BMW M2 Forum > BMW M2 Discussions > 2016 BMW M2 (F87) is a Go! Coming Late 2015 - Early 2016
      04-30-2014, 09:29 PM   #243
Bam226
Drives: BMW 228i M sport
Anyone care to guess starting MSRP?
      04-30-2014, 09:35 PM   #244
Black Flagged
Black Flagged's Avatar
Drives: M2C
$54,000. With options $64,000. Just guessing
      04-30-2014, 09:38 PM   #245
wdlfbio
Drives: 2013 4S, 2015 3500 HD Dually,
Dang. Might have to get a slightly used mustang to get me by for two years, while waiting for this one.
'16 235i
'15 3500 HD Dually
'13 C4S
      04-30-2014, 09:45 PM   #246
nks_bb
Drives: 2011 e90M ZCP
Gonna have some decisions to make... This comes out just at the same time my warranty is over. Do I buy a dd and garage queen the last and only NA V8 M or do an ED for an M2???
      04-30-2014, 10:03 PM   #247
DieGrόneHφlle
Drives: M
Originally Posted by j23a45m View Post
nothing is evident at all. you Rd what you've done before you release it anyway man. ok I'm done with this you won
Go ask your friend at Braman why Dinan is releasing a piggyback for the M5 and not a ecu tune. See what he says.
Cheers.
      04-30-2014, 10:05 PM   #248
DieGrόneHφlle
Drives: M
Originally Posted by kmarei View Post
Too hbd this car will suffer from boxster-itis
Not so sure of that.
The 1M doesn't suffer from boxster-itis.
      04-30-2014, 10:06 PM   #249
DieGrόneHφlle
Drives: M
Yeah low $50k.
      04-30-2014, 10:07 PM   #250
bxsinster
Drives: 2009 n54 135i SedonaRed
the m4 is obviously light years ahead especially if they are using an n55 for an m2.,,. no comparison m3/4 better in every way
      04-30-2014, 10:07 PM   #251
Ayrton91
Drives: BMW 1M, BMW X5 3.5d
M2 as DD. M3 in garage and for special occasions..
      04-30-2014, 10:13 PM   #252
Jadar
Dejan
Jadar's Avatar
Serbia
1753
Drives: 2018 Audi S3
Originally Posted by Desert_Fox
Originally Posted by 03BeastCharmer View Post
Doubt it. The M235 is the old "is" version that sits below the M car. Since you bought a 335is instead of an M3, you are proof that there is room for that tuned version below the ///M version
I'm excited to see how this turns out. I'm afraid how big the M4 is. M2 may be a better fit for me.
The 'middle child' kind of placement you're referring to is right, but I also chose the 335is because IMO the I6 TT was much better and more fun than the crappy V8 in the M3. In this case however, both cars use the N55. One simply has more power, and the kind of person who would even buy an M235i over a 228i (Think more power, sportier) I think will opt for the M2 as well (As long as the money is there)
Oh wow, you best put on a fire retardant suit ASAP!
Calling an s65 garbage will get you castrated around here. Lmao
S65 is epic man! A real track ready motor.
FBO-PS1 and stuff
      04-30-2014, 10:19 PM   #253
Appeltje
Appeltje's Avatar
Drives: M4 F82
Originally Posted by Tornrider
HOLY COW! Forget the M3, I'm waiting for this!
x2 :-)
      04-30-2014, 10:30 PM   #254
Jadar
Dejan
Jadar's Avatar
Serbia
1753
Originally Posted by alpinweiss 335i
Originally Posted by dd1981 View Post
Yes! Yes! Yes! Yessssss!
Best news this year!
Sign me up, because I was shopping a cayman s 981.
Can't wait to see them compared. So far the Cayman S has my vote.
Mine too but that's because it's already out. And I test drive one with a PDK 2 weeks ago, and it was freakin amazing! It was still so very engaging to drive and felt very visceral.
I couldn't help but think to myself this is the best car I've driven in a long time, perhaps ever, especially under 400hp.
The M2 can win me over if they do it right. But the cayman will own the looks department still IMO. Not to mention it's feel and low weight will be difficult to match. It'll still be a better car.
FBO-PS1 and stuff
      04-30-2014, 10:44 PM   #255
Tag
this is the way
Tag's Avatar
18160
Drives: N-1 starfighter
You do know that the new m3/4 is using pretty much a N55 just with 2 turbo's right? If they're getting 365 hp from the n55 that's a good thing to know on our end.
There's a lot more to the S55 than a couple of turbos.
ENGINE
  • 3.0L inline 6 cylinder engine (S55) with two mono-scroll turbochargers
    • 3,027 cc (compare to 2,979 cc of N55)
    • 89.6mm bore / 80mm stroke over-square (compare to 84mm bore / 89.6mm stroke under-square of N55)
    • Derived from N55 engine
    • Direct Injection
    • VALVETRONIC
    • Double-VANOS
    • closed-decked crankcase (4.4 lbs / 2kg lighter)
    • twin-wire arc-spray coating (instead of liners) in cylinder bores reduce engine weight
    • 20 lbs lighter than V8 S65 engine (from E90/E92 M3)
  • 430 HP (approximately) from around 5000-7300 RPM
  • "far beyond" 369+ LB-FT (500 Nm) from under 2000 RPM to over 5000 RPM
  • See Dyno Chart
  • Slightly above 7500 RPM redline
Source: http://f80.bimmerpost.com/forums/sho...d.php?t=892746
      04-30-2014, 10:44 PM   #256
BimmerPowered
Drives: '06 ZCP M3
I think we should all wait to see some preliminary specs and info released, otherwise we're all just speculating.
However, I am excited as fvck for this car, could be a great replacement or addition to the current E46 M3 owners, myself included.
      04-30-2014, 10:52 PM   #257
positiveions
positiveions's Avatar
Lebanon
961
Drives: 19 Tacoma, 16 Golf wagon
This is the news I'm waiting for
      04-30-2014, 10:53 PM   #258
pkimM3r
pkimM3r's Avatar
206
Drives: m3 saloon in granny mode.
Cool story bro, so cobb is spending big bucks also! price wise i don't know how much or care how much. but again I'm sure bmw is lending a hand to Dinan. I'm not spreading anything its called a opinion that I'm untitled to express right boss?
You are the one spreading stories. Your opinion is way off base and incorrect.
No Cobb takes much much longer to crack BMW ecu and they lost their BMW guru Rob Irish last year. For instance the N54 ecu, they were much later to game than Dinan.
Once again. Fact Dinan does all their own in house hacking. They hire Cal Tech engineers. Steve has a softeware team of 6 individuals that literally spend their entire work day hacking ecu's. Steve say on average it takes them half a year to hack an ecu.
and their software still sucks. lol.
      04-30-2014, 10:55 PM   #259
j23a45m
j23a45m's Avatar
Drives: 2012 E70 X5
ENGINE
    • Direct Injection
    • VALVETRONIC
    • Double-VANOS
  • See Dyno Chart
I've seen this before! you seen what i quoted with what i said so pointing is out isn't showing me anything new at all but thanks
2011 BSM 335i E90 MTECH 6MT • JB4 stage 2 iso 5.3 FF wire• BMS Intake • Vishnu DP • Cyba Scoops • LUX V4 • 6000K Headlight/Fog light Philips Ultinon • Euro headlight switch • ACS roof wing • 35% tint • Performance Grilles • Misc coding • Cobb charge pipe • ///M3 fenders • 335is pedals • BC Coilovers • Vrsf 7" IC • ///M3 mirrors •
      04-30-2014, 10:56 PM   #260
j23a45m
j23a45m's Avatar
Drives: 2012 E70 X5
I agree with
      05-01-2014, 12:15 AM   #261
IS3andME
Drives: Lexus IS300
Originally Posted by ASAP View Post
I refuse to believe that bmw can build a reliable high strung turbo 4 cylinder motor. The N55 with 300 hp is relatively reliable but that is an extra 2 cylinders, 80 less hp and 1L extra displacement. Wait till those cla motors start crapping out after everyone drives them like real performance cars. Make no mistake about it, a reliable higher power 4 banger can be built, I just dont thing Bmw or Benz can do it.
Isn't the guy who was doing 4 cylinders for VW/Audi now with Mercedes AMG, and is the one responsbile for the CLA 45AMG?
      05-01-2014, 12:23 AM   #262
pkimM3r
pkimM3r's Avatar
206
I agree with
which means they put all that time into it and still make subpar parts vs others lol
      05-01-2014, 12:24 AM   #263
pkimM3r
pkimM3r's Avatar
206
get a japanese builder.
they e been doing it for ages. look at the evo fq series.
      05-01-2014, 12:49 AM   #264
wantm135i
wantm135i's Avatar
Drives: x1 35i m sport
I all ready have one.
Tags
2015 bmw m2, 2015 m2, 2016 bmw m2, 2016 m2, bmw f22 m2, bmw f87 m2, bmw m2, bmw m2 coupe, bmw m2 coupe news, bmw m2 engine, bmw m2 f22, bmw m2 f87, bmw m2 forum, bmw m2 forums, bmw m2 motor, bmw m2 n55, bmw m2 n55 engine, bmw m2 news, bmw m2 render, bmw m2 rendering, bmw m2 renders, bmw m2 rumors, f22 m2, f87 m2, m2 coupe, m2 f87, m2 forum, m2 forums, m2 n55, m2 news, m2 rumors, n55 bmw m2, n55 m2
m2
