02-11-2016, 08:59 PM | #1 |
Rep 444
19x8.5 ET35 19x9.5 ET40 235/265 Set Up
*Update*
I've had this set up for a little over a week now and still have no issues. I have yet to rub my front or rears, and it's nice to know that if I run into any rubbing I can just roll the front fenders, but I don't think I will have to. Also, my M4 LCAs have finally arrived so I will be putting those on, which will give me some front camber, and an alignment will probably give me some rear camber as well. Finally got them put on and they fit fine. No rubbing. No issues of any kind. No cutting, rolling or anything else. Multiple vendors on here wanted to upcharge me 500+ dollars for "correct" offsets, but after doing the math, decided that the factory offsets would fit, and they do. There is a little bit of poke, but a lot of cash in my pocket for other mods. Here are the specs. Advant Garde M510s 19x8.5F +35ET 235/35/19 19x9.5R +40ET 265/30/19 Wrapped in Michelin Pilot Super Sports. Factory Suspension. It's dark out now and I'll take some better pictures tomorrow.
Quickest Stock Turbo F8x In The World
02-11-2016, 09:31 PM | #3 |
Rep 444
Yeah, on my scale the fronts were 26.1 pounds and the rears were 25.3.
I believe the MPSS weigh in around 25 pounds. A little heavy, good thing we got those Kosai track tires.
02-11-2016, 09:34 PM | #4 | |
Rep 5,262
ya those are about 10lbs heavier than the Kosei's |
02-11-2016, 10:29 PM | #6 |
BMW Lover
122
Rep 251
02-11-2016, 11:07 PM | #9 | |
Rep 444
The rears, I don't see how it is possible to rub on factory suspension. The 19s only added about 0.4 inches of height, so only 0.2 closer to the top of the wheel well. I still have over 2 inches of clearance, and when I put 3 people (almost 700 pounds) in the rear, the suspension sagged like an inch. The fronts on the other hand, if I had any higher offset, they would probably rub on the strut. My finger could fit between the gap, and that was it. I'd say around 3-5mm max of space. A +40 in the front would probably hit the suspension with 235/35/19.
02-11-2016, 11:07 PM | #10 | |
Rep 5,262
http://www.willtheyfit.com/index.php...et2=40#content rear looks really wide |
aarwilli14.00 |
02-11-2016, 11:09 PM | #11 |
Rep 444
Your front ET is 10mm closer to the suspension then mine. Along with the 19" being slightly taller, meaning the clearance is slightly higher since the strut is angled.
02-11-2016, 11:12 PM | #12 | |
Rep 444
http://www.wheel-size.com/calc/?whee...=30mm&scl=51mm I like how they diagram everything out.
02-11-2016, 11:22 PM | #13 | |
Rep 5,262
02-11-2016, 11:59 PM | #15 | |
Rep 1,422
02-12-2016, 12:02 AM | #16 | ||
Rep 5,262
02-12-2016, 12:34 AM | #17 |
Rep 444
Once the car was back on the ground, I grabbed the strut cover and tried to make it touch the wheel. Even with me trying to make them touch, probably had a good 15mm before it would. Makes sense since you have 58 and I have 40. I think a 5mm spacer would have saved you from cutting the plastic cover.
I agree with you that a 10mm spacer would most likely let you run 235s for your set up in the front.
02-12-2016, 12:36 AM | #18 |
Rep 444
Probably the same reason I had to go with my offsets. It's the closest they have in offsets that are mass produced.
02-12-2016, 05:18 AM | #20 | |
BMW Lover
122
Rep 251
I just wonder why nobody did this since the M235i is out since 3 years now , all Vendors say our max setup is 255 R and 225 Front ! |
02-12-2016, 08:14 AM | #21 |
Rep 219
I have 19x8.5 et40 with 235/35 and 19x9.5 et45 with 265/30... hankooks tho... and on H&R Springs
I'm 100% sure you'll will rub with those specs if you lower your car. My car rubs on the fronts, nothing on the back. |
02-12-2016, 08:53 AM | #22 |
Rep 329
Looks amazing! I have the same wheel setup and really want to get 235/265 when i need nee tires. Keep us updated of any rubbing issues.
Also, did you wrap your mirror covers and diffuser? Lol something i also want to do. Thanks |
