06-10-2014, 12:03 PM | #1 |
Rep 442
Drives: 2018 BMW M2
Did BMW underrate the horsepower rating for the 228i?
Curb weight~ 3200lbs
240HP (underrated by BMW, independent tests show more around 270HP) 0-60 in 4.9s (as tested by Car and Driver) M-Sport package gets most of the same goodies as the M235i. These specs are equal to or better than the E36 M3. Quoted by this article
06-10-2014, 12:05 PM | #2 |
***** noob
1368
Rep 10,479
I call BS on 270 hp...maybe 250
From some random poster...comon now
2006 325xi (Sold)
06-10-2014, 12:27 PM | #4 |
Rep 442
Drives: 2018 BMW M2
Great Photo Choice! I'm digging your 2! Nice!
06-10-2014, 12:29 PM | #5 |
Rep 37
That's optimistic. GSR Autosport weighed their 228i which was specifically optioned to be as light as possible, and they got 3189 lbs with about 2/3 full tank. The weights from the various reviews I've seen so far are:
Motor Trend: 3334 lbs. Edmunds: 3344 lbs. Car & Driver: 3353 lbs. |
06-10-2014, 12:37 PM | #6 |
Rep 78
Just compare the wHP from various dynos to other engines rated in that range, and that should tell the story. For example, with regards to the M235i rated at 322hp, dynos show ~305hp. Compare that to a Hyundai Genesis 3.8 AT which is rated at 348hp but shows ~275hp on a dyno. "Real" hp is unknown, but that's 30 more hp to the wheels and that's what really counts. A good comparison for the 228i would be the Genesis 2.0, which is rated at 270hp. Or something with GM's 2.0T which is also rated in the 270hp range.
06-10-2014, 01:13 PM | #8 |
Rep 119
Drives: 2014 M235i EBII May '14 ED
It's not the horsepower... It's the torque.
06-10-2014, 01:21 PM | #9 |
Rep 134
It seems BMW does have a tendency to underrate, but C&D also uses a roll out when testing 0-60, so it brings the published times down compared to other testers. They have posted the fastest 0-60 for the M235i using the same methodology.
I'd guess it's overrated but I'd also guess it's unrealistic to expect to consistently replicate C&D's results or to come to a conclusion on HP using independent dyno testing. Bottom line is, the car's a decent bargain, whatever the true numbers. |
06-10-2014, 01:49 PM | #10 |
Rep 809
Drives: 2014 228i Msport
GSR Autosport dynoed their 228 race project while still stock and saw 233 HP at the rear wheel. Assumeing a rather conservative 10% powertrain loss thats 256 at the crank. Powertrain losses are i'm betting more like 15% so that would be 267 at the crank. Yea, I'd say BMW is really conservative
A peasant and proud of it
Save The Manuals!!! |
06-10-2014, 02:47 PM | #11 | |
Rep 269
**edit** Nevermind... my google-fu was weak. I found it on my own |
06-10-2014, 05:06 PM | #13 |
Rep 326
Drives: 2020 X3M40, 2000 Z3M, 2017 X1
Whatever it is, I love my 228! I road tested an Audi A3 which is rated at 220Hp and similar weight, and my 228 feels significantly faster. The extra gears help, but the engine just seems a lot stronger. I traded in a GenV GTI and the Audi didn't feel much stronger than the GTI. So says my extremely accurate butt dyno!
06-10-2014, 05:26 PM | #14 |
Rep 254
Drives: M3, F80
when i test drove the 228i i was very pleased, but i think i am more than happy with my m235i, perfect choice, if you can burn the extra $ go for the m235i...
2016 BMW F 80 M3 Current
2015 BMW F 36 435i Gran Coupe Retired 2014 BMW F 22 M 235 i Retired 2013 BMW E 82 135 i Retired 2012 BMW F 20 116 i Retired 2011 BMW E 81 116 i Retired 2007 BMW E 87 116 i Retired |
06-10-2014, 07:36 PM | #15 |
Lucky13
211
Rep 1,762
I saw one of the car magazines did a Dyno on a 328 when they tested it against the Caddy ATS 2.0 and it was 258 I believe. This was about a year ago.
1995 325i, 1996 328ci, 1997 528i, 1997 Z3 2.8, 2000 528i, 2001 X5 3.0, 2001 330i Convertible, 2002 M3 Convertible, 2003 M3 Coupe, 2004 M3 Coupe, 2004 Z4 3.0, 2004 X3 3.0, 2007 X3 3.0, 2007 335i Convertible, 2013 X1 28 sdrive, 2014 M235 manual, 2020 X3 30i Xdrive
06-10-2014, 07:39 PM | #16 | |
M Comp
134
Rep 228
Drives: 2019 BMW M2 Competition
That being said, I'd be perfectly fine withe 228i if the m235i did not exist. Stout motor with plenty of power in a dd.
'19 M2 Competition | '07 Heads/Cam/Stall C6 Corvette | '17 Ford Escape Titanium
Past: '14 M235i, '07 335i xDrive, '06 GTO, '02 Trans Am Firehawk, '99 Grand Prix GTP |
06-10-2014, 07:43 PM | #17 | ||
Rep 809
06-10-2014, 09:42 PM | #18 |
Rep 1,077
its probably more like 270 hp.
i've got a 328i so same engine. http://www.edmunds.com/car-reviews/t...illac-ats.html cadillac ATS and 328i dyno charts in there. ATS , GM says has 272hp , and the dyno shows they put down about the same at the wheel |
06-10-2014, 10:53 PM | #19 | |
Rep 15
I think the 3189lb is probably with a manual transmission. So the question remains, is the manual in the 228 as good as the one in the M235i? I wish I had a chance to drive a manual because the lighter the better. |
06-11-2014, 06:34 AM | #20 | |
Rep 511
That is good reading. Thanks! |
06-11-2014, 06:50 AM | #21 | |
Rep 18
Really looking to find an ecu upgrade here in Australia to get my 220i up to the 228i since they carry the same engines. |
06-11-2014, 11:14 AM | #22 | |
Lucky13
211
Rep 1,762
