04-19-2015, 03:42 PM | #1 |
Rep 2,942
SOLVED - F22: The Great Radiator Controversy
Well, I've figured it out: the breakdown of which 2-series with M Sport bodywork (228i M Sport, M235i) have a second auxiliary radiator behind the driver's side lower air intake, and which don't have the radiator. The breakdown doesn't just affect 2-series; it's an F30 (3-series)/F32 (4-series) phenomenon, too ... but for those of us F22 M Sport owners missing the second aux radiator, well ... many of us appear to have been gypped out of fog lights.
Yes, yes: let me explain: First, thanks to the roughly 30 of you who participated in the VIN survey at this thread. The results crystallized the radiator-inclusion trends and led me to do research into the F30, which sealed the conclusions I've come to. (Second: for the initial explanation of the issue, see this thread.) For F22s with M Sport bodywork (I'm ignoring base and Sport Line cars; they are not affected), the general breakdown is this: - All Euro-spec cars (228i, M235i) have ONE aux radiator (passenger side). - All convertibles (228i, M235i) regardless of market have ONE aux radiator. - All U.S.-spec 2014 228i M Sport and M235i coupes have BOTH aux radiators. - All U.S.-spec 2015 228i M Sport coupes with the Track Handling Package, as well as all 2015 M235i coupes, have BOTH aux radiators. - All U.S.-spec 2015 228i M Sport coupes WITHOUT the Track Handling Package have ONE aux radiator. For the 2015 model year, there was a shift regarding the inclusion of the second aux radiator that applies to all 2-series, 3-series, and 4-series cars with M Sport bodywork: the determinant shifted from the bodywork to the M Sport Brakes. On 2015 2-series cars, the M Sport Brakes are part of the Track Handling Package. On 2015 3- and 4-Series cars, the M Sport Brakes are a standalone option -- and packaged with the ferric gray wheels/non-RFT summer tires that the 2-series' THP is also packaged with -- that's only selectable after M Sport line is selected. What tipped me off is the following passage from the F30/N20 Tech Guide (key phrase in red): "The cooling module itself only comes in one variant. An auxiliary radiator (in the right wheel arch) is used in vehicles used in hot climate markets and in combination with the maximum speed optional equipment." This passage is nebulous, but it plainly alludes to the second aux radiator and is direct evidence that for 2015, the determinant for its inclusion on cars isn't just M Sport Brakes -- it's the high speed-rated tires that come with the brakes. Before 2015, the determinant was merely choosing M Sport line. Here's the kicker: as many of us know, fog lights aren't available on 2-series M Sport models or the M235i. However, as discussed in this F30Forum thread, they re-appeared as standard equipment on 3-series M Sport models for 2015, but are deleted if the M Sport Brakes option is chosen. This is shown, both visually and informationally, on the bmwusa online builder for the 3 series. So the questions now become: why did BMW make this equipment shift for 2015 N20 and N55 cars? And why did those of us who own 2015 228i M Sport cars without the THP not get fog lights standard, even though the M Sport line package for the 2-series and 3-series includes pretty much exactly the same things?
04-19-2015, 04:55 PM | #2 | |
Rep 886
Oh, yeah. Now I remember. http://www.2addicts.com/forums/showp...16&postcount=5
04-19-2015, 06:43 PM | #5 |
Little Deuce Coupe
391
Rep 635
Drives: SO M2C
Great detective work, Mike.
That's not an inexpensive add-on, so not as trivial as some of the deletions BMW makes for different markets or model years. I guess the logic goes that non-THP cars and convertibles aren't likely to end up on the track. If it's demonstrably unnecessary, consider it weight saved off the nose and a couple less hoses to leak. If the single aux radiator cars go into limp mode on the track, then it's a cheapskate fail on BMW's part. I guess time will tell. I'm really surprised that BMW doesn't include these on Australian or Brazilian cars at all, which seems to be the case.
ex: 2004 Thermonuclear Yellow RX-8|6MT
ex: 2015 Estoril Blue M235i |6MT|slicktop|MP exhaust - PCD 2020 Sunset Orange M2C|6MT|Black 788s |
04-19-2015, 06:50 PM | #6 | ||
Rep 2,942
Personally I think it's crazy that the determinant is the one part of the car that's not warranted by BMW (and one that's easily and frequently upgradeable by the consumer), but what do I know? ...
04-19-2015, 07:02 PM | #7 | |||
Rep 886
Now, one thing I don't understand is that you say all M235i coupes come with it. The speed rating on the A/S tires that BMW supplies is only 130 mph and if you get the square all-season option on an M235i, you don't get the 840 option increased speed limiter, so you limit out at 130 mph as well as having lower rated tires. That would seem to contradict the above, unless you didn't get any submissions from A/S tired M235i or M235xi models in your data set.
Prior 40 years: 67 BelAir wagon / 68 LeMans Tempest / 70 Mustang Mach 1 / 72 El Dorado / 78 Corvette / 81 Subaru GL wagon 4WD / 83 s10 Blazer 4x4 / 85 Bronco 4x4 / 96 Bronco 4x4 / 04 Passat 4mo / 09 BMW 335xi Last edited by Zooks527; 04-19-2015 at 07:12 PM.. |
04-19-2015, 08:57 PM | #8 |
Mess Deck Commando
244
Rep 807
Kudos Mike! Appreciate you taking the time and getting this sorted for us. This information will serve a long line of current and future 2er enthusiasts.
///Sursum Ab Ordine
04-19-2015, 09:16 PM | #9 |
Rep 333
Drives: 228i
wish there was a way to test heat buildup on whatever component it was supposed to be cooling
04-19-2015, 10:13 PM | #11 |
Old Guys Rule
20
Rep 73
I have a 2014 M235 with high speed tires yet only have one radiator that's on passenger side. My car was ordered before being built for shipment to Tennessee.
04-19-2015, 11:58 PM | #12 | ||||
Rep 2,942
As for a square-setup equipped M235i: actually, I have two in the database, both 2015 xDrives. They do not have 0840 (meaning a 130MPH top speed), but they DO have both radiators.
04-20-2015, 01:04 AM | #13 |
Rep 1,091
Don't quite follow the logic: all EU M235is don't have the driver-side radiator (my doesn't either - production day March 30th, 2015), even though they come on Michelin PSSs and autobahnen in DE allow for speeds you Americans only can do on tracks. Why? I mean, I find front fogs very helpful, so the ideal config would be to have them plus an opening for the aux radiators on BOTH sides... BMW is clearly cutting the corners, I'm afraid....
previous: 2003 E46 330i SMG
04-20-2015, 02:41 AM | #14 | ||
Rep 886
With the convertibles now showing up without them, I'd bet one of the kids there will be a decontenting point coming up where tire speed ratings will start triggering it on 235 coupes. Quote:
04-20-2015, 04:56 AM | #15 | |
Rep 321
04-20-2015, 06:56 AM | #16 |
Rep 289
To be honest....don't care much for the fog lights as they would decrease the aggressiveness of the front end look on the M235i/228i M-Sport....
2014 M235i.Estoril Blue II Coral Red
2020 Jeep Grand Cherokee High Altitude 2021 X3M Competition.Alipine White.Sakhir Orange 2022 Jeep Grand Cherokee 4XE Summit Reserve (Current) |
04-20-2015, 07:41 AM | #17 | |||
Rep 4,976
The reason I ask is because my 2015 M sport without THP and M Sport brakes but with staggered summer RFTs does go up to 155... And I don't have the second Aux Radiator... I know this because I went this fast on an airstrip event by me with a gps.... Again maybe I was just confused when I read what you said... Could you break it down for me? Could it be that because mine are summer RFT that's why I didn't get it and would have gotten it with Michelin PSS? Because my limiter is definitely 155...
Wife's Car: 2020 X4M Competition, Alpine White on Black Alcantara and Biege
Current Car: 2018 F80 M3CS, SMB, DCT, ZEC, MPE Recently Departed: 2020 F87 M2C, LBB, ZEC, 6MT (Euro Delivery Aug. 29, 2019, totaled by an idiot in a Camry who then ran from the scene) Wife's Prior Car: 2018 F80 M3, Yas Marina Blue, DCT, Black 19s, Carbon Structure Anthracite Cloth/Leather Combination, Driving Assistance Package (Euro Delivery Oct. 9, 2017) |
04-20-2015, 08:10 AM | #18 | ||||
Rep 2,942
There are two others like ours in my database, which I'll post to this thread as a .pdf in the next couple of days.
04-20-2015, 08:12 AM | #19 | ||
Rep 2,942
04-20-2015, 08:25 AM | #21 |
Rep 242
04-20-2015, 09:14 AM | #22 | |
228i - 2015-03
13
Rep 66
I drive a 228i M Sport edition and got no auxiliary radiator at all. Fog lights are standard in my country on this model |
