02-25-2016, 05:09 AM | #23 | |
Rep 4,515
Pictures [before yesterday's brake upgrade]
Current '22 X3M LCI.. |
02-25-2016, 05:26 AM | #24 | |
Rep 4,515
Fronts - were items 9, 10, 11 and 12 on the attached http://www.realoem.com/bmw/enUS/show...diagId=34_1992 Wrt pads, you can go for item # 8 and I got a deal on a set of F8x MP front pads 34112284765.
02-26-2016, 10:00 AM | #25 |
Rep 199
Hi BP,
Did you get all the hardware used? I was compiling all parts to do the conversion: With brand new parts, to change front calipers, front disc protection plate, 4 drilled M Performance discs and pads: Code:
1 Caliper housing left 34 11 6 799 469 614,83 € 614,83 € 1 CALIPER HOUSING RIGHT 34 11 6 799 470 614,83 € 614,83 € 4 Hex Bolt (chrome-free CR(VI)) M12X1,5X43 ZNS3 34 11 6 772 117 3,17 € 12,68 € 1 Repair kit, brake pads asbestos-free 34 11 6 878 876 211,95 € 211,95 € 1 Brake pad wear sensor 34 35 6 789 440 22,32 € 22,32 € 2 Brake disc, ventilated, w/holes, front 370X30 34 10 6 797 603 229,85 € 459,70 € 2 Inner hex bolt M8X14 34 21 1 161 806 0,90 € 1,80 € 1 Protection plate left 34 11 6 872 081 30,94 € 30,94 € 1 Protection plate right 34 11 6 792 238 30,94 € 30,94 € 8 Hex Bolt (chrome-free CR(VI)) M6X12-Z1-8.8 MK 34 11 6 772 886 0,63 € 5,04 € 0,00 € 1 Repair kit, brake pads asbestos-free 34 21 6 876 422 141,74 € 141,74 € 1 Brake-pad sensor, rear 34 35 6 792 292 28,49 € 28,49 € 2 Brake disc, ventilated, w/holes, rear 345X24 34 20 6 797 598 144,85 € 289,70 € 2 Inner hex bolt M8X14 34 21 1 161 806 0,90 € 1,80 € 0,00 € 4 Brake-pad paste (BMW Group) 3G 83 19 2 158 851 0,75 € 3,00 € 2 469,76 € M Performance Big Brake Kit in red: Code:
Leebmann24 Leebmann24 1 Retrofit kit, sport brake, red 34 11 2 221 445 1 749,00 € 1 749,00 € 2 Brake disc, ventilated, w/holes, rear 345X24 34 20 6 797 598 144,85 € 289,70 € 2 038,70 € It's 400€ cheaper with rear calipers on top of the rest! Even with used front calipers, Red BBK is very well placed price-wise. But MPBBK is in red, yellow or orange and my car is EBII... |
02-26-2016, 01:11 PM | #26 |
Rep 812
That was my argument. The kit seems like a bargain given that you can sell your blue callipers back out.
Ground Control Camber Plates, Ferrodo D2500 w/ E86 MZ4 2 piece rotors, Dunlop Direzza ZII on Apex EC-7s
02-27-2016, 05:32 PM | #27 | |
Rep 4,515
Pads, protection plates, discs and wear sensors - all new. I also added braided steel hoses and RBF - came in much cheaper.
02-29-2016, 04:59 PM | #29 |
Rep 4,515
02-29-2016, 05:02 PM | #30 |
Rep 1,084
03-01-2016, 03:31 AM | #31 |
Rep 4,515
These look good value for anyone stateside looking to upgrade - a pair of 370mm calipers and pads for 620 bucks...:-
http://f20.1addicts.com/forums/showthread.php?t=1231761 Also the thread has a great photo to illustrate the difference between 340mm caliper [top] and 370/380 MP BBK/F30 msport/F8x std front caliper [bottom]
Current '22 X3M LCI.. Last edited by Bee Pee; 08-17-2016 at 12:35 AM.. |
03-07-2016, 08:43 PM | #32 | |
Rep 1,084
The part numbers on these calipers appear (I scanned the bar codes on the back) to be 34116799467 and 468, which appear in no ETKA. Did you verify the part numbers of the calipers you installed? Thanks, Rob |
03-08-2016, 02:39 AM | #33 |
Rep 4,515
Hi Rob,
I didn't scan them TBH so can't verify the part numbers you quote. Looking at the markings embossed on your calipers they look the same as mine. BP
03-22-2016, 04:23 AM | #35 |
Rep 4,515
Not really - I got OEM MP BBK upgrade for less than 1/2 the cost.
03-22-2016, 10:41 AM | #36 | |
Rep 812
And if u consider selling those old 340mm calipers out to 228 owners, then it might even be less than $1k. Total steal
03-22-2016, 11:15 AM | #37 | |
Rep 1,084
$700 for used calipers, pads, and clips (same vendor as Bee Pee) $600 for new 370mm rotors (blank face, not drilled) well under $1.5k... |
04-02-2017, 12:31 AM | #38 |
Rep 82
so those are the stock m sport calipers ?[/QUOTE]
To confirm you fit the larger Mperf 370mm rotors on the front stock M235i caliper without issue?
@theyoungcarmody
2015 m235i track edition PTF / Bm3 n55 dev car / brand ambassador Cscs time attack - street rwd Who says a race car can’t also be a show car?!?! |
04-02-2017, 12:37 AM | #39 |
Rep 5,262
04-02-2017, 07:13 AM | #40 |
Rep 1,084
F2X front calipers will not work on 370mm rotors. You need front calipers from the F8X, which are the same as the M Performance calipers for the F3X.
04-03-2017, 04:35 PM | #41 |
Rep 4,515
Pika - 100% correct
04-04-2017, 05:14 PM | #42 |
Rep 2,214
Any place online to grab the F3x M-Sport Calipers new, without getting a$$ r@ped? If there were any on the classifieds I'd scoop them up, but not having much luck lately. Missed out on Rob's set...
D
04-05-2017, 08:24 PM | #43 |
Rep 111
After research and test on my 235 and friends 228 I don't think there is a real improvement between 340 kit or 370 kit.
Only improvement is 30mm diameter which make a longer torque distance. The weak point of this break sets I believe is disk, everybody changed pads but the fixed solid disk really making some issue when it get heated. Get a floated disk, thats make the new world. |
