10-02-2015, 09:10 AM | #1 |
Rep 1,290
changing color on display
So I have noticed recently that sometimes the display between the tachometer and speedometer that shows what gear you are in, number of miles on the car, etc. , sometimes changes from orange to white and back again while driving. I thought at first it had something to do with the headlights being on, but after watching it the last few days, this doesn't seem to affect it. Has anyone else noticed this? If so, any idea why it changes colors for no apparent reason and without me doing anything?
10-02-2015, 10:01 AM | #2 |
Rep 8,942
Your first guess was close, it's for day and night driving. Annoying in low light daytime for instance when it bounces back and forth.
10-02-2015, 11:30 AM | #3 |
Rep 87
Also annoying that at low light it's getting out of sync sometimes. Top part with speedo/tach gauges turns orange, but bottom LCD panel (and AC display) stays white for a while. And then when it gets darker, everything turns orange. Such an obvious bug.
10-02-2015, 12:46 PM | #5 |
Rep 1,091
And this state is the most annoying of all possible combinations - one of those many "cost reduction" stupidities BMW implemented in their lower series vehicles to remind the owner he paid a little less than he would for similar engine class vehicle of a higher series. Don't know about the 3 series, but the dash illumination in my F10 was either all red (night illumination), or all white (but actually illuminated white) for daylight, when everything was consistent and elegant. BTW I wonder how much BMW actually saves by not illuminating the upper portion of the dash during dusk hours...
previous: 2003 E46 330i SMG
10-02-2015, 12:47 PM | #6 | |
Rep 818
It's light.
When it's light outside, it's white. When it's dark enough for your auto headlights to turn on, it's orange. Quote:
Only in some of the higher BMW's did BMW put regular lighting behind the dash cluster. Almost EVERY other BMW before the F10 never had dash lighting during the day. The regular 3 doesn't have it. Get over it. Last edited by nike001; 10-02-2015 at 12:54 PM.. |
10-02-2015, 01:09 PM | #7 | ||
Rep 1,290
10-02-2015, 02:37 PM | #8 |
Rep 8,942
Probably the only thing I miss about my old Saab was the blackout button that would turn all interior lighting off for night driving. That was a nice feature.
10-02-2015, 02:53 PM | #9 |
Rep 52
Wonder if any aspects of this are code-able. The white looks more modern to me and I might turn it on all the time if possible, not sure if I'd regret it at night though.
10-02-2015, 02:57 PM | #10 | |
Rep 1,091
Of course I know most of the cars still only have dashboard illumination at dark (just like my old good E46 used to do)- the trick is that if entire clock is at the same level of illumination it just looks "normal", while with the main portion almost invisible and the lower portion unnaturally bright - it looks as something is wrong...
10-02-2015, 03:04 PM | #11 | |
Rep 167
2004 Imola Red 330i ZHP 6MT RIP
2007 Jet Black 335i 6MT RIP |
10-02-2015, 03:09 PM | #12 |
Rep 1,091
Unfortunately you cannot "turn it on all the time" as the main/upper portion of the clocks do not have white illumination at all - in daylight they are supposed to reflect the ambient light (in white, since the scale, needles and the ring are white). The only actual back-light source in that area is red, and comes on in the dark. Bummer.
10-02-2015, 03:19 PM | #13 |
Rep 1,290
since our cars don't have oil temp gauges, I was kind of hoping it was orange until the car warmed up at which time it would turn white, signaling that you could now rip on it. that would have been really cool!
10-02-2015, 03:20 PM | #14 | |
Rep 1,091
As I said, all is OK in the dark (all is evenly illuminated red); the worst scenario is the big contrast with daylight only coming from the front (like when you're at the end of a tunnel): not enough ambient light for the main portion to reflect light in white, with the white illuminated lower portion adopting its highest intensity.
10-02-2015, 04:00 PM | #15 | |
Rep 818
Hell, before 2015.. bluetooth streaming wasn't even standard equipment on BMW's and yet Ford/Toyota/etc had it for a year or two as standard. |
10-02-2015, 04:25 PM | #16 |
Rep 87
10-02-2015, 06:46 PM | #17 |
228i - 2015-03
13
Rep 66
Sometimes (not easy to say exactly when...) the gas gauge and the m.p.g. part is completely switched off. I noticed that during daytime when one enters a tunnel, then, if it's long enough, it turns red...
10-02-2015, 07:28 PM | #18 | |
Rep 754
Drives: 2022 M3 Competition
My 2015 climate control lights are always orange. How do you make them white? I know how to change the ambient lighting in iDrive, but it doesn't effect the climate area apparently.
2022 M3 Comp BGM/Fiona Red, Executive, Drivers Assistant Pro, Parking Assist, 826M black wheels
(SOLD) 2018 M2 BSM LCI, DCT, Executive, Drivers Assist, CarPlay |
10-02-2015, 08:16 PM | #19 | ||
Rep 831
Hoc Lapidem Non Vi Sed Saepe Cadendo!
10-02-2015, 08:46 PM | #20 |
Rep 754
Well damn...
10-03-2015, 07:21 PM | #21 | |
Rep 87
Here is the pic. First is daytime, second is daytime with exterior lights on, third is nighttime. |
10-08-2015, 11:12 AM | #22 |
Rep 222
