2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum Headlights aimed too low?
      11-25-2014, 08:57 PM   #1
Demetrius Joel
Drives: 2014 BSM/CR M235i
2014 BMW M235i  [0.00]
does anyone else seem to have this problem? My headlights seem to be way too low. They only illuminate the ground in front of me and not even that far? Signs are out of the question until I'm right up on them. Are they designed like this for a reason?
      11-25-2014, 09:06 PM   #2
ska///235i
***** noob
ska///235i's Avatar
2006 325xi  [0.00]
Same here and theres no way to adjust like the E9x
      11-25-2014, 10:00 PM   #3
five3three
Drives: m2c
They're definitely aimed a bit on the low side. I have gotten used to it but nowhere near ideal at night.
      11-26-2014, 08:04 AM   #4
ska///235i
***** noob
ska///235i's Avatar
2006 325xi  [0.00]
Maybe coding can adjust the aim???
      11-26-2014, 08:17 AM   #5
Uridian
Uridian's Avatar
42
Drives: E36 M3, 228i M Sport
I've wondered the same thing recently. I don't get the road illuminated especially well unless I'm cresting a hill. It's sort of a bummer, but it's not all that bad I guess.
      11-26-2014, 08:33 AM   #6
nyeager
Drives: 2015 M235i xDrive
According to @BluF22 you can adjust. See this post. There are plastic screws under the hood near the lights/heatsinks. I haven't had a chance to change my aim yet but plan to do it over the holidays.
      11-26-2014, 09:21 AM   #7
ska///235i
***** noob
ska///235i's Avatar
2006 325xi  [0.00]
I want to give u a hug
Thx
      11-26-2014, 11:28 AM   #8
F80_M
Drives: 1/1 PSM F80, F36, G11
Thx
Will have to give this a try later. As much as I like to see things on the ground I do prefer to see it in a distance first
      11-26-2014, 09:30 PM   #9
Vervain
No_Country
398
Drives: .
Not sure if it's the same as the F30, but here is a thread with steps (with pictures) on how to adjust them:
http://f30.bimmerpost.com/forums/sho...php?p=12647423
Current:
2022 G01 BMW X3 xDrive 30d
2018 8U Audi RSQ3
2017 F55 Mini Cooper S
2015 F22 BMW M235i
      11-29-2014, 10:35 PM   #10
bman6074
Drives: 14 M235i and 07 Lotus Exige S
Did the adjustment screw work? I looked at my m235i and could not find the screw as shown in the picture. could that be a pic of a 228i or non xenon headlight?
EDIT: Never mind I found it.
      11-30-2014, 01:14 AM   #11
g18galvin
g18galvin's Avatar
34
Drives: Z4MR
Mine aimed too high after I dropped the car with h&r springs,
Had to lower it
      11-30-2014, 04:33 PM   #12
TB///M3
Drives: 16 ///M3
Its not the same as the F30.
Check the pic. You'll won't miss it.
Remember, clockwise aims down, counter-clockwise turns it up. For me, two full turns is perfect.
      05-18-2016, 12:32 AM   #13
jnu
Drives: 228i MSport Convertible
The up/down headlight adjustment for my Xenons is inside the big circle shown in this photo directly to the left of the "36" imprint. There's a white plastic screw inside the hole. As previously mentioned, counter-clockwise aims the lights up, and clockwise aims the lights down. Compared to the factory setting, I raised mine around 2 full turns counter-clockwise and I still think they're aimed down sufficiently to be safe and legal.
Appreciate 4
      05-18-2016, 08:19 AM   #14
bozman9
Drives: 2016 M235xi CV
Thanks for bumping this up and pic for reference. Seems easy enough.
Bozman
      05-18-2016, 08:26 AM   #15
Luddy
Luddy's Avatar
42
Drives: 2016 M235i xdrive EBII
I should check mine but seriously right now after going from a 2007 328xi with halogens (I did raise the level of those and they still weren't great) here was such drastic difference I didn't even think about it until I saw this thread.
      05-18-2016, 08:32 AM   #16
Killramos
Killramos's Avatar
Drives: '19 M2 '21 X5
I think the problem is that for those of use who have the anti dazzle lights disabled ( ie North America ) the cars get stuck in the urban driving setting or some generic lighting setting.
With the euro coding the highway beam lengths are enabled which throws the light much further but because our cars cant use those settings they just get aimed to short. Just a matter of we can't use the lights the way they were designed to work which is why they appear to be poor. Blame the US DOT.
I saw an article on this somewhere that explains it pretty well.
      05-19-2016, 01:50 PM   #17
I also see this issue. All mountainous here, so it's always "Auto High Beam" setting at night, for me. Without the high beams, I'm only getting 20% of the illumination I should, from past Xenon experiences. Makes me think they really want us to use the high beams?
      01-26-2017, 08:05 AM   #18
p912guy
I did this last night. It was a noticeable improvement. My MINI Cooper S had the HID lights and I absolutely loved them. They projected higher and further on the horizon than my M235i did when I took delivery of it. This adjustment made made the brightness and distance the similar to the MINI so all is good.
16 Audi Q5 3.0T (Wife's Daily Driver)
66 Porsche 912 (Project)
17 GMC Canyon Denali Long Bed 4x4 (Tailgatin, Haulin & Towin)
various 'one design' sailboats / stinky hockey gear
      01-26-2017, 10:29 AM   #19
mrfattbill
Drives: 2016 EB M235i xDrive
What height did you set them too, relative to ground, and how far away did you have the tape?
Thanks
Bill
      01-26-2017, 10:37 AM   #20
p912guy
I didn't make any measurements but rather followed the path of others who posted earlier in the thread and turned the adjustment screw two turns counter-clockwise. It seemed to work well as I had noticeably better vision at night and no one flashing their light's at me to indicate they thought I had my brights on. I am sure there are more scientific ways of adjusting the lights, but this adjustment took all or 2 minutes. If I start to get any indication they may be aimed too high, I can always go and adjust the screw clockwise.
      01-26-2017, 10:37 AM   #21
Maynard
Drives: 228iX & M2C
I think I recall seeing that you should have the car running at the time, to be sure auto leveler is working. Haven't tried this, but would check to see if putting it into gear, or rolling slowly, makes it change height. I noticed that in the BMW video of assembly line adjusting, the wheels are slowly turning on a dyno-type fitting while she is adjusting them.
I asked at the dealership to get this looked at, and they told me 'they were set right, needed nothing' but to me I notice an improvement afterwards, so perhaps they are quietly resetting these w/o admitting they were off? Was going to DIY, but now don't feel the need.
      01-26-2017, 12:08 PM   #22
JeffreyZ
Drives: TBD
Would it be possible to recode to the EU version?
