2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum 2 Series Photos and Videos The wait is over, now the fun begins.
      05-17-2015, 09:28 PM   #67
ketema
Drives: 2015 M235i
Oh how could I forget! I would not have been even able to get the wheel without Jason at GetYourWheels He was able to get the wheels from Japan where others could not. Thanks Jason!
2015 6M Black Sapphire Metallic | MPE w/Carbon Tips | Digital MP Steering Wheel | Carbon Interior | StopTech Slotted Rotors | Pagid RSL1 Race Pads | KW Clubsport Coilovers | DINAN Stage 2 and Carbon air intake | Clutch Masters Lightweight Performance Clutch and Flywheel | Hotchkis Anti-Roll Bars | Enkei RS05RR 18" Racing Wheels
      05-17-2015, 09:35 PM   #68
ketema
Drives: 2015 M235i
Here is one more. A close up.
      05-17-2015, 10:26 PM   #69
AUSf22
Australia
2690
Drives: 2020 M2C HS & Ferrari Roma
wheels look amazing ! the enkei RS05RR definitely suits the car
      05-17-2015, 10:59 PM   #70
alexc93
Drives: na
Looks sick! Build is coming along great!
      05-18-2015, 01:37 AM   #71
ABPReader
Deserter
ABPReader's Avatar
No_Country
215
Drives: BM&W
      05-18-2015, 05:50 AM   #72
ketema
Drives: 2015 M235i
Here is a pic of some measurements.
      05-18-2015, 05:35 PM   #73
GetYourWheels
Drives: F10
Thanks for the kind words Ketama!
Your wheels look SWEET installed! And the fitment looks perfectly flush!
Did you end up running spacers at all?
Cant wait to see some pics of that thing on the track with the new wheels!
      05-18-2015, 05:36 PM   #74
ketema
Drives: 2015 M235i
No need for spacers at all. The offsets are perfect. I'll be at the track again soon!
      07-10-2015, 10:47 PM   #75
ketema
Drives: 2015 M235i
Some recent pics after finally getting my suspension problems resolved.
      07-11-2015, 12:08 AM   #76
Phiberoptik
Drives: 2015 BMW M235i
Those rims look really good!
      07-11-2015, 04:40 AM   #77
SteveInfante
NewFinishColumbia/detailer
SteveInfante's Avatar
Drives: 2015 F31 xDrive
I bet you are glad you got all the coilover/camber plate nonsense straightened out. Look great.
78' Honda CB400A project
      07-11-2015, 10:40 AM   #78
proflex957
Drives: 330ci ZHP, M235
While I'm prepping to get my coil overs installed I took some time to install these pedal covers.
What are your floor mats, and where did you get them?
      07-11-2015, 11:28 AM   #79
ketema
Drives: 2015 M235i
Just BMW sport line all weather mats. Got them from dealer.
      07-12-2015, 10:02 AM   #80
horsepower_and_hounds
Drives: BMW
Where did you get your rotors at? Do they offer drilled or drilled/slotted?
      07-12-2015, 10:05 AM   #81
ketema
Drives: 2015 M235i
They are stop tech. Yes they have drilled if you want. I chose slotted because I believe they are a better balance between de-gassing and retaining strength. Stop tech can be purchased almost anywhere just Google. My wheel well page has the part numbers I bought
      07-14-2015, 05:36 PM   #82
rwalker
Drives: the wheels off
updates on KW DDC vs Clubsport?
      07-14-2015, 05:42 PM   #83
ketema
Drives: 2015 M235i
Well I have not been to track yet, but driving around town on setting 3 the club sport is noticeably stiffer but not unbearable and not "bouncy" like you see some cars. Once I get to the track again I will make a real comparison
      07-22-2015, 07:18 PM   #84
ketema
Drives: 2015 M235i
Sway Bars are in
Finally got my Hotchkis sway bars in!
Front: 3 way adjustable :
32mm hollow
350 lbs/in (100% Stiffer than OE M235i)
380 lbs/in (115% Stiffer than OE M235i)
420 lbs/in (140% Stiffer than OE M235i)
Rear: 1 setting
19mm hollow
80 lbs/in (100% Stiffer than OE M235i)
      08-07-2015, 02:34 PM   #85
ketema
Drives: 2015 M235i
UPDATE: OK got my Hotchkis Sways installed and my Clutch Master's Clutch and Flywheel installed. I will be on track in 3 weeks for a real shake down, but my initial impressions on the sways are...I can't feel a thing. Not going fast enough to make a difference. Clutch and Flywheel: First thing I noticed is that the clutch engagement point is waaay lower/earlier than on the stock car. The thing just grabs. It was a little disconcerting and I'll admit I stalled it on the first try as I had no idea what to expect. I adjusted quickly, but now I have to admit there is way too much travel in my clutch pedal now. I could operate it with my tippy toes. Definitely need a way to eliminate all the extra travel. Suggestions welcome.
Secondly its loud. At first I thought it was the AC, but when idling in neutral it makes a raspy sound. My mechanic said that is normal. I hope so. It does not bother me if it is because I'm using it as a track toy, but it is noticeable and some may not like it if they daily drive.
Thirdly after driving it a bit and getting used to it, I noticed that the revs do not drop when up shifting. When down shifting the throttle is more responsive and the engine is easier to rev match because 1: the revs don't drop that much and 2: less throttle was needed to make the tach move. (in sport+)
I have driven around now on both the Club sport coilovers and the previous DDC coil overs with GC camber plates. The new camber plates no longer break my struts which is a good thing and Kudos to GC for taking care of me. However I decided to stick with the club sports and their integrated camber plates. The things are just bad ass. The car is insanely stiff and I love it. NOT great for the street, but you have to know why you bought the car. I only have it set on 3 and I have5 more settings to play with. The car no longer dives forward under heavy braking. It's just planted. I am sure the wider tires and wheels help with that as well.
Overall I am really happy with the mods and I only have 1 week before my stage 2 DINAN is installed and then I am going to chill for a while and just drive it at the track mercilessly.
      08-12-2015, 03:08 PM   #86
ketema
Drives: 2015 M235i
Here is a pick of the Hotchkis front bar installed
      08-12-2015, 03:13 PM   #87
ketema
Drives: 2015 M235i
Couple pics from autocrossing
      08-13-2015, 12:10 AM   #88
alexc93
Drives: na
Looking great, the stance is perfect.
Tags
build thread, m235i
