2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions Active sound ASD is not working
      10-16-2016, 11:12 AM   #1
tengotengo
Drives: 2016 BMW M235i
Question Active sound ASD is not working
I have an American 2016 F22 M235i.
I read all those topics about Active Sound and I was wondering if what I hear is generated sound or real, I wasn't sure if it's even working.
Turns out it wasn't working, because yesterday something happened and it worked, it was so loud and unusual inside the car that I even thought there's some sort of exhaust malfunction.
When I restarted my car, the sound was gone again.
I know all the topics are usually about disabling it, but my question is, how do I enable it?
I tried coding that ASD value and it doesn't affect anything.
From the coding perspective, everything seems to be enabled and yet it's not working.
      10-16-2016, 12:24 PM   #2
BentZero
BentZero's Avatar
That's a bummer. Get an aftermarket exhaust and never worry about ASD ever again. That's what I did.
You may have some loose wiring too. Check out the ASD module. Look for the ASD bypass install thread for instructions on how to locate the module. If you're near a dealer take the car in. To verify that your ASD isn't working change driving modes as you cruise down the road. It should get louder when you switch from comfort to sport.
      10-16-2016, 01:38 PM   #3
harma24
Consider yourself lucky and leave it alone! Disabling the ASD is one of the first things I plan on doing next weekend once I get my car. If I wanted fake engine noise, I would have ordered a fake engine!
If you really want it and have never coded it out, it's probably safe to assume it's not coded out. Especially since it's intermittent, the place to start would be wiring as BentZero suggested. Check the connector at the amp in the trunk. You'll need to remove the trunk liner to find it. Look for instructions on how to disable ASD; you'll find several videos on YouTube to guide you to it. If that's not it, take it back to the dealer. I would think it would be covered under warranty if something is loose.
Family Cars: 1993-2014: 1993 Honda Accord 10th Anniversary Edition | 2014-Present: 2014 Honda Odyssey
Stable-mate: 2019 - present: 2020 230xi Seaside Blue Convertible
      10-16-2016, 04:44 PM   #4
BentZero
BentZero's Avatar
While ASD in concept is lame I found it to be better than not having it when still running the stock exhaust. The car is just too quiet in stock form for my taste. I eventually had to push an exhaust higher up my priority list though and I couldn't be happier with my Fabspeed valvetronic.
Tags
active sound, asd, coding, f22 235i, m235i
