2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum First Look and Taste of the Tuningwerk M235i Beast
      05-04-2014, 06:25 AM   #133
Tiago
Tiago's Avatar
25
Drives: BMW
Originally Posted by Dackelone View Post
New pistons, crankshaft, rods, balanced and blue printed engine. Thermo coatings(everywhere). New beefier radiator(2cm thicker than stock) new larger oil cooler and FMIC. PPK HD radiator fan and aux water radiator. Different turbo and DME sw to run on 98 to 102 octane pump fuel(available at most GErman gas stations).
Does the reliable 360hp of N55 applies to the internal engine components or just to the turbo???
I just found odd that BMW would sell a car with a engine only 12% left from its internal limits. I know that this car propose is to be spanked at track and need higher levels of reliability but for a street daily basis i bet that you can achieve similar results with the same bolt ons (turbo, intercooler, exhaust and ecu) and last forever with a proper maintaince and driver care.
      05-04-2014, 06:52 AM   #134
Tiago
Tiago's Avatar
25
Drives: BMW
These guys make 600 to 700 PS 1M's. The owner had a X5M with 800 PS and 1,100 Nm of Tq.
From what i have read, they package other companies stuff and make their own ecu tuning. And throw some dyno sheets with 25% drivetrain loss and big crank numbers. Do you know if those 700ps 1M's has single turbo conversion? Or what is the brand of the dual turbos? Loba?
      05-06-2014, 05:50 AM   #135
Dackelone
European Editor
Dackelone's Avatar
Germany
10594
Drives: N54 e82
Don't you find it odd that BMW would go thru the EXPENSE of having TWO engine lines that produce two such similar engines in the same factory: N54 with 345 PS and N55 with 300(or320)PS. That costs bmw a lot of money for such a small difference in power outputs. Why would they do that?
So there MUST be a reason. The reason is the internal engine parts are not up to the task on the N55 vs the N54 power levels.
Also... we all know these engines are under rated in HP(PS) - but that is getting OT.
I just was driven in their 1M on the Nordschleife. It was AMAZING. It absolutely "killed" every car out there. Porsche's/Lambo's/Ferrari's you name it - it was toast. Their 1M had 600 HP not 700, my mistake. And it had two turbos, that are not OE. I will (hopefully) do an in depth story on their 1M packages. But for now that's the only info I can give you.
Dack
      05-06-2014, 06:48 AM   #136
M.barnes
Drives: 123d
can i just say, i have been emailing a few companies about parts for my M235i and Tuningwerk have come back the quickest and with the most additional information and help!
seem like a good service.
      05-06-2014, 11:53 AM   #137
Tiago
Tiago's Avatar
25
Drives: BMW
So there MUST be a reason. The reason is the internal engine parts are not up to the task on the N55 vs the N54 power levels.Dack
I was under the impression that both use the same block and same internal specs (size at least). First they released a strong engine (forged internals) to avoid problems and gain market trust (+600rwhp vishnu fftec). Then they focused into reducing costs: one turbo cheaper than two; weaker/cheaper internal parts... But as i said before, i still don't believe that BMW would gamble to release a FI engine with just 12% of margin for internal parts (rods, pistons, crankshaft...). Just do the math for others BMW FI engines stock vs tuners values with just bolt ons.
I just was driven in their 1M on the Nordschleife. It was AMAZING. It absolutely "killed" every car out there. Porsche's/Lambo's/Ferrari's you name it - it was toast. Their 1M had 600 HP not 700, my mistake. And it had two turbos, that are not OE. I will (hopefully) do an in depth story on their 1M packages. But for now that's the only info I can give you.Dack
You don't need a 600hp stage to kill Porsche's/Lambo's/Ferrari's at track. I bet that a stock engine with dedicted suspension, brake and tire combo will be enough for that job.
I want to believe into tuningwerk claims but words is just words and it isn't enough for me. I'm looking forward for that info and see how different it is from other tuners stages. There is on youtube a red BMS 335i with RB turbos and a serious weight reduction killing a bung of high hp cars.
      05-29-2014, 01:27 PM   #138
ir_fuel
Especially at the Nordschleife. Track knowledge is everything there.
      06-01-2014, 04:50 PM   #139
kerm1t
Drives: 17 M3 ZCP Stage 2
did we figure out what lip that was?
      06-01-2014, 05:27 PM   #140
Dackelone
European Editor
Dackelone's Avatar
Germany
10594
Drives: N54 e82
It's Tuningwerk's own cf part.
M235i RS
2979ccm, 6Zyl. TwinScroll Turbo, manuelles Getriebe
444PS (327kW) bei 600Nm
V.max open
Leergewicht mit vollem Tank 1.490kg
Verbaute, Tuningwerk eigene Teile:
- TW Breitbau
- TW Frontlippe, Heckdiffusor und Heckspoiler aus Carbon
- TW Design
- TW Kühlerkit, bestehend aus Hauptkühler, Ölkühler und zusätzlichem Kühlmittelkühler, sowie 850W Lüfter
- Optional Wärmetauscher
- TW Einmassenschwungrad mit Sportkupplung
- TW Midpipe, beseitigt Engstelle am Flexelement
- TW Edelstahl Endschalldämpfer mit Klappensteuerung und Carbon Tailpipes, einmalig tiefer Sound
- TW Bremsanlage mit Brembo Komponenten und geändertem Setup des DSC/ABS Steuergerätes
350x34er Stahlscheiben Brembo Racing, VA 6Kolben Bremssattel, HA Serie, VA und HA Stahlflexleitungen
- TW Schmiede Felgen VA, 7,1Kg HA 7,4Kg (für Serienfahrzeuge ohne Breitbau) VA 8,5x18", HA 9x18"
mit Dunlop SportMaxx RT, VA 235/40R18 HA 265/35R18
- TW Sitzschienen für Recaro PolePosition
- TW Heckausbau, optional mit Überollkäfig und 6Punktgurten
- TW modifizierte Alu-Ölwanne
- Uniball Achselemente
- TW Setup /alternativ Tuningbox
- Optional geänderter Turbolader
Sonstige verbaute Teile
- Radkombination für Breitbau, BBS Racing 3teilig, VA 10x18" HA 10,5x18" mit Dunlop Direzza, VA 265/35R18, HA 285/30R18
- Sitze, Recaro PolePosition
- KW ClubSport 3fach Fahrwerk, optional auch KW Competition Fahrwerke
- Optional Karosserieversteifung und Zusatzstreben
- Zündkerzen mit höherem Wärmewert
- geänderte Luftführung
- BMW M-Performance Interieur mit M- Performance Lenkrad II
- großer Ladeluftkühler
- Drexler Differential-Sperre mit TW Setup
Price from 65.000,-- €
      03-02-2015, 10:17 PM   #141
Alpine F31
Alpine F31's Avatar
Drives: MB E350 4MATIC Estate
Originally Posted by Blown335Atx View Post
Is that a custom door panel? if not what color was the interior prior to modding? Random observation, just curious
I noticed the door panel too. I believe it's Oyster from the factory with custom carbon by Tuningwerk. That is only my guess, not a fact.
      10-19-2015, 09:23 AM   #142
Dackelone
European Editor
Dackelone's Avatar
Germany
10594
Drives: N54 e82
Yes, it was a custom door panel. It helps when you know who the suppliers are for BMW and where they are located.
Dackel
      07-18-2016, 04:44 PM   #143
Dackelone
European Editor
Dackelone's Avatar
Germany
10594
Drives: N54 e82
      07-19-2016, 08:05 PM   #144
i8ur911
Drives: F22 228i MSport
2yrs later and no info 🙁
      07-20-2016, 04:30 AM   #145
Dackelone
European Editor
Dackelone's Avatar
Germany
10594
Drives: N54 e82
TW made a few cars. They prefer to stay under BMW's radar bc they do not want to upstage BMW. TW's cars are magical beasts.
      07-20-2016, 05:21 AM   #146
Nahlem
Nahlem's Avatar
Sweden
1146
Drives: None atm
Have seen this car before and to be fair this is how the M235i should have looked from the start minus the giant rear spoiler and no backseats otherwise its perfect.
      10-08-2021, 11:05 AM   #147
whoismorggan
Bimmer Nut + Software Dev
whoismorggan's Avatar
Drives: 2018 Audi S3 IE Stage 1
Dackelone What are the details on the front and rear fenders? They look wider with molded arches. IT'S SEXY AF
Current: 2018 Audi S3 IE Stage 1
Past: '08 Infiniti G37S, '87 Porsche 944 Turbo, '13 328i, '15 M235i, '15 F80 M3, '16 M235i, '15 335i, '17 X5 xDrive35i
@whoismorggan
      10-08-2021, 11:47 AM   #148
freakystyly
Drives: F22 B58 6MT
Might want to ask someone else, unfortunately he passed a couple years ago.
