BMW M2 Forum > BMW M2 Discussions > Gear indicator
      05-19-2023, 06:45 PM   #89
(K)
(K)'s Avatar
1278
Drives: '21 M2C 6MT (R.I.P.)
Originally Posted by chris719 View Post
Do you think there's a way to change the car's default modes on startup? It drives me nuts that the M2C starts with steering in Sport.
I support this 100% and I believe it's doable with a tuning suite once the DME is unlocked. Of course you know who to go to for all of that (Enabled, in case you didn't).
chris7197334.00
Enabled1410.00
      05-20-2023, 04:06 PM   #90
dbhajek
Drives: 2018 M3
Originally Posted by Enabled View Post
So here are the changes that I made to make it happen.
Code:
Instrument Cluster  In Esys, Bimmercode expert mode, protool, etc.
3003 FZG_Ausstatung
SPA_ENABLE change to nicht_aktiv 00 (default aktiv 01)
SPA_IST_GANG_ENABLE change to aktiv 01 (default nicht_aktiv 00)
Work like a charm, thanks Enabled, I still need to get with you for the remote unlock.
      05-24-2023, 09:29 AM   #91
Enabled
Drives: 328xd Wagon, M2 Competition
Glad it worked!
Send me a PM with your email or number to text and we'll plan it out!
-2014 328d Wagon, 8HP. Self-tuned, 270hp/430ft-lbs.
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp
-2016 Mini Cooper S, MT. Many plans.
Others:
-E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe.
      06-08-2023, 03:00 PM   #92
Kran1um
Kran1um's Avatar
30
Drives: M2 CS
I finally got around to doing this coding this week. First off, I want to thank Ratkiller for asking the question! I was amongst the naysayers initially (why would you need this? The gear lever will always tell you what gear you're in!), but then I did remember that sometimes while cruising you space out and notice the revs are a little higher than you think they should be and ask "what gear am I in?". Also in stock form (in my CS at least) once you get to 6th gear there's just an empty square in the gage cluster and it kinda looks dumb. Having it show a 6 there is a small upgrade imo!
Thank you Enabled for figuring this out! I got the biggest coding scare when I hit apply in Bimmercode on this when it errored out and my dash said I had a retractable roof malfunction!
Luckily, a restore, reseating of the OBD module and a retry worked a charm.
      06-08-2023, 03:43 PM   #93
DadVibes
DadVibes's Avatar
1247
Drives: F87 M2 CS
Code:
3003 FZG_Ausstatung
Confirming, this worked perfectly in my CS.
Current: F87 M2CS - 6MT | Öhlins R&T | Garagistic Endlinks | Autosolutions SSK | AA EL Midpipe & Axleback | 255/275 PS4S
Gone: F87 M2C - 6MT | Öhlins R&T | G.C. Camber Plates | Autosolutions SSK | UCP | AA EL Midpipe & Axleback | Apex EC-7 | 265/295 PS4S
Appreciate 4
Enabled1410.00
chris7197334.00
F87source7255.00
///MPhatic13864.00
      06-08-2023, 04:49 PM   #94
F87source
F87source's Avatar
No_Country
7255
Drives: Bmw M2
Enabled any updates on the OG m2? I'm taking my m2 out next week and could test any updates.
https://f87.bimmerpost.com/forums/sh...2#post30368242
Appreciate 5
David.m437.00
jefe2000742.00
Hankdoll135.50
BadgerDog177.50
gphung193.50
      06-14-2023, 02:29 AM   #95
BadgerDog
BadgerDog's Avatar
178
Drives: 2017 BMW M2
2017 BMW M2  [9.50]
As much as I don't think it's needed, id make the changes too if og gets sorted out.
I got used to just having that space be blank, but something even remotely useful would still be an upgrade...
gphung193.50
      06-14-2023, 01:16 PM   #96
Enabled
Still working on it!
It's very likely in the manner that the DME sends out the data to the network and the cluster, which makes it unique and challenging.
I find it interesting that the S55 control is a little different in reporting it.
Others:
Appreciate 5
F87source7255.00
jefe2000742.00
David.m437.00
gphung193.50
bmxcamel555.50
      06-14-2023, 01:23 PM   #97
F87source
F87source's Avatar
No_Country
7255
Drives: Bmw M2
I see, hopefully you get it soon!
      06-14-2023, 02:35 PM   #98
BadgerDog
BadgerDog's Avatar
178
Drives: 2017 BMW M2
2017 BMW M2  [9.50]
You're a huge benefit to the community my dude.
Appreciate 4
F87source7255.00
Enabled1410.00
gphung193.50
moebiuz105.50
      07-03-2023, 11:57 PM   #99
Jeffe
Jeffe's Avatar
Drives: 2019 Carrera T 7MT
You’ve solved a huge pain point for me. Thank you Enabled for gifting everyone this amazing find!
Confirming this worked flawlessly on my 2020 M2 Comp. I did get an odd date/time error at first, but I just disabled/enabled via idrive and it’s all back to normal.
BMW should’ve included this from the factory, end of story.
Current:
2020 M2 Comp (AW) 6MT
Previous:
2018 Mini Cooper S (F56) (grey/black)6MT
2015 NC Miata club PRHT 6MT
2007 911 Carrera 2 (black/tan) 6MT
2017 Grand Sport (blue/white/red) 7MT
2015 BMW M4 (BSM/SS) 6MT
2011 C63 AMG (black/black) 7A
F87source7255.00
Enabled1410.00
Swish77380.00
      07-06-2023, 02:45 PM   #100
samsamdar
samsamdar's Avatar
No_Country
585
Drives: OG M2
2018 BMW M2  [6.67]
Any update on this for N55 M2s?
OG M2 with the OEM M mirror retrofit
F87source7255.00
      07-06-2023, 03:15 PM   #101
F87source
F87source's Avatar
No_Country
7255
Drives: Bmw M2
+1
It would be nice to replace the gear suggestions with an actual gear indicator.
      07-06-2023, 10:15 PM   #102
bmxcamel
bmxcamel's Avatar
No_Country
556
Drives: F87 LCI, G01 m40i, E90 M3
+2. Happy to help by using my car for testing
F87source7255.00
      07-10-2023, 07:03 PM   #103
Goodtimesandalpines
Goodtimesandalpines's Avatar
Drives: 2020 M2 Comp 6spd slicktop
Eureka!!!!
Video with sound of my manual shifter here https://drive.google.com/file/d/18bO...ew?usp=sharing
Dude this is so sick! I just did it to mine after seeing it could be done with BimmerCode!
Much cooler than the stupid eco gear suggestion lol
Appreciate 4
F87source7255.00
Enabled1410.00
Kattanah137.50
      07-15-2023, 08:18 AM   #104
Swish77
Swish77's Avatar
Drives: M2 Competition '21
Code:
3003 FZG_Ausstatung
As the kids say, this is dope! Thank you so much for figuring it out! But for any dudes who are as dumb as me when it comes to tech stuff, what exactly needs to be done in BimmerCode?
I go to the “Instrument Cluster” in expert mode, scroll down to lines of text that start “SPA_ENABLE change to nicht …..” and do what? Will those two lines of text already be there and I’m just clicking on them to enable or disable? Or do I need to create and fully type those two lines of text as shown above?
And how does “3003 FZG_Ausstatung” play into the whole thing? What’s that?
      07-15-2023, 05:17 PM   #105
Enabled
Those lines will already be there, yes, you just need to find them in the list and change them to the values I posted. The 3003 FZG-Ausstatung is just a data bank header "title". It's there to sort coding. You don't do anything with it.
Others:
Swish77380.00
      07-15-2023, 05:21 PM   #106
Enabled
I have some mild progress (likely only via DME tune), but ideally, I need to flash a few variations to test and identify the changes required. The DME control bytes are a bit different in the tune in M2C vs N55 M2.
Ideally I wish I had one locally to do some tune fast flashes over 45 seconds to test!
Others:
Appreciate 4
///MPhatic13864.00
David.m437.00
F87source7255.00
gphung193.50
      07-15-2023, 07:44 PM   #107
F87source
F87source's Avatar
No_Country
7255
Drives: Bmw M2
bmxcamel do you have a tuning platform for enabled to test some tunes?
My cars in bits right now as I install my mmi system + rewire my dash camera, so there's no battery plugged in so I avoid an air bag rearranging my face.
      07-15-2023, 09:31 PM   #108
bmxcamel
bmxcamel's Avatar
No_Country
556
I have bm3 if that’s helpful.
F87source7255.00
      07-15-2023, 09:45 PM   #109
F87source
F87source's Avatar
No_Country
7255
Drives: Bmw M2
I believe that'll do it! Because Enabled can tune via bm3.
chris7197334.00
      07-16-2023, 12:31 PM   #110
Swish77
Swish77's Avatar
Worked like a charm for me with Bimmercode on my '21 M2C! For those of you as tech-challenged as I am ...
Once in "Instrument Cluster" and expert mode, find the header "3003 FZG-Ausstatung" and click into it. Then scroll down to find those two lines of text, which are right next to each other, and click into each one of them separately to change the setting and "back" afterward. There are only two options on each line, so just change it to the other option. Click "code" and voila. (This stuff might seem obvious to guys who code a lot, but I get lost, and I'm also nervous I'm going to screw up the electronics on the car.)
The only thing I needed to do after the re-coding was reset my dash clock in iDrive settings.
Thanks! Enabled for President!
Enabled1410.00
chris7197334.00
m2
