09-29-2023, 06:34 PM | #1 |
Rep 3
N55 Spark plug replacement cost
Hi Everyone,
N55 motor. Local BMW dealership quoted me $720 for spark plug replacement. Is that normal? What have you been charged before? I have changed spark plugs myself in 5 different vehicles and it usually took about 30 minutes. Is there something with N55 that makes spark plug replacement time consuming or difficult? Thanks! |
09-29-2023, 06:43 PM | #2 |
E4 Mafia
325
Rep 412
Drives: E30, E36/5, E46, F22, F30
Garage List 1990 BMW 325i [0.00]
1998 BMW 318ti [0.00] 2003 BMW 325i [0.00] 2015 BMW 335i [0.00] 2015 BMW M235i [0.00] |
removing everything around the cowl to access the rear couple plugs is what takes the longest. It isnt difficult at all, just takes more time. I really would have to be near dead to pay over $700 for the job; if I were I wouldn't be able to drive it.
Squad - '90 E30 325i MT (225k) | '98 E36/5 318ti MT (153k) | '03 E46 325i MT (152k)| '15 F22 M235i MT (60k) | '15 F30 335i MT (80k)
KIA - '91 E30 325i AT (146k) | '02 E46 325i MT (212k) Bring back the purple M stripe |
10-02-2023, 01:06 PM | #3 |
Rep 2
I just changed my Sparkplugs and Coils a few days ago, I already knew what to do and it took maybe about one hour so if you do it for the first time you may take longer but it still is a very doable task if you have the tools for it. Plugs (Bosch) and Coils (Delphi) cost me about 170€ in Germany. BMW original parts will cost way more, at least double I think.
10-03-2023, 12:01 PM | #4 | |
Rep 243
Makes complete spark plug replacement a 30 minute job, tops.
'15 235i - Moddedededed
10-03-2023, 02:12 PM | #5 | |
Rep 5,372
For those DIYing, if the plug have never been replaced and the car has 40K+ miles, you may find that the plugs have a bit of resistance coming out. What ends up happening is the carbon near the plug base starts getting caught up in the threads which are tight. The key here is patience. Loosen, then tighten a bit, then loosen a bit farther, then tighten a bit, and so on. This keeps the carbon from packing tight into a thread and potentially risking a cross threading issue which would be a monumental and expensive nightmare.
zoro200122.50 |
10-03-2023, 06:21 PM | #6 | |
Rep 243
It's doable as noted before, but you need to know what you're doing.
10-14-2023, 10:00 PM | #7 |
Rep 91
Drives: 2020 X5; 2016 M235i Conv. 6MT
Find yourself an alternative shop to go to. It’s definitely delicate, but the cost should be no more than $400-500.
10-17-2023, 10:57 AM | #8 | |
I like biscuits
164
Rep 250
Better to remove the cowl. And for OP: the dealership is ripping you off. Even if the plugs are $30/each. = $180 in parts. That means they are charging $540 labor. At a standard shop rate of $125/hr thats 4.32 labor hours. The job doesn't take that long. Either DIY or find a more reputable independent shop that works on BMWs |
AmuroRay2290.00 |
10-25-2023, 03:45 PM | #9 | |
Rep 243
OP if you've never done plugs, do it by the book or take it to the shop. It's an easy job so don't be afraid to tackle it on your own.
AmuroRay2290.00 |
10-26-2023, 12:33 PM | #10 | |
Rep 5,372
By not giving yourself full access to the two rear plugs, you have to sneak in the socket and extension in rather blindly. There's a host of wires and other crap you're contending with as well right about the plugs. Without a straight shot to the plugs, you run the risk of torguing on the plugs on one side, thus running the risk of cracking the plug (which you won't know until you start the car and it runs like crap) or worse, snapping the plug in half. For the 15 minutes it takes to remove the supports and such, just do it and save yourself one less risk to contend with. Shortcuts can be great, but this isn't one of the places to be cutting corners.
11-16-2023, 08:12 PM | #11 |
Rep 198
I dont know how people can justify spending 500-700 for a spark plug change. its 6 plugs plus a special thin wall socket I picked up the 6 oem plugs minus the BMW logo for $9 a peace and $25(a one time cost) for the thin wall socket from FCP Euro. so for under $100 for the parts, and you cant beat the lifetime warranty either. I think i was done in a little over an hour the first time I did the plugs
11-21-2023, 02:22 AM | #12 |
Rep 1
For those of you who are DIY'ers, if the plugs have never been replaced and the car has 40K+ miles on it, you may notice a little resistance in the plugs. What eventually happens is the carbon near the base of the plug starts to get stuck in the tight threads. The key here is patience. Loosen, then tighten a bit, then loosen a bit more, then tighten a bit more, and so on. This prevents the carbon from building up tightly in the threads and potentially introducing the risk of cross-threading issues, which would be a huge and expensive nightmare.
———————————————————————————— STEPPERMOTOR.FR has a wide range of motors, now available Brushless DC Motor,Hollow Shaft Stepper Motor and so on. |
zoro200122.50 |
12-22-2023, 12:24 PM | #13 |
Rep 372
Just dropped mine off to have the plugs changed at 70k miles. Got quoted $380 all in, I’m on the north side of Atlanta if that matters.
12-22-2023, 03:37 PM | #14 |
Rep 5,372
That's a fair price.
