04-08-2017, 04:45 PM | #133 | |
Rep 350
04-08-2017, 06:27 PM | #134 | ||
Rep 8,942
SerenVoX147.00 |
04-09-2017, 06:09 PM | #135 | |
Rep 34
04-24-2017, 11:50 PM | #136 |
Rep 350
Just want to say thank you to all of you who provided feedback while I was waiting on my CAI. So I ended up having a snow valve, and since I bought the intake used I ended up buying the hardware kit since I was missing the smaller clips, seal, and cover for snow valve. Got it installed but I've been running the car with out the snow valve cover since I just havnt found time to borrow a rivet gun. JB4 did show codes, MAF sensor electrical short circuit to B. I'm guessing it's normal, car runs fine I did notice slight idle stutter but only for seconds and that's on cold starts only. This was the last thing to officially be FBO and I decided this last as we all know performance from an intake is minimal. I don't feel any difference than the stock but it's nice to know the car is sucking in alot more air than the restrictive stock filter.
04-25-2017, 10:44 AM | #138 | |
Rep 8,942
SerenVoX147.00 |
04-25-2017, 11:37 AM | #139 |
Rep 350
04-25-2017, 12:40 PM | #140 | |
Rep 8,942
SerenVoX147.00 |
04-25-2017, 03:23 PM | #141 |
Rep 124
so to replace/clean the filter every 20k miles or so...does one simply undo the 4 clips around the box and lift the pipe and its assembly up and unscrew the filter from there-or do you have to mess with the clips/ hose clamps and that sensor?
04-25-2017, 09:39 PM | #142 |
Rep 647
Its is very simple to pull the Dinan intake out for maintenance. One wormgear clamp and 4 clamps to remove the housing and tube. You can leave the MAF connected. Wormgear clamp at filter to filter housing. Quick and easy
01-13-2018, 06:00 PM | #146 |
Rep 350
I'm looking to replace my air filter only for a new one, will buying it direct from Dinan be my best option or can we get them else where for a better price? While I'm at it I was gonna redo the weather striping, has anyone else needed to or for safe measure a good idea?
01-13-2018, 09:26 PM | #147 | |
Rep 647
SerenVoX147.00 |
01-16-2018, 04:10 AM | #148 | |
Rep 4,521
Mppk lower box is essentially same a m2 lower box and lots of m2 owners have installed dinan cai. BP
Current '22 X3M LCI.. |
01-16-2018, 11:26 AM | #149 | |
Rep 8,942
Personal opinion - Dinan with stock lower box is best until you get into Eventuri silly money land. You can add the AFE scoop but I don't think that does much TBH. I have one on the wagon where the install is 100% good, not on the convertible where the support pop rivet won't work.
01-17-2018, 03:01 AM | #150 | |
Rep 4,521
I ended up with oem lower airbox + Dinan CAI + AFE DAS on my M135i - it offered marginal improvement in IAT and throttle reponse compared to my prior setup - which was OEM airbox, AFE dry drop in panel filter and AFE DAS. This was a good VFM upgrade IMHO as it yielded better IAT's and throttle response than stock.
01-28-2018, 12:39 PM | #151 |
Rep 190,975
