2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning Upgraded Transmission Mounts
      07-19-2020, 12:27 PM   #23
icin235
icin235's Avatar
Drives: 2015 M235i Silver 6spd
Originally Posted by Wheelwright View Post
I am also interested in upgrading transmission feel in my 235i. I hope it will rekindle my passion for driving.
Your answer:
https://www.m3post.com/forums/showthread.php?t=1349745
      03-02-2021, 01:03 PM   #24
icin235
icin235's Avatar
I just updated my m235i transmission mounts to M2 mounts.
I had 50k miles on the car. Shifting had gotten a little notchier than normal at times. I suspected the drivetrain was moving a little.
These did the trick. Drivetrain feels tight. Shifting back to perfect.
AmuroRay2282.50
      03-02-2021, 04:56 PM   #25
jb-slow
Drives: m235i
Stock m2 mounts?
      03-02-2021, 05:43 PM   #26
MLJR235
MLJR235's Avatar
117
Drives: M235I
If you do not want ANY increase in NVH, stick to a new set of OEM 235 or M2 mounts.
If you want to stiffen it up with minimal increase in NVH, I along with many, recommend the Rogue rubber mounts. They are a perfect balance of stiffness/ mininal nvh.
You can get them from bimmerworld I believe under item ""RE.TM".
'15 235i - Moddedededed
      03-02-2021, 06:28 PM   #27
icin235
icin235's Avatar
Originally Posted by jb-slow View Post
Stock m2 mounts?
Yes, just OEM M2 mounts ordered from ECS Tuning.
      03-03-2021, 02:27 PM   #28
jb-slow
Drives: m235i
Just ordered a set. I tried the ecs mounts and they were absolute hell, only ran them for 1 day.
      03-03-2021, 04:02 PM   #29
XutvJet
I like my M2 mounts as well. I added them in the fall.
      03-08-2021, 12:53 PM   #30
AmuroRay
AmuroRay's Avatar
2283
Any additional NHV? How much stiffer than stock?
Mods: Yes.
      03-16-2021, 07:21 AM   #31
TYC
TYC's Avatar
Drives: 2015 M235i TE
Here’s a link to my trans mount setup. Very little added NVH and I use a body mounted self centering shifter.
@theyoungcarmody
2015 m235i track edition
PTF / Bm3 n55 dev car / brand ambassador
Cscs time attack - street rwd
Who says a race car can’t also be a show car?!?!
      03-16-2021, 11:35 AM   #32
XutvJet
I didn't notice any additional NVH and I'm pretty tuned to that kind of stuff and will remove parts immediately if there's too much NVH/compromise.
Durometer wise, the rubber in the M2/3/4 mount felt maybe 10 to 15% more stiff. However, my stock M235 mounts were also 5 years old. Visually, they looked fine though. No cracks, tears, etc.
      08-15-2022, 12:13 AM   #33
Knhattingh
Knhattingh's Avatar
Drives: BMW 230I
Could someone explain what NVH is?
      08-15-2022, 10:11 AM   #34
jb-slow
Drives: m235i
Noise, vibration, harshness
      09-24-2023, 11:07 PM   #35
ericlr1225
ericlr1225's Avatar
Drives: 2018 M2 LCI 6MT
Originally Posted by TYC View Post
I also tried ecs poly mounts, but it was too harsh.
Mind you I have a body mounted self centering shifter
I went with uuc e series m3 high density rubber mounts, and metal cups. Very happy.
The rubber Is stiffer then stock and absorbs the NVH, the metal cups provide the support to prevent movement.
I'm having chassis mounted shifter with Rouge rubber mounts too.
There is still a metal buzzing sound under the boot. Any NVH to you?
Have you tried stock mount with chassis mounted shifter before?
Thanks
Tags
2 series, bmw, ecs, ecs tuning, f22, m235i, rouge engineering, shifter, short shifter, transmission mounts
