09-23-2019, 05:11 PM | #1 |
Rep 86
BMW M2 Anti-Lag braaap sound after lifting the throttle
Hello everyone,
I have been thinking about what makes this "braaap" sound after lifting the throttle in M2 (non competition). It is done by the wastegate right? Could I possibly implement it on M235i/M240i by purchasing DME/turbo&exhaust manifold from M2 and putting it on 235i/240i? The sound I'm looking for: It sounds like anti lag system, Just to be clear, I'm not looking for other burble tune. Thanks! |
09-23-2019, 09:29 PM | #2 |
Bimmer Nut + Software Dev
553
Rep 802
Drives: 2018 Audi S3 IE Stage 1
I'm also curious to learn what causes this sound!
Current: 2018 Audi S3 IE Stage 1
Past: '08 Infiniti G37S, '87 Porsche 944 Turbo, '13 328i, '15 M235i, '15 F80 M3, '16 M235i, '15 335i, '17 X5 xDrive35i @whoismorggan |
09-26-2019, 05:47 AM | #5 | ||
Rep 86
Here's a quote from @Andrew Quote:
Used DME for M2 cost around ~1.2k I believe. With catless downpipe it sounds even better! |
09-26-2019, 08:32 AM | #6 |
Rep 373
i believe the difference on the limiter in sound between a m2 and normal n55 (235 etc) is that the m2 has a hard cut limiter that makes that aggressive braap noise. if you look at the m2 rev gauge when its on the limiter it bounces a lot more aggressively then a 235.
'14 F20 M135i EWG FBO:// INJEN INTAKE // PURE INLET// TURBOSMART BOV DUAL PORT // //CSF INTERCOOLER // ER CP // SNOW S2.5 METH KIT // B58TU HPFP // NGK 97506 // ER DP // TMSS MID PIPE //MPE // MPBBK // UR STRUT BRACE // BM3 CUSTOM JORDAN E85 TUNE // XHP STAGE 3 // |
09-26-2019, 10:38 AM | #7 |
Rep 208
My 228i does a similar sound on upshifts after muffler delete. Not as pronounced though. The M2 has a more aggressive exhaust then the normal 2 series, so it makes sense.
Quaife LSD | BC Racing Coilovers | H&R ARB | F8x LCA+TS | Wiechers Strutbar | Mishimoto CAI | Mishimoto Oil Cooler | Mishimoto Oil Catch Can | Mishimoto FMIC | VRSF DP | Masata TIC | Masata CP | DV+ | Custom Kline Exhaust | GTS Style Roll Cage | Sparco Evo QRT | Brey-Krause seat mounts | Schroth Profi 2 ASM 6p | 10" Android HU| xHP Stage3 | BM3 | RaceCapture Data Logger
danielduke3.00 |
09-26-2019, 05:34 PM | #8 | ||||
Rep 86
Tech Part: Quote:
Arc170313.00 |
09-30-2019, 12:22 AM | #9 | |
Rep 373
https://www.e90post.com/forums/showt...18714&page=118
10-02-2019, 07:13 PM | #11 | ||||
Rep 86
https://f80.bimmerpost.com/forums/sh....php?t=1211456 Quote:
10-03-2019, 12:18 AM | #12 | |
Rep 555
10-03-2019, 04:49 AM | #13 |
Rep 86
10-05-2019, 12:42 AM | #15 |
Rep 373
im talking about the sound the m2 makes on the limiter when you rev it it cant be a gearbox related noise as the manual makes the same sound.
10-05-2019, 01:24 AM | #16 |
Rep 170
I looked into this a bunch and reached out to both Wedge and PureBoost about it.
Wedge said that they had looked into it before and hadn't been able to figure it out. Ken suggested getting in touch with Fabian and PureBoost. I contacted Fabian who also said he had been trying to find the parameters that make the M2 do this overrun but hadn't yet found it - and said he would get back in touch with me. It is definitely overrun controlled by the DME though. Though the throttle closure on the M2 might also have something to do with it. I've wanted this sound badly on my M235 for a while lol.
Current: 2019 M2 Comp, Coilovers, Camber Plates, Rogue SSK, AA Single MP, BM3 Stg 1
Sold: 2015 M235i RWD, MHD Stage 2, FBO, MPE, XHP, HPD5Evo | IG @sea_m235i |
10-07-2019, 02:03 PM | #18 | |
Rep 373
10-09-2019, 06:49 PM | #19 | |
Rep 86
It's more like soft limiter but ALS (Anti-Lag System) kicks in and that's why you hear it. Pretty much all M cars does this right now (maybe besides newest M5). Definitely not a "hard cut limiter", even the thing with wastegate which @nioh_lbbm2 said is more realistic than hard cut limiter. Make sure to analyze those two videos. |
10-11-2019, 03:31 PM | #20 |
Rep 134
Not sure if it's because of this thread, but a customer came to me with this thing.
I'll try over the weekend to flash my N55 EWG with the M2 files for testing.
2016 435i xdrive Gran Coupé
2011 E82 1M Custom Frozen Brilliant White 2006 E60 M5 Alpine white SMG DELETE 6MT swap. Gone : 135i 2008 | Gone : 2008 535i Touring| Last edited by julienjj; 10-11-2019 at 04:31 PM.. |
10-13-2019, 09:54 AM | #21 |
Rep 4,147
I don’t think that will work. Doesn’t BM3 have a stock M2 map - does that give you the sound? Very interested in this.
10-14-2019, 09:10 PM | #22 |
Rep 134
The BM3 m2 maps just transfer over the basic M2 parameters. The M2 use totally different software BUT the same hardware. Normally BMW protect those by FSC (Preventing you from flashing the 320i into a 328i) but the M2 DME is running an incompatible eeprom so it seems they didn't bother
Replacing the eeprom in the DME is not something that can be done by bootmod or by OBD at all.
2011 E82 1M Custom Frozen Brilliant White 2006 E60 M5 Alpine white SMG DELETE 6MT swap. Gone : 135i 2008 | Gone : 2008 535i Touring| |
Tags |
als, anti-lag, bmw 235i, bmw m2, braap |
