with all the traction control disabled (as much as we can) so I will code it off.
