Help Needed. No Crank, No Start After Accident ('18 M240i) |
12-22-2023, 01:35 PM | #1 |
Rep 10
Hey all, recently got my hands dirty in a revival project and everything has gone pretty smoothly up until this point, and then I started dealing with the electronics
I went ahead and took care of the things I could, those being, replacing the positive BST, checking if the clutch safety switch (no issues there), and changing out the ACSM. Prior to changing out the ACSM, the dash displayed a ABS light, and that has since disappeared. The dash turns on as normal with the first press but as soon as you attempt to press the clutch in and start the car, the entire display on the dash shuts off and you're back to step one. Really unsure where to go as it's my first time rebuilding a car, let alone messing with the electronics of one. Here are the codes I managed to pull if anyone would be kind enough to help me draw a conclusion. Note: I haven't gotten the chance to recode the ICM to my vehicle, and I believe the steering errors are a result of that as they weren't popping up previously. Also, I have the IBS cable disconnected from the negative terminal of the battery, the battery was also replaced, and needs to be coded. D35420 - No message (request, braking torque, sum, 60.1.4), receiver DSC, transmitter ICM D354B8 - No message (speed, vehicle, 0X1A1), receiver DSC, transmitter ICM D3550A - No message (switch configuration, driving dynamics, 0X3A7), receiver DSC, transmitter ICM D35538 - No message (roadway inclination, 0X163), receiver DSC, transmitter ICM D35558 - No message (whel torque powertrain 2.41.3.4), receiver DSC, transmitter DME/DDE D3556D - No message (wheel torque powertrain 3, 0X145), receiver DSC, transmitter DME/DDE D35570 - No message (wheel torque powertrain 4, 0x0DC) receiver DSC, transmitter DME/DDE D35755 - No message (specification, parametrisation, I-Brake/HDC, 60.1.4), receiver DSC, transmitter ICM D35A08 - No message (wheel torque powertrain 6, 61.3.4), receiver DSC, transmitter DME/DDE D35B3F - No message (wheel torque drive 5, 40.3.4) receiver DSC, transmitter DME/DDE D35C1B - No message (status, energy generation, 0X1BA) receiver DSC, transmitter DME/DDE 930928 - Driver's seat belt tensioner. Resistance too high (the seatbelt was rebuilt through a third party shop) C95405 - No message (speed, 0x1A1), ACSM Receiver, ICM transmitter C95418 - No message (DME), ACSM reciever, DME/DDE transmitter 482394 - EPS Control Unit: Initialisation fault, steering angle, loss of multi-turn value D51458 - No message (EPS quadrant deviation, 107.0.1) receiver EPS, transmitter ICM/DSC D514B8 - No message (driving speed, 55.3.4) receiver EPS, transmitter ICM/DSC D514C2 - No message (vehicle yaw rate, 56.0.2) receiver EPS, transmitter ICM/DSC D514E8 - No message (front axle actual steering angle, 57.1.2) receiver EPS, transmitter ICM/DSC D5150A - No message (driving dynamics switch configuration, 272.4.8 ) receiver EPS, transmitter ICM/DSC D51744 - No message (drive train data 2, 230.0.2) receiver EPS, transmitter DME/DDE D51C12 - No message (setpoint, steering torque ratio, driver 68.0.2), reciever EPS, transmitter ICM/DSC D51C1B - No message (power generation status, 232.1.2) receiver EPS, transmitter DME/DDE D51C1F - No message (specified electrical power, 232.0.2), receiver EPS, transmitter DME/DDE D51C20 - No message (setpoint steering torque actuator, driver, 68.0.2), receiver EPS, transmitter ICM/DSC If you made it this far, I appreciate you taking the time out of your day! |
12-22-2023, 03:32 PM | #2 |
Rep 1,014
If I had to take a wild guess I'd say diagnose the DME functionality first. Issues there will affect many other systems. It also controls the electrical system.
Just my $0.02, and probably worth less than that. |
