02-28-2024, 02:13 PM | #1 |
Rep 5
228i total engine failure
Hi, I am new to this forum. I have a BMW 228i registered in early 2015. I hope someone can shed some light on my engine failure. I have always had an extended warranty on the car and had it serviced by a registered BMW dealer. About 6 months ago I notice a puff of blue smoke on startup, BMW discovered the top valves were worn and they had to rebuild the top of the engine. They said the wear was caused be overheating! All was good for a few months and then driving along an A road the whole engine failed. I freewheeled to a layby. BMW say that the lower part of the engine totally failed and a bearing sheared off causing massive damage to cylinder 4 and throwing metal throughout the engine. They also said the failure was caused by overheating. BMW have agreed to replace the engine entirely with a new one. But have yet to give me a satisfactory reason for the failure. Has anyone heard of such fault on this car? I am worried it might happen again.
02-28-2024, 02:27 PM | #2 |
Rep 1,798
Timing chain guide failures are somewhat common on those engines (not caused by overheating). If the dealer is willing to investigate further that is...
02-28-2024, 07:20 PM | #4 |
Rep 615
Timing chain guide failures are somewhat common on 2015 and older 2.0 engines. Starting in 2016 the design was improved. Are you saying the dealer is replacing your engine under warranty? If so, don't worry about it. Just be glad they are making it right.
03-01-2024, 11:20 AM | #10 |
Rep 109
03-01-2024, 11:38 AM | #11 |
Rep 5
So the engineer said it had nothing to do with the guides. Cam shaft apparently entirely ceased and there was damage in cylinder 1. All they could tell me is it overheated due to oil starvation. But they could tell me no more than that.
freakystyly3006.00 |
03-02-2024, 08:44 AM | #13 |
Rep 615
I change oil every 5000 miles. I'd rather be conservative that way but I don't think oil change intervals caused his engine failure, unless he never changed it.
03-05-2024, 06:47 PM | #14 |
Rep 205
We will never know, but oil starvation may be to gummed oil passages. Could be debris or a defect but my money is on poor oil quality due to long intervals.
