2Addicts | BMW 2-Series forum Technical Topics N20 (228i) / B46 (230i) Engine, Transmission, Exhaust, Tuning white smoke from exhaust, burning oil?
      08-18-2023, 05:54 AM   #1
yep
Drives: M235i ED June 11
2014 M235i, original owner. Never observed this white smoke issue before. I am not a mechanic but google around indicates possible:
Crankcase Ventilation Valve CCV/PCV valve issue
Damaged cylinder head
It's not a lot of smoke, just a bit. Passenger side exhaust pipe only. Exhaust sound is off too. Never seen it in almost 10 years of ownership. White smoke, mostly on ignition start up. Took it to a local BMW branded shop (not a dealer) and they basically said it's fine, keep driving, nothing too bad . Only thing they found was the turbo throttle pipe (aka charge pipe) is a bit cracked/damaged where it connects to the engine.
Ran the oil level check on the car and it's low, on the way towards below minimum levels . That doesn't seem good.
Thoughts? Opinions? Take it to another mechanic?
      08-18-2023, 06:55 PM   #2
Sharpie36
Drives: F22 228i 6MT slicktop
Burning oil is usually bluish. Carbon is black. White is usually water/coolant.
Oil being THAT low is pretty concerning, whether it's related to your smoking issue or not. Definitely need a full checkup and probably well worth doing oil analysis too.
      08-24-2023, 10:33 PM   #3
TTR M240i
TTR M240i's Avatar
Australia
Drives: 2019 M240i
Head gasket.....?????
Did you check the colour of your oil and have you replaced the charge pipe?
      09-15-2023, 01:15 AM   #4
yep
No.
I started it today and it was just a ton of smoke, so much even the engine compartment had smoke in it in just ~60 seconds. There is no way this is normal or okay to drive. I am making an appointment with a different BMW service shop around me.
      09-15-2023, 06:31 AM   #5
yep
It's a lot worse now. This video isn't mine but it's basically the same as mine, even the same exhaust pipe (passenger side).
      09-18-2023, 02:52 AM   #6
TTR M240i
TTR M240i's Avatar
Australia
Drives: 2019 M240i
Hope all goes well.
Keep us posted.
Out of curiosity, is car tuned?
      09-18-2023, 03:22 AM   #7
yep
Hope all goes well.
Keep us posted.
No, stock everything.
      10-11-2023, 02:08 AM   #8
yep
Exclamation
Hope all goes well.
Keep us posted.
Dealer says condensation from not driving the car. They checked everything else.
Well, better safe than sorry. It's true I don't drive the car much anymore since I started WFH full time. It used to be my daily commuter. Need to get it in the garage for the winter.
I guess it's my Sunday driver now .
      10-11-2023, 11:15 PM   #9
TTR M240i
TTR M240i's Avatar
Australia
Drives: 2019 M240i
Phewwwww......
Tags
burning oil, ccv, m235i, pcv, smoke, white smoke
